Inconel 600: Composition, Properties, and Temperature Range
Written byMegan Conniff
25 min read
Published June 22, 2026Updated November 20, 2026
Inconel 600 Alloy. Image credit: Shutterstock/Crarex
Inconel 600 is a nickel-chromium superalloy within the broader nickel alloy family, engineered for sustained performance under high-temperature oxidizing and reducing environments where carbon and low-alloy steels fail within hours of exposure. The alloy carries a nominal composition of 72% nickel minimum, 14% to 17% chromium, and 6% to 10% iron, producing a face-centered cubic (FCC) austenitic matrix that retains structural integrity from cryogenic temperatures up to 2,000°F (1,093°C) in continuous service.
Inconel 600 delivers oxidation resistance through a stable chromium oxide (Cr₂O₃) surface layer that regenerates after mechanical damage, corrosion resistance in alkaline and organic acid environments, and tensile strength from 80 ksi to 100 ksi at room temperature that decreases gradually rather than abruptly with rising temperature. The alloy qualifies under ASTM B168 (plate and sheet), ASTM B166 (rod and bar), and ASTM B167 (seamless pipe and tube), with applications spanning nuclear reactor components, chemical processing heat exchangers, aerospace combustion hardware, and industrial furnace fixtures. The combination of nickel content above 72%, solid-solution strengthening from chromium and iron, and resistance to stress corrosion cracking in chloride environments establishes Inconel 600 as the reference material for high-temperature service where alloy stability over decades of continuous exposure is the primary design requirement.
What Is Inconel 600?
Inconel 600 is a nickel-chromium-iron superalloy classified under the UNS N06600 designation, produced in wrought form through hot rolling, cold drawing, and forging processes that develop the fine-grained austenitic microstructure responsible for its mechanical and corrosion performance. The alloy belongs to the Inconel family of nickel-based superalloys, distinguished from lower-nickel grades by its minimum 72% nickel content, which provides both corrosion resistance in reducing environments and thermal stability across a continuous service range from negative 423°F (negative 253°C) to 2,000°F (1,093°C). The industrial relevance of Inconel 600 spans multiple critical sectors. Nuclear power plants historically utilized the alloy for steam generator tubing, pressurizer heater sleeves, and reactor vessel components due to general corrosion resistance, despite its long-term susceptibility to primary water stress corrosion cracking (PWSCC) in high-purity water at 550°F to 650°F (288°C to 343°C). Chemical processing facilities specify it for heat exchanger tubing, retort vessels, and distillation columns handling caustic soda, chlorinated solvents, and organic acids. Aerospace manufacturers use the alloy for combustion chamber liners, afterburner components, and turbine exhaust hardware operating at temperatures from 1,400°F to 2,000°F (760°C to 1,093°C). The alloy's combination of fabricability, weldability, and long-term stability in oxidizing, reducing, and mixed-atmosphere environments makes it a baseline specification material across industries where alloy substitution introduces unacceptable reliability risk.
What is the Chemical Composition of Inconel 600?
The chemical composition of Inconel 600 is shown in the table below.
The balance of the composition is nickel, which exceeds 72% in all certified heats. The absence of molybdenum differentiates Inconel 600 from Inconel 625 (8% to 10% molybdenum) and limits its resistance in reducing acid environments (such as dilute hydrochloric and sulfuric acids) and localized chloride pitting, while its high nickel and chromium contents maintain fair stability in mildly oxidizing media.
Why is Nickel Content Critical in Inconel 600?
