Metal Bending Services
Instant Quotes and Cost-Effective, On-demand Fabrication | Free Standard Shipping on All US Orders
Bent Metal Parts: Instant Quotes, Parts in Days
Xometry’s sheet metal folding service provides instant quotes for simple and complex bending jobs. You can get an instant quote from a 3D CAD in our Instant Quoting Engine. We use electric and hydraulic press brakes to bend parts to your specifications, including tight-tolerance parts. A range of post-processing options is available so you can get parts that are ready to use.
Our broad network of metal bending shops and expert engineering team can work on anything from small prototyping jobs to large-scale production manufacturing for thick metal plates.
Xometry also offers a waterjet cutting service, a laser cutting service, and a plasma cutting service to cover all your sheet metal fabrication needs.
Metal Bending Materials
Aluminum | Copper | Steel |
Aluminum Aluminum 5052 | Copper Copper 101 | Steel Stainless Steel 301 |
Aluminum Aluminum 6061 | Copper Copper 260 (Brass) | Steel Stainless Steel 304 |
Aluminum Aluminum 7075 | Copper Copper C110 | Steel Stainless Steel 316/316L |
Aluminum | Copper | Steel Steel, Low Carbon |
Additional materials are available upon request!
Available Finishes
Standard
Bead Blast
Powder Coat
Provides corrosion resistance and good conductivity properties. Can be used as a base for paint. Can leave surface yellow/gold.
Custom
Ready to get started on your metal bending quote?
Advantages of Metal Bending With Xometry
Beautiful Parts
The lack of visible weldments makes for a smooth, clean finish.
Accuracy
Bending metal instead of welded parts makes parts more accurate due to the elimination of human error.
Fewer Pieces
You can get the same outcome with fewer pieces vs. an approach that relies on welding parts together.
Metal Bending General Tolerances
Description | General Tolerance |
Description Blank Size | General Tolerance 10’ x 20’ (3.05 m x 6.10 m). We accommodate larger part volumes upon request. |
Description Standard Lead Time | General Tolerance Starts at 3 business days |
Description Sheet Thickness | General Tolerance 0.024” - 0.250” typical. We accommodate thicker or thinner gauges upon request. |
Description General Tolerances | General Tolerance For single planes or flat parts, +/- 0.010” on edge to edge, edge to hole, and hole to hole features; +/- 0.010” on bend to edge/hole features. For multi-planed bent parts, +/- 0.030” for hole to hole/edge, edge to edge, and over-formed parts; +/- 1 degree for bend angles. |
Description Braking (Hydraulic) | General Tolerance 10’ length, fingers from 3” - 6” |
Description Braking (Magnetic) | General Tolerance 6 tons of magnetic pull across the entire beam, 5/8″ minimum reverse bend |
Description Punching | General Tolerance 2″ diameter hole capacity, or larger upon request |
Description Welding | General Tolerance Welded edges and seams, weldments, and assemblies |
This table depicts the general tolerances for Xometry’s sheet metal services. Learn more about our sheet metal manufacturing standards.
Why Choose Xometry for Metal Bending?
Get your bent metal parts delivered right to your door without the hassle of sourcing, project management, logistics, or shipping.
We are ISO 9001:2015, ISO 13485:2016, and AS9100D certified. ITAR registered.
