Laser Metal Cutting
Laser cutting is one of Xometry's Sheet Metal profiling processes that directs a high-power laser through optics to cut materials for industrial applications. Laser cutting is both more precise and less energy-consuming than plasma cutting, but has an upper threshold on the thickness of the material being cut. Xometry's Manufacturing Partner Network offers both Fiber and CO2 lasers that can cut a number of materials including mild steel, stainless steel, aluminum, copper, brass, and exotic alloys. CO2 (carbon dioxide) laser excels at cutting, engraving, and boring metals, while Fiber laser is a good option for thicker materials. For sheet and plate metal thicker than 4 inches, see our waterjet cutting services.
XOMETRY’S LASER CUTTING
  • Fiber and CO2 lasers
  • Mild steel, stainless steel, aluminum, copper, brass, & exotic alloys
  • Up to 53″ x 121″ (+pass thru)
Get an Instant Quote
Sheet Metal Design Guide
Sheet metal fabrication is a process by which parts are cut and bent from a roll of stock metal material. It can be a very cost-effective way to make straightforward metal parts. Check out our design for tips on how to optimize your files for sheet metal!
Download your free guide for more design tips and information on material selection and whether to choose laser cutting or waterjet cutting.
Download Guide
Manufacturing On Demand
Massive scale when you need it
We integrate seamlessly with over 1000 vetted manufacturing partners in the US including ITAR qualified facilities. You are no longer subject to the limits of your existing local suppliers. Dynamically scale your manufacturing capacity when you need the flexibility. And Xometry guarantees your custom parts will be built to your specifications.
Extensive capabilities on one platform
Xometry’s Partner Network offers wide-ranging capabilities from CNC Machining, industrial-grade 3D Printing, Sheet Metal, Urethane Casting, and production-grade Injection Molding. All just a click away.
Fast lead times, low prices, & lightning-fast quoting
Xometry gives you instant pricing, lead times, and DFM on materials and manufacturing processes for your custom parts. Our proprietary pricing engine uses Machine Learning to analyze 3D CAD drawings and provide instant feedback on pricing, lead times, and the best process to make your custom parts. We turn around Injection molding within 24 hours.
back to Sheet Metal Fabrication