Nickel content is critical in Inconel 600 because high nickel concentration stabilizes the alloy structure and resists oxidation and corrosion under extreme conditions. Nickel at 72% minimum governs the corrosion resistance, thermal stability, and microstructural integrity of Inconel 600 across the entire service temperature range from negative 423°F to 2,000°F (negative 253°C to 1,093°C). Nickel stabilizes the face-centered cubic (FCC) austenitic matrix at all temperatures without phase transformation, preventing the ductile-to-brittle transition that occurs in ferritic and martensitic alloys below 32°F (0°C). The FCC structure remains ductile and tough at cryogenic temperatures, with Charpy impact values above 50 ft·lb at negative 320°F (negative 196°C), a performance level unachievable in iron-based alloys without specialized alloying. Nickel provides immunity to stress corrosion cracking (SCC) in chloride environments that destroy austenitic stainless steels (304 and 316 grades) at temperatures above 140°F (60°C) in corrosion resistance. Stainless steel 316 experiences SCC at chloride concentrations as low as 50 ppm at 212°F (100°C), while Inconel 600 resists SCC at chloride concentrations above 1,000 ppm across the same temperature range. At high temperatures, nickel slows oxidation kinetics by maintaining the adhesion and regeneration of the chromium oxide (Cr₂O₃) protective layer, extending oxidation resistance to 2,000°F (1,093°C), where iron-based alloys with equivalent chromium content fail through rapid scale spallation above 1,400°F (760°C). Lower-nickel alloys (below 40% nickel) such as 309 stainless steel lose oxidation resistance above 1,800°F (982°C) through cyclic spallation, while Inconel 600 maintains protective scale integrity through repeated thermal cycling at the same temperature.
What Are the Key Properties of Inconel 600?
The key properties of Inconel 600 deliver a combination of mechanical strength, corrosion resistance, and thermal stability that positions it among the most reliable superalloys for high-temperature and chemically aggressive service environments. At room temperature, the alloy achieves tensile strength from 80 ksi to 100 ksi (552 MPa to 689 MPa), yield strength from 25 ksi to 45 ksi (172 MPa to 310 MPa), and elongation from 35% to 45%, reflecting high ductility and toughness in the annealed condition. Hardness ranges from 120 HB to 200 HB, depending on cold work and heat treatment conditions. Thermal properties include a melting range from 2,470°F to 2,575°F (1,354°C to 1,413°C), thermal conductivity of BTU/(hr·ft·°F) at 70°F (14.9 W/m·K), and a coefficient of thermal expansion of 8.6 × 10⁻⁶ in/in/°F (15.5 × 10⁻⁶ m/m·K) from 70°F to 1,200°F. The low thermal expansion coefficient relative to austenitic stainless steels (9.6 × 10⁻⁶ in/in/°F for 304 SS) reduces thermal fatigue risk in components subject to repeated heating and cooling cycles. Electrical resistivity of 620 ohm·circ mil/ft (103 μΩ·cm) and density of 0.306 lb/in³ (8.47 g/cm³) complete the physical property profile. The alloy is non-magnetic in all conditions, qualifying it for applications near sensitive electronic or magnetic measurement equipment in nuclear and aerospace environments.
How Does Inconel 600 Perform at High Temperatures?
Inconel 600 performs at high temperatures by maintaining structural integrity and oxidation resistance across a continuous service range from 1,000°F to 2,000°F (538°C to 1,093°C), performing through oxidizing, reducing, and mixed-atmosphere conditions that degrade iron-based and lower-nickel alloys within weeks or months. At 1,200°F (649°C), the alloy retains tensile strength of approximately 75 ksi (517 MPa) and yield strength of approximately 30 ksi (207 MPa), representing strength retention of 85% and 75%, respectively, compared to room-temperature values. At 1,800°F (982°C), tensile strength decreases to approximately 25 ksi (172 MPa), with yield strength near 15 ksi (103 MPa), as thermally activated dislocation climb and grain boundary sliding reduce load-carrying capacity through creep mechanisms. Oxidation resistance at high temperatures is governed by the chromium oxide (Cr₂O₃) surface layer, which remains stable and adherent up to 2,000°F (1,093°C) in air and oxidizing combustion atmospheres. Above 2,000°F (1,093°C), chromium oxide volatilizes as CrO₃ gas, destabilizing the protective layer and accelerating metal recession at rates above 0.002 inches per year. Creep rupture life at 1,800°F (982°C) under 1.5 ksi to 2.5 ksi (10.3 MPa to 17.2 MPa) stress reaches 100 hours to 500 hours, depending on grain size and prior heat treatment condition, qualifying the alloy for short-duration high-temperature fixtures but not for long-term creep-loaded structural service above 1,800°F without stress reduction.
What Is the Melting Point of Inconel 600?
