Nylon 12 (PA12): Properties, Density and Melting Point
Written byMegan Conniff
23 min read
Published June 22, 2026Updated October 30, 2026
Nylon 12 (PA12). Image credit: Shutterstock/Copy.photograpy
Nylon 12 (PA12) is a semi-crystalline aliphatic polyamide engineering thermoplastic produced through the ring-opening polymerization of laurolactam, a 12-carbon cyclic monomer derived from butadiene. The Nylon 12 identifies the 12 carbon atoms in the monomer unit, producing the longest standard carbon chain among common nylon grades and directly determining the material's flexibility, low moisture absorption, and chemical resistance.
The key properties of Nylon 12 include tensile strength from 45 MPa to 55 MPa, elongation at break from 200% to 300%, and a density of 1.01 g/cm³ to 1.02 g/cm³, making it the lightest commercially available engineering polyamide. The melting point ranges from 175°C to 180°C, and continuous service temperature spans from -40°C to 100°C in standard grades. Moisture absorption at equilibrium measures 0.25% to 0.9% at 23°C and 50% relative humidity, the lowest value among all standard nylon grades, preserving dimensional stability and mechanical properties in humid environments where PA6 and PA6/6 absorb 2.5% to 3.5%. Nylon 12 serves automotive fuel and brake lines, pneumatic tubing, electrical cable jacketing, selective laser sintering (SLS) powder beds, medical device components, oil and gas flexible pipes, powder coatings, and sporting equipment across industries requiring a flexible, chemically resistant, low-moisture engineering polymer.
What Is Nylon 12 (PA12)?
Nylon 12 is a semi-crystalline aliphatic polyamide produced by ring-opening polymerization of laurolactam, yielding a linear polymer chain with the repeat unit formula (C₁₂H₂₃NO)ₙ and one amide group separated from the next by 11 methylene (-CH₂-) units. The 12-carbon chain architecture places Nylon 12 at the flexible, low-polarity end of the polyamide family, producing properties distinct from shorter-chain grades at equivalent processing conditions. The material achieves a melting point from 175°C to 180°C, a glass transition temperature of approximately 35°C to 50°C depending on measurement method, and a density from 1.01 g/cm³ to 1.02 g/cm³. Crystallinity degree ranges from 20% to 30% under standard processing conditions, with the amorphous phase contributing flexibility and impact resistance across a service temperature range from -40°C to 100°C continuously. Nylon 12 serves demanding applications in automotive fluid lines, offshore flexible pipes, SLS additive manufacturing, and medical device components because no equivalent nylon grade simultaneously delivers the same combination of low moisture absorption, flexibility at sub-zero temperatures, and chemical resistance to hydrocarbons and aggressive fluids.
How Is Nylon 12 Classified Among the Different Types of Nylon?
Nylon 12 is classified as a single-number aliphatic polyamide within the nylon family, derived from one monomer (laurolactam) rather than the diamine-diacid monomer pairs that produce double-number nylons such as Nylon 6/6 or Nylon 6/10. Single-number nylons, including Nylon 6, Nylon 11, and Nylon 12, form through ring-opening or condensation polymerization of a single amino acid or lactam monomer, with the number identifying carbon atoms per repeat unit. Nylon 12 sits alongside Nylon 11 at the most flexible end within the flexibility-stiffness spectrum of the nylon family, both sharing long methylene chain segments that reduce amide group density compared to Nylon 6 or Nylon 6/6. Nylon 12 carries one additional carbon per repeat unit compared to Nylon 11, producing a slightly lower melting point of 175°C to 180°C versus 183°C to 190°C and a marginally lower moisture absorption of 0.25% versus 0.9%. The full comparison of grades, processing methods, and performance trade-offs across the polyamide family appears in the Types of Nylon resource covering all commercial nylon classifications.
Is Nylon 12 a Form of Polyamide?
