Annealing vs. Tempering: The Key Differences Between Them
Phillip Keane
Updated byPhillip Keane
16 min read
Published October 24, 2023Updated June 22, 2026
Industrial furnace for annealing and tempering. Image Credit: Shutterstock.com/Aleksandr Ivasenko
Annealing and tempering are closely related processes that use the application of heat to adjust the material properties of various metals. They are fairly similar, although they differ in their cooling methods and intended effects on material properties. Annealing involves slow cooling, while tempering typically involves controlled reheating followed by moderate cooling. Both processes adjust the microstructure of various metals to enhance mechanical properties, though annealing primarily softens the material while tempering reduces brittleness after hardening.
Related and similarly named processes also have applications in other classes of materials—particularly in glass and certain crystalline polymer materials.
What Is Annealing?
Annealing is a heat treatment process used to alter the properties of metals and other materials, typically to make them softer, more ductile, and less brittle. It involves heating the material to a specific temperature and then cooling it slowly in a controlled manner (often in a furnace or insulating medium such as sand or ashes), to manipulate the crystalline structure.
The process can be performed in precise or approximate ways. Precision annealing involves slow cooling in a furnace where the temperature ramps down over a programmed cycle. Process annealing, also known as subcritical annealing, is a lower-temperature method used primarily for low-carbon steels to restore ductility. Full annealing and recrystallization annealing require furnace cooling, while normalizing (a similar process) uses air cooling. The annealing process choice, functional temperature, and cooling duration depend on the material type, previous processing history, and the desired properties.
How Does Annealing Work?
Annealing subjects the material to a carefully controlled heating and cooling sequence. The goal of annealing is to achieve specific changes in the material's microstructure and properties.
The material is heated to a specific annealing temperature, often near or above its recrystallization temperature but below its melting point, at which its crystal structure begins to reorganize.
The rate of heating is controlled to avoid thermal shock in materials that are susceptible to this, such as ceramics or glass. After reaching the annealing temperature, the material is held at that temperature for a specific duration to ensure that heating is complete and uniform and that atomic diffusion processes have sufficient time to occur. The material is then cooled slowly and uniformly. The cooling rate is a critical aspect of annealing. Slow cooling is often achieved by turning off the furnace and allowing the material to cool within the furnace (furnace cooling) or in a controlled atmosphere. The slow cooling allows for the formation of desired microstructures and the reduction of internal stresses.
An illustration of how annealing works.
What Is the Purpose of Annealing?
Annealing serves various purposes in materials processing and manufacturing. It is a near-universal heat treatment technique in steels and many other metals. Annealing softens materials that have become hard or brittle due to previous manufacturing processes, such as quenching, cold working, or machining.
The treatment increases the ductility and malleability of materials, making them easier to work with in subsequent processing steps. Annealing relieves internal stress that has accumulated in the material during prior operations. It promotes the formation of new larger and more equiaxed grains in the material's microstructure, which enhances various mechanical properties of the material.
Annealing helps achieve a more uniform composition throughout the material, particularly in alloys, by allowing the diffusion of elements within the material. Annealed materials are generally easier to machine and form, reducing tool wear and improving throughput. In materials like ferrous alloys, annealing can alter electrical conductivity or magnetic permeability, depending on the specific annealing process used.
What Is the Importance of Annealing?
Annealing plays a crucial role in materials processing and manufacturing, and its importance is underscored by key benefits such as enhanced workability, reduction of internal stresses, and improved machinability.
It is one of the most widely applied heat treatment processes that serves to optimize material properties. Annealing also improves manufacturing efficiency and ensures the reliability and quality of finished products across various industries, including aerospace, automotive, electronics, metalworking, and construction.
What Are the Benefits of Annealing?
The benefits of annealing are varied, and their importance in an individual context can often be related to the nature of the parts being annealed and the post-heat-treatment processes they must undergo. These advantages are:
  1. Improved workability
  2. Relief of internal stresses
  3. Increased ductility and toughness (though ultimate tensile strength may decrease in some cases)
  4. Reduction of anisotropy in mechanical properties
  5. Improved machinability
  6. Better response to subsequent heat treatments
  7. Reduced brittleness
  8. Altered electrical conductivity and magnetic permeability (effects depend on the material and annealing method)
  9. Consistent inter-batch properties and improved quality control
"Xometry offers annealing as a finishing option to relieve internal stresses, improve ductility, and enhance machinability in metal parts. It’s especially useful for parts that will undergo further forming, machining, or welding, like brackets, enclosures, or precision components."