The melting point of Inconel 600 ranges from 2,470°F to 2,575°F (1,354°C to 1,413°C), reflecting the solidification behavior of a multi-component alloy system rather than a single-element pure metal with a fixed melting point. The lower bound (2,470°F / 1,354°C) represents the solidus temperature, the point at which the last solid phase begins to liquefy during heating. The upper bound (2,575°F / 1,413°C) represents the liquidus temperature, at which the alloy is fully molten. The 105°F (58°C) melting range creates a mushy zone during casting and welding where solid and liquid phases coexist, requiring careful thermal management to prevent hot cracking and segregation of chromium and iron in the solidifying weld pool. The melting range of Inconel 600 exceeds that of austenitic stainless steel 316 (2,450°F to 2,550°F / 1,343°C to 1,399°C) by approximately 20°F to 25°F at the solidus, contributing to the alloy's superior retention of mechanical properties at temperatures approaching 2,000°F, where 316 stainless steel loses effective strength above 1,500°F (816°C).
What Is the Temperature Range of Inconel 600?
The temperature range of Inconel 600 operates across a continuous service temperature range from negative 423°F to 2,000°F (negative 253°C to 1,093°C), covering cryogenic, ambient, elevated, and high-temperature service conditions within a single alloy without phase transformation or embrittlement. The cryogenic lower limit of negative 423°F (negative 253°C) reflects the alloy's FCC austenitic structure, which retains ductility and toughness at liquid hydrogen temperatures without the ductile-to-brittle transition that limits ferritic steels and body-centered cubic (BCC) alloys below negative 40°F (negative 40°C). The upper continuous service limit of 2,000°F (1,093°C) is governed by three factors: oxidation resistance of the chromium oxide surface layer (stable below 2,000°F), creep strength retention under structural load (tensile strength above 20 ksi / 138 MPa below 2,000°F), and grain boundary stability (carbide dissolution and grain growth acceleration above 2,000°F, weakening the matrix). Intermittent service exposure at temperatures up to 2,100°F (1,149°C) is acceptable for short durations (below 100 hours) where creep accumulation and oxidation loss remain within design tolerance. Load conditions directly affect the usable upper temperature limit: unloaded fixture components tolerate 2,000°F, while components under sustained stress of 1.2 ksi (8.3 MPa) or less are limited to 1,800°F (982°C) to maintain creep rupture life above 1,000 hours.
How Does Temperature Affect Inconel 600 Performance?
Temperature affects Inconel 600 performance across three distinct regimes. The ambient-to-elevated range (70°F to 1,000°F / 21°C to 538°C), the high-temperature range (1,000°F to 1,800°F / 538°C to 982°C), and the extreme range (1,800°F to 2,000°F / 982°C to 1,093°C), each characterized by different dominant degradation mechanisms. Tensile strength decreases gradually from 80 ksi to 100 ksi (552 MPa to 689 MPa) at room temperature to approximately 70 ksi (483 MPa) at 1,000°F from 70°F to 1,000°F (21°C to 538°C), while oxidation remains negligible with metal loss below 0.0001 inches per year. Creep is not a design factor below 1,000°F. Tensile strength continues to decrease from 70 ksi to approximately 25 ksi (172 MPa) from 1,000°F to 1,800°F (538°C to 982°C), and creep becomes the primary structural degradation mechanism. The chromium oxide surface layer remains intact and regenerative, limiting oxidation to below 0.001 inches per year in clean oxidizing atmospheres. Creep rupture life drops sharply from 1,800°F to 2,000°F (982°C to 1,093°C). Rupture life falls below 100 hours at 1,900°F (1,038°C) under 1.0 ksi (6.9 MPa) stress. Oxidation accelerates above 1,950°F (1,066°C) as chromium oxide begins volatilizing, increasing metal recession to 0.003 inches to 0.005 inches per year. Grain growth above 2,000°F (1,093°C) reduces yield strength by 15% to 25% compared to the fine-grained annealed condition, marking the effective performance degradation threshold for structural applications.
How Does Inconel 600 Compare to Other Alloys?
The comparison of Inconel 600 to other alloys is shown in the table below.