Yes, Nylon 12 is a form of polyamide. The material contains repeating amide linkages (-CO-NH-) throughout its molecular backbone formed during ring-opening polymerization of laurolactam, satisfying the chemical definition of polyamide under IUPAC nomenclature. ISO and DIN standards designate the material as PA12, where PA identifies the polyamide classification, and 12 specifies the 12-carbon monomer chain. The polyamide designation carries regulatory and engineering significance beyond naming. Material specifications for automotive fuel systems, offshore flexible pipes, and medical device components reference PA12 explicitly, excluding other polyamide grades not validated for the application. Every property associated with polyamide behavior in Nylon 12, including hydrogen bonding capacity between amide groups, hydrolytic susceptibility under prolonged water or acid exposure, solubility in polar solvents such as formic acid, and semicrystalline morphology, derives directly from the amide bond chemistry repeated throughout the polymer chain.
What is the Difference Between Polyamide vs. Nylon?
The difference between Polyamide vs. Nylon is shown in the table below.
How Does Polyamide Compare to Nylon 12 in Structure and Use?
The comparison of polyamide and nylon 12 in structure and use is listed below.
  • Backbone Chemistry: The polyamide family includes both aliphatic and aromatic backbone structures, while Nylon 12 contains exclusively aliphatic methylene chains connecting amide groups. Aramid polyamides achieve tensile strength above 3,000 MPa through aromatic ring stiffness unavailable in any nylon grade, including Nylon 12.
  • Monomer Source: Nylon 12 derives from laurolactam, a petrochemical monomer from butadiene, while the broader Polyamide Definition encompasses naturally occurring amide-bonded proteins (silk, wool) and bio-based synthetic grades alongside petroleum-derived nylons.
  • Industrial Applications: Nylon 12 serves flexible tubing, SLS additive manufacturing, automotive fluid lines, and medical components at service temperatures from -40°C to 100°C. Aromatic polyamides serve ballistic protection and high-temperature filtration at continuous temperatures from 180°C to 220°C, where Nylon 12 would melt.
  • Processing Methods: Nylon 12 processes through injection molding, extrusion, SLS sintering, and powder coating at melt temperatures from 200°C to 220°C. Aromatic polyamides require solution spinning or high-temperature processing incompatible with standard thermoplastic equipment.
Are Polyamide and Nylon the Same Material?
No, polyamide and nylon are not the same material, though every nylon qualifies as a polyamide. Polyamide is the broader chemical classification defined by repeating amide linkages (-CO-NH-) in the polymer backbone, encompassing synthetic engineering plastics, aromatic high-performance fibers, and naturally occurring protein structures. Nylon is restricted to synthetic aliphatic polyamides, excluding aramids and natural amide-bonded polymers. The terms are used interchangeably when referring to PA6, PA6/6, PA11, and PA12 because all qualify as both nylon and polyamide simultaneously in industrial practice. The distinction matters when comparing standard nylon grades to aramid polyamides or interpreting material specifications that use the polyamide designation in its full chemical scope. A data sheet listing only polyamide without specifying backbone type or carbon chain number requires clarification before Nylon Properties comparisons with specific grades, such as PA12, are technically valid.
What Are the Key Properties of Nylon 12?
The key properties of Nylon 12 are listed below.
  • Tensile Strength: Nylon 12 achieves tensile strength from 45 MPa to 55 MPa at room temperature, providing structural reliability in tubing, hose, and functional additive manufacturing parts without reinforcement in standard grades.
  • Elongation at Break: Elongation reaches 200% to 300%, placing Nylon 12 among the most flexible semi-crystalline engineering polyamides for tubing, hose, and SLS part applications requiring deformation tolerance.
  • Moisture Absorption: Equilibrium moisture absorption of 0.25% to 0.9% at 23°C and 50% relative humidity is the lowest among all standard nylon grades, preserving dimensional accuracy and mechanical properties in humid or wet environments.