Kurt PokopacSenior Solutions Engineer
What Are the Drawbacks of Annealing?
While annealing offers several advantages, it also has some potential drawbacks and limitations, as listed below:
  1. It can be time-consuming, especially when heavier gauge materials require slow and controlled cooling.
  2. The high temperatures required for annealing can result in significant energy consumption and cost, especially in large-scale industrial settings.
  3. Annealing furnaces and equipment have size limitations, making it challenging to anneal very large components. However, continuous annealing processes, such as those using conveyor furnaces, allow for processing longer materials like metal strips and wires.
  4. During heating, materials generally develop surface scale or oxidation, requiring additional finishing processes to remove this (e.g., pickling or mechanical cleaning).
  5. It may increase or decrease electrical conductivity and magnetic permeability depending on the material and annealing process.
  6. The cost of equipment, energy, and labor associated with annealing can be a drawback.
What Is Tempering?
Tempering is a heat treatment process used primarily for ferrous metals, particularly steel and cast iron. It alters their mechanical properties, primarily to increase toughness and reduce brittleness. The tempering process involves heating a previously hardened material to a specific temperature (typically below its critical temperature, often between 150°C and 700°C, depending on the desired properties) and then cooling it in a controlled manner.
The result of tempering is a material with improved toughness, reduced brittleness, and a trade-off between hardness and ductility. This process is widely used in industries where strong and tough steel components are required, such as in the manufacturing of springs, tools, machine components, and blades/cutters.
How Does Tempering Work?
Tempering involves a transformation of the material’s crystalline microstructure to deliver specific adjustments to the mechanical properties. The process adjusts the proportions and distribution of microstructural phases, modifying the crystal matrixes within the material to exploit the relative benefits of different microstructures.
Hardened steels generally possess a martensitic structure. Martensite is a highly stressed and brittle metastable phase formed during rapid quenching. It has a supersaturated arrangement of atoms and is characterized by a body-centered tetragonal (BCT) lattice.
First, the material is heated to a temperature below the lower critical temperature (A1), typically between 150°C and 700°C, but still relatively high.
The fine-tuning of properties results from precisely controlling target temperature and dwell time. This heating initiates changes in the martensitic structure.
As the material is heated, carbon atoms diffuse, reducing internal stresses within the martensite, and some retained austenite may transform into ferrite and cementite. Contrary to the original statement, austenite (FCC) does not form during tempering unless temperatures exceed A1, which would lead to partial re-austenitization, an undesirable effect in standard tempering.
During the dwell period (rest at elevated temperature), atomic diffusion occurs. Carbon atoms, in particular, diffuse within the lattice, leading to the precipitation of iron carbide (Fe₃C) or alloy carbide within the crystal lattice. The cooling phase of tempering allows the material to retain its tempered martensitic structure, with reduced internal stresses and improved mechanical properties.
The resulting microstructure is called tempered martensite, which has a more refined and less stressed lattice than the original.
The tempered martensite microstructure offers improved toughness and ductility compared to the preexisting, brittle martensite. The fine carbide precipitates within the structure act as barriers to dislocation movement, enhancing the material's toughness and ductility while maintaining sufficient hardness.
An illustration of the tempering process.
What Is the Purpose of Tempering?
The primary purpose of tempering is to optimize the mechanical properties of hardened steel and its alloys and to adjust the balance between hardness and toughness. It increases the toughness of materials by recovering a controlled degree of the ductility that is lost in quench hardening. Tempering reduces brittleness and improves the ability to withstand impact and dynamic loads without fracturing. It also moderates the hardness of quenched steels.
While hardness is valued, full hardness carries a high risk of fracture, meaning a balance of properties is often preferred. Tempering refines the microstructure of the material, promoting the formation of tempered martensite and fine carbide precipitates within the lattice. This microstructure adjustment enhances both strength and ductility.