The primary industrial selection criteria from Inconel 600 to alternative alloys are temperature limit, acid environment type, and required strength level. Inconel 600 is selected when the environment is reducing or mildly oxidizing, the temperature reaches 2,000°F, and cost efficiency is a constraint. Inconel 625 is selected when stronger oxidizing acids or seawater corrosion is present. Inconel 718 is selected when tensile strength above 150 ksi is required at temperatures below 1,300°F. Hastelloy C-276 is selected for the most aggressive mixed oxidizing-reducing acid environments where no other alloy provides adequate corrosion resistance.
How does Inconel 600 Compare to Inconel 625?
The comparison of Inconel 600 to Inconel 625 is shown in the table below.
The molybdenum content of 8% to 10% in Inconel 625 is the key differentiator, raising the pitting resistance equivalent number (PREN) from approximately 14 to 17 in Inconel 600 to approximately 50, providing resistance to pitting and crevice corrosion in seawater, chloride brines, and oxidizing acid mixtures where Inconel 600 experiences accelerated corrosion. Inconel 600 retains the advantage in strongly reducing environments (hydrogen sulfide, hot caustic alkalis) where molybdenum provides no additional benefit, and the higher nickel content of Inconel 600 governs corrosion resistance. The higher tensile strength of Inconel 625 (120 ksi to 135 ksi vs 80 ksi to 100 ksi) reflects additional solid-solution strengthening from molybdenum and niobium, making Inconel 625 the preferred choice when high corrosion resistance and structural strength are required in the same component.
How does Inconel 600 Compare to Inconel 718?
The comparison of Inconel 600 to Inconel 718 is shown in the table below.
The precipitation hardening mechanism of Inconel 718 through γ″ (Ni₃Nb) phase formation after aging at 1,325°F to 1,375°F (718°C to 746°C) produces tensile strength from 180 ksi to 220 ksi (1,241 MPa to 1,517 MPa), more than double that of the solid-solution strengthened Inconel 600. The strength advantage of Inconel 718 is decisive in high-stress aerospace applications, including turbine discs, compressor blades, and fasteners that require fatigue strength above 100 ksi. Inconel 600 surpasses Inconel 718 in maximum service temperature (2,000°F vs 1,300°F), as the γ″ precipitates that provide strength in Inconel 718 coarsen and transform into the stable, incoherent δ phase above 1,300°F (704°C), causing rapid strength loss. Inconel 600 is specified for furnace fixtures, heat exchanger tubing, and nuclear reactor components where continuous service above 1,300°F at moderate stress levels governs material selection over peak room-temperature strength.
What is the Difference Between Inconel 600 and Inconel 713?
The comparison of Inconel 600 to Inconel 713 is shown in the table below.
Inconel 713 achieves its high tensile strength (120 ksi to 135 ksi) through γ′ (Ni₃Al) precipitation hardening, enabled by aluminum content from 5.5% to 6.5% and titanium from 0.5% to 1.0%, elements absent in Inconel 600. The high aluminum content makes Inconel 713 susceptible to hot cracking during welding, limiting it to investment casting production for complex turbine blade and nozzle guide vane geometries, where the casting process forms the final net shape without welding. Inconel 600's excellent weldability and availability in wrought product forms (plate, bar, tube) make it the appropriate selection for fabricated equipment (heat exchangers, furnace retorts, chemical reactors) where joining and forming operations are required during manufacture. Machined Inconel 600 parts are available through Xometry's Inconel CNC machining service.
What Are the Applications of Inconel 600?
The applications of Inconel 600 are listed below.
  • Nuclear Reactor Components: Inconel 600 is specified for pressurized water reactor (PWR) steam generator tubing, pressurizer heater sleeves, and control rod drive mechanism housings operating at 550°F to 650°F (288°C to 343°C) in high-purity water environments. The alloy's resistance to general corrosion in boric acid solutions and lithiated water made it the historical standard for nuclear primary circuit components, though decades of operational data revealed its severe susceptibility to primary water stress corrosion cracking (PWSCC).
  • Chemical Processing Heat Exchangers: Shell-and-tube heat exchangers handling caustic soda (sodium hydroxide) at concentrations from 10% to 70% and temperatures from 200°F to 600°F (93°C to 316°C) use Inconel 600 tubing, as the high nickel content provides immunity to caustic stress corrosion cracking that destroys stainless steel 304 and 316 tubing within months of exposure. The alloy is also specified for handling chlorinated solvents, fatty acids, and organic process streams.