  • Service Temperature Range: Continuous service spans from -40°C to 100°C in standard grades, with heat-stabilized grades extending short-term resistance to 120°C.
  • Chemical Resistance: Nylon 12 resists hydrocarbons, fuels, oils, greases, hydraulic fluids, and many solvents, with validated compatibility in automotive fuel systems and offshore hydrocarbon fluid contact applications.
  • Density: Density from 1.01 g/cm³ to 1.02 g/cm³ makes Nylon 12 the lightest standard engineering polyamide, reducing component weight in aerospace, automotive, and wearable medical device applications.
  • Impact Resistance: Notched Izod impact strength from 4 kJ/m² to 10 kJ/m²  at room temperature, with toughness retained at -40°C, distinguishing Nylon 12 from stiffer polyamide grades that embrittle at sub-zero temperatures.
How Do Nylon 12 Material Properties Support 3D Printing?
Nylon 12 material properties support additive manufacturing by combining low moisture absorption, consistent melt behavior, and sintered part toughness, which make PA12 powder the dominant material in selective laser sintering production. Moisture absorption of 0.25% to 0.9% reduces hygroscopic swelling in stored powder, maintaining particle flowability and laser sintering consistency across build jobs without the aggressive drying cycles required for PA6 or PA6/6 powders. Melting point from 175°C to 180°C and a narrow melting range allow SLS systems to maintain the powder bed at 168°C to 172°C, only 5°C to 10°C below the melt onset, producing dense sintered parts with porosity below 2% at standard laser power and scan speed parameters. Sintered PA12 parts achieve tensile strength from 45 MPa to 50 MPa and elongation from 10% to 20% in the build direction, suitable for functional prototypes, end-use brackets, ducts, and enclosures. The full range of polymer powder and filament options for additive manufacturing appears in the 3D Printing guide covering process selection and material performance.
Is Nylon 12 Strong Enough for Functional Parts?
Yes, Nylon 12 is strong enough for functional parts in molded and additive-manufactured forms. Tensile strength from 45 MPa to 55 MPa in injection-molded Nylon 12 covers structural requirements for fluid line fittings, connector housings, sensor brackets, and mechanical enclosures operating under moderate loads at temperatures from -40°C to 100°C. Sintered PA12 parts from SLS processes achieve tensile strength from 45 MPa to 50 MPa and elongation from 10% to 20%, meeting functional requirements for air ducts, cable management components, medical device housings, and automotive interior brackets without post-processing reinforcement. Glass-fiber-reinforced Nylon 12 grades reach tensile strength from 100 MPa to 130 MPa and flexural modulus from 4,000 MPa to 6,000 MPa, extending the material's functional range into load-bearing structural applications requiring stiffness beyond the unfilled grade. Impact resistance retained at -40°C confirms suitability for outdoor and cold-environment functional parts where competing polymers embrittle and fracture under dynamic loading.
What Is the Density of Nylon 12?
Nylon 12 has a density of 1.01 g/cm³ to 1.02 g/cm³ in unfilled grades, representing the lowest density value among all standard commercial polyamide grades. The low density results directly from the long 12-carbon methylene chain between amide groups, which reduces the proportion of heavier polar amide groups per unit volume of polymer compared to shorter-chain nylons. Glass-fiber-reinforced Nylon 12 grades increase density to 1.07 g/cm³ to 1.23 g/cm³, depending on fiber content from 10% to 30% by weight, while mineral-filled grades reach 1.30 g/cm³ to 1.50 g/cm³. Carbon-fiber-reinforced Nylon 12 achieves densities from 1.10 g/cm³ to 1.20 g/cm³ with tensile strength from 150 MPa to 200 MPa, combining low weight with high stiffness for aerospace and motorsport bracket applications. SLS-sintered PA12 powder parts measure bulk density from 0.93 g/cm³ to 0.97 g/cm³ due to residual porosity from 4% to 8% in the sintered structure, slightly below the solid injection-molded value.