Tempering can relieve internal stresses that accumulate during quenching or cold working, reducing the risk of distortion, warping, or fracture in the finished product. It makes materials easier to machine, weld, and form, reducing tool wear and easing manufacturability. Tempering ensures the consistency of material characteristics, which is vital for quality control and inter-batch repeatability.
What Is the Importance of Tempering?
The importance of tempering lies in its ability to optimize the mechanical properties of hardened materials, primarily steel and its alloys, to achieve a balance between hardness and toughness.
Tempering is essential for materials used in engineering and manufacturing because it allows their properties to be fine-tuned to meet the specific demands of their intended use. It ensures that materials are appropriately strong, tough, and resilient for the intended application, benefiting industries such as automotive, construction, aerospace, and tool manufacturing.
What Are the Benefits of Tempering?
Tempering brings well-understood benefits to hardened materials, including:
  1. Enhanced toughness (reduced brittleness)
  2. Microstructure refinement
  3. Stress relief
  4. Customization of mechanical properties
  5. Improved workability (ductility and machinability)
  6. Selective control of hardness and strength
  7. Property consistency/repeatability
What Are the Drawbacks of Tempering?
While tempering is a valuable heat treatment process with many advantages, it also has some potential drawbacks and limitations:
  1. Achieving the desired combination of properties through tempering can be a skilled and slow process, requiring careful control of temperature and time.
  2. The size of the material or component being tempered is limited by the capacity of available tempering furnaces.
  3. The heating process during tempering produces surface oxidation or scaling, which generally requires additional finishing processes.
  4. The heating and tempering process requires considerable energy.
  5. The need for restored toughness necessitates a reduction in hardness, as the two properties are inversely related in hardened steels.
What Is the Role of Annealing and Tempering in Steel Microstructure?
Annealing and tempering are two crucial heat treatment processes that play distinct roles in modifying the microstructure of steel, which in turn affects its mechanical properties.
Annealing promotes the formation of a more stable, refined, and less stressed microstructure. During the heating phase, austenite forms a more regular arrangement of atoms. While the steel is held at the annealing temperature, atomic diffusion and migration occur. Carbon atoms diffuse within the lattice, precipitating carbide particles within the matrix.
The cooled material retains some of the austenite but also reverts some of it back to a ferritic or pearlitic structure that is more regular and less stressed than the pre-annealed state. The resulting ferrite or pearlite has a more balanced combination of strength and ductility than the heat/quenched or work-hardened martensite.
Tempering, on the other hand, begins with the material in its hardened state, typically martensite, a body-centered tetragonal lattice with elevated hardness and high brittleness. Tempering aims to reduce “excess” hardness and increase toughness. During tempering, the martensitic structure is transformed to a more stable phase, often austenite, which includes the condensation of fine carbide precipitates within the matrix.
The cooling phase of tempering allows the material to retain a proportion of tempered martensite, but it also reverts some of it back to austenite or other phases, depending on the tempering conditions. The proportions can be fine-tuned by tempering temperature and dwell time. The result is a tunable degree of improved toughness, balanced hardness, and ductility.
To learn more, see our full article on Steel Microstructure.
How Do Annealing and Tempering Differ in Process?
Annealing is a low-control process, in which the target state is unitary, irrespective of the starting condition of the material. That is, if the temperature of a part is raised to a sufficient level, i.e., the annealing temperature, and then the part is cooled slowly, the fully annealed state will result.
There is no variation in the target for this, i.e., a partially annealed state is rarely required. The fully annealed state is one in which:
  1. All regions of the part have the maximum possible crystal size.
  2. All internal stresses are relieved.
  3. All traces of any prior heat treatment or hardening have been eradicated from the crystalline structure.
Tempering, on the other hand, is a precise and quantified process in which a part is first hardened, generally by heat/quench processing, and then the temperature is raised to an annealing level that is moderately controlled. The heat is maintained for a critical and predetermined dwell time to allow the part to become completely uniform in temperature and for the microstructural alterations to commence and proceed fully throughout. The part is then allowed to cool in controlled conditions, such as air or oil, to complete the revision of the microstructure.