  • Industrial Furnace Components: Radiant tubes, muffles, retorts, annealing fixtures, and furnace rolls are produced in Inconel 600 for industrial heat treating furnaces operating at 1,400°F to 2,000°F (760°C to 1,093°C) in air, nitrogen, hydrogen, and endothermic atmospheres. The alloy's resistance to carburization in hydrocarbon-bearing atmospheres and nitriding in ammonia dissociation atmospheres extends fixture service life from months to years compared to stainless steel alternatives.
  • Aerospace Combustion Hardware: Combustion chamber liners, afterburner components, and jet engine exhaust hardware operating at 1,600°F to 2,000°F (871°C to 1,093°C) are fabricated in Inconel 600 sheet and formed components, using the alloy's oxidation resistance and thermal fatigue strength to withstand repeated engine start-stop thermal cycles from ambient to maximum operating temperature.
  • Thermocouple Protection Sheaths: Inconel 600 tube stock serves as the outer sheath material for Type K and Type N thermocouples measuring temperatures from 32°F to 2,000°F (0°C to 1,093°C) in oxidizing and mildly reducing furnace atmospheres, providing mechanical protection for the thermocouple wire assembly while maintaining dimensional stability across the measurement temperature range.
  • Food Processing Equipment: Inconel 600 is used in sparger tubes, agitator shafts, and heat exchanger surfaces in fatty acid hydrogenation reactors and high-temperature food processing equipment where nickel alloy purity standards (FDA 21 CFR compliance) and corrosion resistance in organic acid environments are required.
How Is Inconel Used in Thermocouple Applications?
Inconel is used in thermocouple applications as a protective sheath and structural material that shields sensing elements from extreme heat, oxidation, and chemical attack. Inconel 600 serves as the primary sheath material for thermocouple protection tubes in temperature measurement systems operating from 32°F to 2,000°F (0°C to 1,093°C) in industrial furnaces, chemical processing, and aerospace environments. The sheath tube, produced from Inconel 600 seamless tubing per ASTM B167, provides mechanical protection for the thermocouple wire assembly (Type K: chromel-alumel, Type N: nicrosil-nisil) against abrasion, chemical attack, and thermal shock while maintaining dimensional stability across the full measurement range. Inconel 600 sheath compatibility extends to Type K and Type N thermocouples for applications up to the alloy's continuous service temperature limit of 2,000°F (1,093°C), though the sensor elements themselves can measure up to 2,372°F (1,300°C) when paired with specialized high-temperature refractory sheaths.  The alloy's low magnetic permeability (relative permeability approaching 1.0 in the annealed condition) prevents electromagnetic interference with the thermocouple millivolt signal, a critical requirement for high-accuracy temperature measurement in controlled atmosphere furnaces. High-temperature sensing accuracy is preserved by the dimensional stability of Inconel 600 sheath tubing. Thermal expansion (coefficient of 8.4 × 10⁻⁶ in/in/°F) produces predictable sheath elongation of 1.01 inches per 10 feet of tube length per 1,000°F temperature rise, allowing engineers to account for sheath movement in thermowell and protection tube mounting designs without inducing measurement error from sheath contact with the thermocouple wires.
What Are the Advantages of Inconel 600?
The advantages of Inconel 600 are listed below.
  • Resistance to Stress Corrosion Cracking in Chloride Environments: Inconel 600 resists chloride-induced stress corrosion cracking (SCC) at chloride concentrations above 1,000 ppm and temperatures from 200°F to 600°F (93°C to 316°C), environments that cause rapid cracking failure in austenitic stainless steels 304 and 316 at concentrations as low as 50 ppm. The resistance, governed by nickel content above 72%, eliminates a primary failure mode in chemical processing, nuclear cooling water, and coastal industrial environments.
  • Continuous Service at 2,000°F (1,093°C): The stable chromium oxide (Cr₂O₃) surface layer and solid-solution-strengthened FCC matrix allow Inconel 600 to operate at 2,000°F in air, oxidizing combustion gases, and reducing atmospheres without structural degradation, a temperature ceiling 400°F to 500°F above the practical service limit of austenitic stainless steels.