How Does Nylon 12 Density Affect Weight and Design?
Nylon 12 density of 1.01 g/cm³ to 1.02 g/cm³ affects weight and design compared to denser engineering polymers and metals at equivalent geometry, enabling lighter assemblies in automotive, aerospace, medical, and wearable device applications where mass reduction improves fuel efficiency, portability, or patient comfort. A Nylon 12 fluid line weighs approximately 11% less per unit length than an equivalent PA6 line at 1.13 g/cm³ and 12% less than PA6/6 at 1.14 g/cm³ at identical wall thickness and outer diameter. The weight difference accumulates significantly in automotive underhood harnesses carrying 50 to 150 individual fluid and pneumatic lines per vehicle. Low density also benefits SLS additive manufacturing design by reducing part mass without requiring wall thickness reduction, maintaining structural cross-sections while staying within weight budgets for aerospace brackets and UAV components. Designers specify Nylon 12 over denser alternatives (POM at 1.41 g/cm³ or PEEK at 1.32 g/cm³) when weight reduction and chemical resistance must coexist at moderate structural load requirements.
Is Nylon 12 Considered a Lightweight Engineering Plastic?
Yes, Nylon 12 is considered a lightweight engineering plastic. It carries the lowest density among standard polyamide grades and competes directly with other lightweight engineering polymers, including polypropylene (PP) at 0.90 g/cm³ to 0.91 g/cm³ and polyethylene (HDPE) at 0.94 g/cm³ to 0.97 g/cm³, while delivering substantially higher tensile strength, chemical resistance, and service temperature performance than either commodity polymer. The lightweight classification is reinforced by Nylon 12's specific strength, defined as tensile strength divided by density, reaching 44 MPa·cm³/g to 54 MPa·cm³/g in unfilled grades. Carbon-fiber-reinforced Nylon 12 raises specific strength to 130 MPa·cm³/g to 180 MPa·cm³/g, placing it within the performance range relevant to structural Engineering Plastic applications in aerospace and motorsport, where weight reduction per unit strength determines material selection.
What Is the Melting Point of Nylon 12?
The melting point of Nylon 12 is 175°C to 180°C, measured by differential scanning calorimetry (DSC) at standard heating rates of 10°C per minute. The melting point is the lowest among major commercial nylon grades, falling below Nylon 11 at 183°C to 190°C, Nylon 6 at 220°C, and Nylon 6/6 at 260°C to 265°C, a direct consequence of the longer 12-carbon chain reducing amide group density and intermolecular hydrogen bonding strength. The narrow melting range of approximately 5°C to 8°C from onset to peak is especially significant for SLS powder bed processing, where the powder bed temperature is maintained just below the melt onset to prevent premature sintering while keeping the powder ready for rapid laser fusion. Heat-stabilized Nylon 12 grades for injection molding and extrusion retain dimensional stability to 100°C continuous and 120°C short-term without reaching the melt transition, confirming a 75°C to 80°C margin from service temperature to melting point in standard applications.
How Does Nylon 12 Melting Temperature Impact Processing?
Nylon 12's melting temperature of 175°C to 180°C determines the processing window for injection molding, extrusion, and SLS sintering, with each method exploiting the low melt onset to reduce energy consumption and thermal degradation risk compared to higher-melting polyamide grades. Injection molding of Nylon 12 uses melt temperatures from 200°C to 230°C, approximately 30°C to 50°C above the melting point, maintaining adequate melt flow without exceeding the thermal degradation threshold above 260°C. Mold temperatures from 30°C to 80°C control crystallization rate and surface quality in molded parts. Extrusion of Nylon 12 tubing and filament uses barrel temperatures from 190°C to 230°C, with die temperatures set 5°C to 10°C above barrel exit temperature to maintain consistent melt viscosity at the die land. SLS processing exploits the narrow melt range by maintaining the powder bed at 168°C to 172°C, enabling rapid laser fusion of individual layers at scan speeds from 2,000 mm/s to 6,000  mm/s while the surrounding unfused powder remains solid and provides self-supporting geometry during the build.