The degree of tempering depends on the desired properties sought from the process and the initial state of hardening of the part, making this a much more complex process with a spectrum of outcomes that require precision control. In some regards, similar to an annealed structure, the tempered material will show:
  1. A slight to significant reduction in hardness
  2. A slight to extreme increase in toughness and ductility
  3. Some degree of retention of the hardened microstructure, from moderate to virtually unmodified
  4. Reduced, but not fully eased, residual stress
What Are the Temperatures Used for Annealing and Tempering?
For annealing, the typical temperature range of between 500–900°C is used, depending on the material being treated. Softer steels and other materials generally require lower temperatures within this range, while high-carbon steels and alloys may require the higher end of the range. The precise temperature depends on the material’s composition and the desired final properties.
For tempering, temperatures generally range from 150–650°C, depending on the desired balance of hardness, toughness, and ductility. Lower tempering temperatures (e.g., around 150 to 300°C) will preserve more hardness while improving toughness slightly. As the tempering temperature increases, the material becomes more ductile and fracture-resistant, but at the cost of reduced hardness. The exact temperature selected for tempering will depend on the application and the material's initial hardening state.
How Do the Applications of Annealing and Tempering Differ?
Annealing serves the one purpose of removing all heat-treatment or work-hardening-imposed microstructural changes from a part. The material is returned to its fully ductile/malleable state. This allows for shaping and forming to proceed with minimum risk of microstructural or macro damage.
Annealing is widely applied as a process for various metals, such as nickel, nickel alloys, stainless steel, carbon steel, copper, copper alloys, titanium, and titanium alloys. It is an aid to ease manufacturing and finds application in various metals that both can and cannot undergo hardening by heat/quenching. Work-hardened metals suffer embrittlement and hardening by work being done to them.
Tempering is a fine adjustment process that can tune the properties of previously hardened materials, allowing a wide spectrum of outcomes from near fully hard and brittle (typical of a file) to fairly ductile and with somewhat reduced hardness (typical of a spring or a screwdriver tip). Tempering is, therefore, often seen as a finishing process for many parts made in steel, to fine-tune their properties once shaping is complete.
Tempering can also be a fine-tuning process that serves to remove residual stresses prior to machining so that post-machining parts will not distort when cut, allowing heat treatment to be performed prior to cutting. This is typical of injection mold tool bolsters/cavities which are generally shaped after hardening/tempering, using EDM or wire cut methods and high-speed carbide cutters.
Which Is More Expensive, Annealing or Tempering?
Of the two processes, tempering is considerably more costly both in time and skills.
Annealing is a simple process that uses a brief elevation of temperature to a level above the critical and glass transition temperature of the material, followed by slow cooling. Tempering requires a precise and very uniform heating of the part, a dwell time at the elevated temperature that depends on part size and section thickness, and a slow cooling in open air. This is more technically demanding and takes longer than annealing.
When To Use Annealing Instead of Tempering?
Annealing is a process used to remove any unwanted, thermally applied heat/quench effects, work hardening, or a combination of the two forms of microstructure change. The treatment is used to return the material to its relaxed and most workable state, to allow forming processes to be completed with less effort and risk of fracture.
Tempering is applied to adjust material properties after a hardening process, generally to remove some of the detrimental effects that hardening has wrought upon the part or material.
How Do Annealing and Tempering Differ in Materials?
Annealing has wide application across most metals. In general, it is a method used to either prepare raw material for forming or as an intermediate treatment that allows the removal of work hardening during processing, to allow further forming stages to be undertaken with less risk of fracture. It is applicable to many metals, from aluminum to tantalum, and most stainless steel to copper.
Tempering is a much more narrowly applicable method that is applied most commonly to steel alloys of various varieties to relieve some of the negative effects of heat/quench hardening. It is also used in beryllium-copper, and to a lesser extent in brass, bronze, aluminum, copper, and even some cast iron materials.
This article presented annealing vs. tempering, explained each of them, and discussed their key differences. To learn more about annealing and tempering, contact a Xometry representative.