  • Resistance to Carburization and Nitriding: Inconel 600 resists carbon absorption in hydrocarbon-bearing furnace atmospheres at 1,600°F to 1,900°F (871°C to 1,038°C), where carburization destroys stainless steel components through internal carbide formation and embrittlement. The alloy similarly resists nitrogen absorption in ammonia dissociation (25% nitrogen, 75% hydrogen) and nitriding furnace atmospheres up to 1,832°F (1,000°C).
  • Excellent Fabricability and Weldability: Inconel 600 is readily formed by cold rolling, deep drawing, and spinning, with a work hardening rate similar to austenitic stainless steels. The alloy welds without post-weld heat treatment using Inconel 82 bare wire (ERNiCr-3 per AWS A5.14) or Inconel 182 covered electrodes (ENiCrFe-3 per AWS A5.11), producing weld deposits with corrosion resistance matching the base metal.
  • Cryogenic Performance: The FCC austenitic structure retains ductility and Charpy impact values above 50 ft·lb at negative 423°F (negative 253°C), qualifying Inconel 600 for liquid hydrogen storage, cryogenic transfer line components, and superconducting magnet support structures where BCC alloys are excluded by ductile-to-brittle transition risks.
  • Long Service Life in Alkaline Environments: Inconel 600 demonstrates corrosion rates below 0.005 inches per year in sodium hydroxide concentrations from 10% to 70% at temperatures up to 572°F (300°C), providing service life exceeding 20 years in caustic evaporator tubing and pulp and paper industry digesters, reducing maintenance shutdown frequency and replacement costs relative to stainless steel alternatives that require replacement within 2 to 5 years in the same environments.
Why Is Inconel 600 Preferred in Industrial Applications?
Inconel 600 is preferred in industrial applications because the combination of corrosion resistance, high-temperature stability, and fabricability eliminates multiple competing failure modes within a single alloy, reducing the need for material substitutions, protective coatings, or frequent component replacement over the service life of industrial equipment. In chemical processing, the alloy's immunity to caustic stress corrosion cracking and resistance to organic acid environments reduces unplanned heat exchanger failures that cost facilities from [$50,000] to [$500,000] per shutdown event in lost production and emergency repair costs. Inconel 600's 50-year operational track record in PWR steam generator tubing and control rod drive mechanisms provides documented operational data required by nuclear regulatory authorities (NRC 10 CFR 50) for safety-critical component qualification, a framework that now effectively mandates the systematic mitigation or replacement of this alloy with crack-resistant alternatives like Alloy 690 or Alloy 800 in operating nuclear systems. The material stability under neutron flux irradiation at doses from 10²⁰ to 10²¹ neutrons/cm² without significant embrittlement or swelling further supports its continued specification in reactor internals. The alloy's resistance to oxidizing combustion gases at 1,600°F to 2,000°F (871°C to 1,093°C) and resistance to thermal fatigue cracking through repeated start-stop cycles extend component replacement intervals from 500 hours to over 5,000 hours in afterburner and exhaust system hardware, directly reducing maintenance labor costs in military and commercial engine overhaul programs. The adoption of Inconel 600 across chemical, nuclear, and aerospace industries reflects its reliability under extreme heat and corrosion as a material-driven strategy for reducing lifecycle maintenance expenditure.
How Does Heat Treatment Affect Inconel 600?
Heat treatment affects Inconel 600 by modifying the grain structure, carbide distribution, and residual stress state of Inconel 600, directly affecting corrosion resistance, ductility, and dimensional stability without changing the alloy's fundamental solid-solution strengthening mechanism. The primary heat treatment objectives for Inconel 600 are grain boundary carbide control (to prevent sensitization), residual stress relief (to reduce stress corrosion cracking susceptibility), and grain size optimization (to balance strength and creep resistance). Carbide behavior governs the most critical heat treatment effect. Carbon content from 0.05% to 0.15% in Inconel 600 precipitates as chromium carbide (Cr₂₃C₆) at grain boundaries when the alloy is held from 1,000°F to 1,400°F (538°C to 760°C) for extended periods, depleting chromium in the grain boundary zone below the 10% minimum required for corrosion resistance. The chromium-depleted zone becomes susceptible to intergranular corrosion in oxidizing environments, a condition called sensitization. Annealing at 2,000°F to 2,100°F (1,093°C to 1,149°C) followed by rapid cooling completely dissolves the carbide network and restores chromium uniformity across the grain boundary, eliminating sensitization and recovering full corrosion resistance. The heat treatment temperature, time, and cooling rate must be controlled precisely to achieve the target grain size (ASTM 4 to 7) and carbide distribution required for the specific service environment of each component.