Does Nylon 12 Require High Heat to Melt?
No, Nylon 12 does not require high heat to melt relative to other engineering polyamides. The melting point from 175°C to 180°C is the lowest among standard nylon grades and requires processing temperatures from 200°C to 230°C in injection molding and extrusion, compared to 260°C to 290°C for Nylon 6/6 and 230°C to 260°C for Nylon 6. The lower processing temperature reduces energy consumption per kilogram of processed material, shortens cycle time by allowing faster mold cooling from a lower melt temperature, and reduces thermal degradation risk during processing. Equipment rated for standard thermoplastic processing handles Nylon 12 without the high-temperature barrel and nozzle specifications required for Nylon 6/6. SLS powder sintering of PA12 operates at bed temperatures from 168°C to 172°C, well within the capability of standard commercial SLS platforms without specialized high-temperature build chamber modifications.
How Is Nylon 12 Used in Nylon 3D Printing Filament?
Nylon 12 is used in nylon 3D printing filament through SLS powder and FDM filament in additive manufacturing, with PA12 powder representing the dominant SLS material globally and PA12 filament offering durable, flexible parts in FDM systems capable of reaching 250°C to 270°C nozzle temperatures. PA12 powder with particle size distributions from 40 µm to 100 µm sinters at bed temperatures from 168°C to 172°C under CO₂ laser energy, producing parts with tensile strength from 45 MPa to 50 MPa, elongation from 10% to 20%, and density from 0.93 g/cm³ to 0.97 g/cm³. PA12 accounts for over 90% of all polymer SLS production volume globally due to its processing consistency, mechanical performance, and powder recyclability at refresh rates from 30% to 50%. PA12 FDM filament at diameters of 1.75 mm or 2.85 mm prints functional parts with tensile strength from 40 MPa to 50 MPa at nozzle temperatures from 240°C to 260°C, requiring an enclosure and dry storage below 15% relative humidity. The complete guide to polymer additive manufacturing options appears in the 3D Printing Filament resource, covering material selection and process parameters.
Why is Nylon 12 Popular in Nylon 3D Printing Applications?
Nylon 12 is popular in nylon 3D printing applications because its narrow melting range, low moisture absorption, consistent powder flowability, and sintered part toughness combine into a processing and performance profile no other standard polyamide powder matches at equivalent cost and availability. The narrow melting range from 175°C to 180°C allows SLS systems to maintain a tight powder bed temperature window of 4°C to 6°C below the melt onset, producing dense, well-fused parts across the entire build volume without hotspot sintering or insufficient fusion at the bed periphery. Low moisture absorption of 0.25% to 0.9% reduces the drying requirement for stored powder compared to PA6 or PA6/6, maintaining particle morphology and flow characteristics critical to consistent layer spreading at 100 µm to 120 µm layer thickness. Sintered PA12 parts achieve elongation from 10% to 20% in the build direction, making them suitable for snap-fit assemblies, living hinges, flexible ducts, and functional brackets that brittle polymer powders (polystyrene or PEEK) cannot produce at equivalent layer thickness and build speed.
Is Nylon 12 Filament Suitable for Durable Prototypes?
Yes, Nylon 12 filament is suitable for durable prototypes in both FDM and SLS additive manufacturing processes. FDM-printed PA12 parts achieve tensile strength from 40 MPa to 50 MPa and elongation from 15% to 30%, exceeding the strength of standard PLA prototypes at 37 MPa to 45 MPa while adding flexibility and impact resistance that PLA cannot deliver. SLS-sintered PA12 prototypes reach tensile strength from 45 MPa to 50 MPa and impact resistance from 40 kJ/m² to 60 kJ/m², qualifying them as functional prototypes and low-volume end-use parts for automotive clips, pneumatic fittings, consumer device housings, and medical equipment brackets. Chemical resistance to fuels, oils, and cleaning agents allows Nylon 12 prototypes to undergo functional testing in actual fluid-contact conditions that polycarbonate or ABS prototypes cannot withstand without surface degradation or structural compromise over repeated exposure cycles.
