Xometry Gold Plating Service
Get Quotes in Two Hours and Parts Finished in as Fast as 2 Days. MIL-G-45204, MIL-DTL-45204, ASTM B488 Available.
ITAR Registered
ISO 9001
ISO 13485
AS9100D Certified
Gold Plating Overview
Gold has a bright, reddish-yellow color in its purest form. It does not oxidize in the air at room temperature, so it remains very stable under normal conditions and its electrical conductivity is constant. It is one of the most common precious metals used in finishing. Gold is corrosion resistant, which makes it a good finish for connector pins and electrical switch contacts. Gold plating is used in parts and components across a wide range of industries including medical, energy, semiconductor, aerospace & defense, telecommunications, and oil & gas industries. Specifications: MIL-G-45204, MIL-DTL-45204, ASTM B488, AMS 2422, AMS 2425
- Symbol: Au
- Atomic mass: 196.96657
- Atomic number: 79
- Melting point: 1,948°F (1,064°C)
- Boiling point: 4,892°F (2,700°C)
Competitive Pricing
Access a deep network of world-class gold platers, helping you find the suppliers you need at competitive prices.
Fast Quoting
Streamlined Communication
Anodizing
- Type II Anodize
- Type III Hard coat
- Type III w/ PTFE
Metal Plating
- Copper Plating
- Electroless Nickel
- Electrolytic Nickel
- Nickel Plating
- Nickel Sulfamate
- Nickel Watts
- Tin
- Zinc
Precious Metal Plating
Adhesives and Coatings
- Black Oxide
- Dry Film Lubricants
- Powder Coat
- Wet Paint
Conversion and Pretreatments
- Chem Film
- Chromate Conversion Coating
- Heat Treat
- Passivation
- Pickle and Oil
Surface Treatments
- Bead Blasting
- Electropolishing
- Etching
Part Marking
- Ink Stamping
- Laser Marking
- Silk Screening
Heat Treatments
- Annealing
- Carburizing
- Cryogenic Treatment
- Flame Hardening
- Hydrogen Embrittlement Relief
- Induction Hardening
- Nitriding
- Stress Relieving
Certifications
- AS 9100D
- ISO 13485
- ISO 9001:2015
- ITAR
- NADCAP
- RoHS
Finishing Services at Xometry
Find Your Finisher
Find verified finishers using our robust search tools with over 50 different criteria including location, finishing capabilities, and certifications.
Create and Submit Your Request
Send a breakdown of your project's requirements to the finisher of your choice complete with details on your finishing needs and any necessary files.
Manage Your Order
Manage your order from start to finish in one place, including fast and easy transactions with your credit card or apply for net-30 terms with no hassle or risk.