"On paper, superalloys like Inconel 600 look like indestructible magic bullets for extreme heat. In the shop (and out in the field), the harsh realities of high-temperature creep and thermal expansion will warp or crack an over-engineered part within days. Designing for manufacturability means matching true operational limits with realistic mechanical loads: you simply cannot expect clean CAD lines to survive extreme environments if you only design for room-temperature properties."
What Are the Recommended Heat Treatment Methods for Inconel 600?
The recommended heat treatment methods for Inconel 600 are listed below.
  • Full Annealing: Full annealing (solution annealing) is performed at 2,000°F to 2,100°F (1,093°C to 1,149°C) for 1 to 2 hours to completely dissolve chromium carbides and optimize grain size for high-temperature service, whereas a standard mill anneal is carried out at 1,800°F to 1,850°F (982°C to 1,010°C) purely to soften the cold-worked matrix without dissolving carbides.  Full annealing is the standard condition for Inconel 600 mill products supplied per ASTM B168 and ASTM B166.
  • Stress Relief Annealing: Stress relief annealing at 1,550°F to 1,650°F (843°C to 899°C) for 1 to 4 hours reduces fabrication-induced residual stresses from cold forming, machining, and welding without fully dissolving grain boundary carbides or significantly changing grain size. The treatment lowers residual stress levels by 50% to 70%, reducing stress corrosion cracking susceptibility in components that cannot tolerate the full dimensional change associated with high-temperature annealing.
  • Bright Annealing: Bright annealing replicates full annealing conditions (1,700°F to 1,900°F / 927°C to 1,038°C) in a controlled hydrogen or dissociated ammonia atmosphere, preventing surface oxidation during the heat treatment cycle and producing a clean, oxide-free surface finish. The process is specified for thermocouple sheath tubing, food processing equipment, and nuclear components where post-anneal pickling or chemical cleaning introduces dimensional tolerance risk or surface contamination concerns.
  • Carbide Stabilization Treatment: For components intended for long-term service from 1,000°F to 1,400°F (538°C to 760°C) where sensitization is a risk, a stabilization treatment at 1,600°F to 1,700°F (871°C to 927°C) for 4 to 8 hours promotes uniform, discrete carbide precipitation rather than continuous grain boundary films. The discrete carbide distribution reduces the chromium depletion zone width at grain boundaries, improving intergranular corrosion resistance in service without requiring the rapid quench step of full annealing.
Can Inconel 600 Be Hardened through Heat Treatment?
No, Inconel 600 can not be hardened through heat treatment. The alloy relies entirely on solid-solution strengthening, where chromium (14% to 17%) and iron (6% to 10%) atoms dissolved in the nickel FCC matrix impede dislocation movement and increase yield strength. No age-hardening or precipitation-hardening response exists in Inconel 600 because the alloy contains no aluminum, titanium, or niobium at concentrations sufficient to form γ′ (Ni₃Al) or γ″ (Ni₃Nb) precipitate phases, the strengthening particles responsible for hardening in Inconel 718, Inconel 713, and other precipitation-hardenable nickel alloys. Room-temperature hardness of Inconel 600 in the annealed condition ranges from 120 HB to 160 HB and increases to 200 HB to 300 HB only through cold work (cold rolling, drawing, or swaging) that introduces work hardening through dislocation multiplication. Heat treatment above 1,600°F (871°C) reverses cold work hardening by recrystallizing the deformed grain structure, returning hardness to the annealed baseline of 120 HB to 160 HB. Nickel alloys with precipitation hardening capability, including Inconel 718 (180 ksi to 220 ksi tensile strength after aging) and Inconel X-750 (155 ksi to 175 ksi after aging), are the appropriate substitutes when heat-treatable strength above 100 ksi is required.