What Are the Main Uses of Nylon 12?
The main uses of Nylon 12 are listed below.
  • 3D Printing Parts: PA12 powder dominates SLS additive manufacturing globally, producing functional parts with tensile strength from 45 MPa to 50 MPa and elongation from 10% to 20% for automotive, medical, and industrial applications.
  • Automotive Fuel and Brake Lines: Nylon 12 tubing carries gasoline, diesel, and vapor emissions at pressures from 10 bar to 40 bar and temperatures from -40°C to 100°C in underhood automotive systems meeting SAE J2260 standards.
  • Electrical and Cable Insulation: Nylon 12 jacketing protects electrical conductors in industrial wiring harnesses, subsea cables, and automotive wire bundles with abrasion resistance at Shore D hardness from 60 to 70.
  • Medical Device Components: Nylon 12 produces catheter shafts, drug delivery tubing, and diagnostic device housings requiring biocompatibility, flexibility, and sterilization resistance in ISO 10993-compliant applications.
  • Industrial Tubing and Pneumatic Systems: Nylon 12 pneumatic tubing operates at 10 bar to 16 bar in factory automation and compressed air systems at bend radii from 4 to 6 times the outer diameter.
  • Consumer Goods and Sporting Equipment: Nylon 12 appears in ski boot shells, cable ties, eyeglass frames, and sporting equipment requiring low-temperature toughness from -40°C to 60°C.
  • Powder Coating Applications: Nylon 12 powder coatings apply at substrate temperatures from 260°C to 300°C in thicknesses from 200 µm to 500 µm, providing corrosion and impact protection on metal substrates.
  • Oil and Gas Components: Nylon 12 lines flexible risers and flowline systems in offshore production, achieving service lives exceeding 20 years under API 17J standards in hydrocarbon fluid contact at pressures from 50 bar to 1,000 bar.
1. Nylon 12 Used for 3D Printing Parts
PA12 powder is the dominant material in selective laser sintering globally, accounting for over 90% of polymer SLS production volume due to its consistent powder flowability, narrow melting range from 175°C to 180°C, and sintered part mechanical performance. Parts produced from PA12 SLS achieve tensile strength from 45 MPa to 50 MPa, elongation from 10% to 20%, and impact resistance from 40 kJ/m² to 60 kJ/m², meeting functional requirements for automotive brackets, pneumatic fittings, medical housings, and industrial ducts without secondary infiltration or coating. Powder refresh rates from 30% to 50% new powder per build maintain sintering consistency across production batches on EOS, Farsoon, and equivalent platforms operating at bed temperatures from 168°C to 172°C.
2. Nylon 12 Used for Automotive Fuel and Brake Lines
Nylon 12 single-layer and multilayer tubing carries gasoline, ethanol blends to E85, and diesel in automotive underhood systems at pressures from 10 bar to 40 bar and service temperatures from -40°C to 100°C. SAE J2260 standards govern fuel line permeation resistance and pressure retention requirements, with Nylon 12 meeting Class A fuel system specifications at wall thicknesses from 0.8 mm to 2.0 mm and outer diameters from 6 mm to 25 mm.  The material's chemical resistance to ethanol blends and low moisture absorption of 0.25% to 0.9% preserves line integrity and dimensional stability across the vehicle service life, exceeding 150,000 km.
