A copper vapor laser collides excited atoms with vaporized copper particles to produce light at wavelengths of 510 nm and 578 nm, which emit green and yellow visible light, respectively. Copper vapor lasers are well-suited for specific applications in micromachining metals and other hard materials, including diamond, glass, silica, silicon, and ceramics. The laser works by using an electrode to excite atoms in a buffer gas, which then collide with vaporized copper, resulting in the emission of either yellow or green light.
This article will discuss the copper vapor laser, including its definition, importance, operation, and key properties.
What Is a Copper Vapor Laser?
A copper vapor laser, also known as a neutral metal laser, utilizes copper vapor as its laser medium. Its primary wavelengths are 510 nm and 578 nm, which produce laser light in green and yellow. This category of lasers is hard to manufacture due to the high temperatures required to vaporize copper. To overcome this difficulty, copper iodide, bromide, or chloride is used, as these forms of copper vaporize at lower temperatures. Copper vapor lasers are highly accurate and are used in micromachining, a process that requires machining at a resolution of 1 micrometer.
What Is the Importance of Copper Vapor Lasers?
The copper vapor laser has an important use in micromachining and cutting applications. Copper vapor lasers are the most powerful form of metal vapor lasers. They also have a unique use in photodynamic therapy, which is a form of cancer treatment.
How Does a Copper Vapor Laser Work?
A copper vapor laser uses a refractory ceramic tube with a low-pressure buffer gas and copper pellets. Two electrodes at the end of the tube create a high-power discharge that excites some metal atoms. At the same time, the increase in temperature to around 1,450 ºC causes some of the copper metal to vaporize. The excited metal atoms collide with the vaporized copper atoms to produce high-energy copper atoms. These atoms then decay to produce either green or yellow light. Figure 1 is a schematic of a copper vapor laser:
What Are the Properties of a Copper Vapor Laser?
The copper vapor laser is a metal-vapor laser that utilizes an electrical discharge as its pump source. The operating wavelengths for this type of laser are 510 nm and 578 nm, which produce green and yellow light, respectively.
What Is the Average Power and Speed of a Copper Vapor Laser?
Copper vapor lasers typically produce an average output power exceeding 100 watts, with high-performance systems capable of reaching over 1 kilowatt. This elevated average power is primarily enabled by the laser’s extremely high pulse repetition rate, which can reach up to 100 kilohertz (kHz). The rapid repetition of short-duration pulses contributes significantly to the high average output, distinguishing copper vapor lasers from other types of pulsed gas lasers.
What Is the Type of Laser Used in a Copper Vapor Laser?
A copper vapor laser uses a type of laser that is a pulse-operated laser rather than a continuous wave laser. This is because the lower-energy light from the laser is slow to depopulate. For this reason, the copper vapor laser must operate in pulse mode to prevent the buildup of lower-energy light.
What Is the Type of Laser Used in Copper Vapor Laser?
A copper vapor laser uses a type of laser that is pulse-operated laser rather than a continuous wave laser. This is because the lower-energy light from the laser is slow to depopulate. For this reason, the copper vapor laser must use pulse operation to prevent the build-up of lower-energy light.
What Are the Uses of a Copper Vapor Laser?
One of the copper vapor laser’s first applications was laser isotope separation in the production of enriched uranium for reactor fuel. Other applications of the laser include:
- High-speed photography
- Dermatological treatment
- As a pump source for dye lasers
- Photodynamic therapy
How Is Copper Vapor Laser Used in Laser Cutting?
When using a copper vapor laser to remove material, the laser energy is used to either vaporize or ablate material from the surface. This is done to retain the thermal effects of vaporization near the laser focal point. Additionally, the stability of the pulse energy means that the laser removes a very consistent layer of material during cutting. For more information, see our guide on How Does Laser Cutting Work.
What Materials Can Copper Vapor Laser Cut?
A copper vapor laser can be used to cut many hard materials because metals and other hard materials easily absorb its wavelength. Copper vapor lasers can be used to cut various metals and the following substances:
- Diamond
- Silica
- Glass
- Silicon
- Ceramics
Additionally, doubling the frequency of a copper vapor laser allows it to produce ultraviolet light, which can be used to machine plastics.
Do Copper Vapor Lasers Give a Quality Result?
Yes, copper vapor lasers provide a high-quality beam. The relative simplicity of the copper vapor laser's operation offers a high-quality beam that facilitates its use in applications, including micromachining.
Can Copper Vapor Lasers Be Used in Laser Etching?
Yes, copper vapor lasers are used in laser etching. The properties of a copper vapor laser—including its high repetition rate, high peak power, and short pulse length—result in a rapid etching ability. For more information, see our guide on What is Laser Etching.
What Are the Advantages of Copper Vapor Lasers?
Copper vapor lasers can micromachine metals whilst also minimizing heat damage to surrounding material to a submicron level. Additional advantages of using a copper vapor laser are:
- Its ability to maintain a diffraction-limited beam at high frequencies.
- The beam profile can be tailored to meet specific requirements.
- The laser has high efficiency for a high power output.
- The laser has a high peak power.
- A copper vapor laser has a smaller minimum beam size when compared to CO2 and Nd:YAG lasers.
What Are the Disadvantages of Copper Vapor Lasers?
One major disadvantage of copper vapor lasers is that they are very difficult to manufacture. This is because the laser tube is required to operate at 1,500 ºC. Other disadvantages of copper vapor lasers include:
- They are costly in comparison to other lasers.
- They can produce dangerous smoke when cutting materials.
- They are poor at cutting reflective materials.
Frequently Asked Questions About Copper Vapor Lasers
Is a Copper Vapor Laser Expensive?
Yes, a copper vapor laser is costly, even in contrast to other lasers. The price of copper vapor lasers is often a major disadvantage. However, they fulfill a specific purpose in high-precision micromachining, which means that, for certain applications, their performance advantage outweighs their high price.
What Is the Difference Between a Copper Vapor Laser and a Metal Vapor Laser?
A copper vapor laser falls into the group of metal vapor lasers. That means every copper vapor laser is a metal vapor laser, but not every metal vapor laser is a copper vapor laser. Other forms of metal vapor lasers include:
- Alkali Vapor Lasers: Alkali vapor lasers use either calcium, potassium, or rubidium, which can be more easily vaporized than copper.
- Helium-Cadmium Lasers: Helium-cadmium lasers use vaporized cadmium as the laser medium. Helium-cadmium lasers emit light in the blue or ultraviolet wavelengths. Rather than cutting and photography, helium-cadmium lasers are used for spectroscopy and holography.
This article presented copper vapor laser, explained what it is, and discussed its various applications. To learn more about copper vapor laser, contact a Xometry representative.