What Are the Limitations of Inconel 600?
The limitations of Inconel 600 are listed below.
  • Susceptibility to Pitting and Crevice Corrosion in Seawater: Inconel 600 lacks molybdenum, limiting its pitting resistance equivalent number (PREN) to 14 to 17 compared to Inconel 625's PREN of approximately 50. The alloy experiences accelerated pitting corrosion in seawater and chloride brines at temperatures above 140°F (60°C), making it unsuitable for offshore platform heat exchangers, desalination equipment, and marine heat transfer applications where Inconel 625 or Hastelloy C-276 is specified.
  • Limited Resistance in Strongly Oxidizing Acid Environments: Inconel 600 corrodes at unacceptable rates in concentrated nitric acid (above 10% concentration), hot sulfuric acid (above 50% concentration at temperatures above 150°F / 66°C), and mixed oxidizing acid streams. Corrosion rates in 10% nitric acid at 212°F (100°C) exceed 0.05 inches per year, disqualifying the alloy from nitric acid plant construction where 304L stainless steel or specialized nitric-acid-grade stainless steels are preferred.
  • Sensitization Risk at 1,000°F to 1,400°F (538°C to 760°C): Extended service or slow cooling through the 1,000°F to 1,400°F (538°C to 760°C) temperature range precipitates chromium carbide (Cr₂₃C₆) at grain boundaries, depleting chromium in adjacent zones below 10% and creating susceptibility to intergranular corrosion. Components welded without post-weld annealing and placed in service in corrosive environments are at elevated risk of intergranular attack in the heat-affected zone.
  • Lower Strength than Precipitation-Hardened Nickel Alloys: The solid-solution strengthening mechanism limits room-temperature tensile strength to 80 ksi to 100 ksi (552 MPa to 689 MPa), approximately 50% to 55% of the tensile strength achievable in precipitation-hardened Inconel 718 (180 ksi to 220 ksi). Applications requiring tensile strength above 100 ksi at temperatures below 1,300°F must specify Inconel 718, Inconel X-750, or Waspaloy rather than Inconel 600.
  • High Material Cost Relative to Stainless Steel: Inconel 600 carries a material cost premium of 4 to 6 times the cost of austenitic stainless steel 316L on a per-pound basis, with plate pricing ranging from [$15] to [$25] per pound compared to [$3] to [$5] per pound for 316L stainless steel. The cost premium requires engineering justification through lifecycle cost analysis demonstrating that extended service life, reduced maintenance frequency, and avoided failure costs offset the higher initial material expenditure.
Is Inconel 600 Suitable for Extreme Corrosion Environments?
Inconel 600 is suitable for extreme corrosive environments but reaches performance limits in strongly oxidizing acid systems, seawater at elevated temperatures, and mixed acid environments where molybdenum-bearing alloys provide substantially superior resistance. The alloy performs reliably in caustic alkalis (sodium hydroxide from 10% to 70% concentration), organic acids (acetic, fatty, and naphthenic acids), chloride-bearing environments at pH above 7, and sulfur-containing reducing gas atmospheres up to 1,800°F (982°C). Corrosion rates in caustic soda at 50% concentration and 300°F (149°C) remain below 0.005 inches per year, confirming long-term suitability in evaporator and digester service. Performance decreases in three specific aggressive environments. Concentrated nitric acid above 10% produces corrosion rates above 0.05 inches per year, requiring substitution with 304L stainless steel or a specialized high-chromium stainless steel. Seawater at temperatures above 140°F (60°C) initiates pitting corrosion within 6 to 18 months of exposure due to the alloy's PREN of approximately 14 to 17, insufficient to suppress chloride-driven pit initiation in stagnant or low-flow conditions. Hydrofluoric acid at any concentration attacks Inconel 600 at unacceptable rates, as nickel fluoride film formation is non-protective in concentrated HF environments above 1% concentration. For the most aggressive corrosion environments combining oxidizing and reducing species, Hastelloy C-276 (15% to 17% molybdenum, PREN approximately 70) provides substantially superior resistance across all three failure-prone environment categories, where Inconel 600 reaches its corrosion resistance limits.