3. Nylon 12 Used for Electrical and Cable Insulation
Nylon 12 jacketing on electrical conductors provides abrasion resistance at Shore D hardness from 60 to 70, chemical resistance to oils and fuels, and flexibility at -40°C in automotive wiring harnesses, industrial control cables, and subsea umbilical systems. Jacket wall thicknesses from 0.3 mm to 2.0 mm cover light flexible signal cables to heavy power and control cables deployed in offshore environments at water depths exceeding 3,000 meters. The material's low dielectric constant from 3.0 to 3.5 at 1 MHz and volume resistivity above 10¹⁴ Ω·cm support electrical insulation performance in low-frequency insulation and protective mechanical jacketing applications.
4. Nylon 12 Used for Medical Device Components
Nylon 12 produces catheter shafts, balloon inflation tubing, drug delivery line components, and diagnostic device housings requiring flexibility, kink resistance, and biocompatibility in ISO 10993-compliant applications. The material passes cytotoxicity, sensitization, and intracutaneous reactivity testing under ISO 10993-5 and ISO 10993-10 protocols in medical-grade formulations free of plasticizers and processing aids incompatible with body fluid contact. Catheter shaft outer diameters from 1 mm to 10 mm at wall thicknesses from 0.1 mm to 0.5 mm are achievable by precision extrusion of medical-grade PA12 compounds with dimensional tolerances of ±0.025 mm maintained across production runs.
"When designing parts for SLS or underhood automotive environments, you cannot treat a material data sheet like a menu of absolute truths: real-world performance depends heavily on processing variables like residual porosity and heat stabilization. A successful design engineer looks beyond nominal data sheet numbers and embeds manufacturing realities directly into their geometric tolerances and wall thicknesses. Ultimately, understanding how a polymer behaves on the shop floor is what prevents costly structural failures before a tool is ever cut."
5. Nylon 12 Used for Industrial Tubing and Pneumatic Systems
Nylon 12 pneumatic tubing serves compressed air and inert gas distribution in factory automation, robotics, and process control at working pressures from 10 bar to 16 bar and temperatures from -40°C to 100°C. Minimum bend radii from 4 to 6 times the outer diameter allow compact routing in multi-axis robot arms and tight enclosures without kinking or flow restriction. Outer diameters from 4 mm to 16 mm in metric and inch sizes cover standard push-to-connect pneumatic fitting dimensions across European and North American automation platforms, with pressure ratings maintained across temperature cycles from assembly at -40°C ambient to full operating load at 80°C.
6. Nylon 12 Used for Consumer Goods and Sporting Equipment
Nylon 12 serves ski boot shells, snowboard bindings, eyeglass frames, cable ties, zip ties, and sporting equipment requiring low-temperature impact resistance, dimensional stability, and surface quality at -40°C to 60°C service conditions. Ski boot shells molded from Nylon 12 compounds maintain flex stiffness and fracture resistance at -20°C, where ABS or polycarbonate shells embrittle under impact. Eyeglass frame production uses injection-molded Nylon 12 for its combination of flexibility, low density at 1.01 g/cm³ to 1.02 g/cm³, and surface finish quality achievable with standard mold surface treatments without secondary painting or coating.
7. Nylon 12 Used for Powder Coating Applications
Nylon 12 powder coatings apply to steel, aluminum, and cast iron substrates through fluidized bed dipping at preheat temperatures from 260°C to 300°C, producing adherent coatings from 200 µm to 500 µm thick. The coating provides impact resistance exceeding 140 kg·cm by ASTM D2794, salt spray corrosion resistance exceeding 1,000 hours by ASTM B117, and chemical resistance to oils, fuels, and alkaline cleaning solutions on valve bodies, pipe fittings, hand tools, and food processing equipment. Particle size distributions from 80 µm to 250 µm serve fluidized bed dipping at preheat temperatures from 260°C to 300°C as well as electrostatic spray application onto cold substrates followed by post-heating.
8. Nylon 12 Used for Oil and Gas Components
Nylon 12 lines flexible risers, flowlines, and umbilical systems in offshore oil and gas production as the internal pressure sheath contacting produced fluids including crude oil, natural gas, water, and injection chemicals at operating pressures from 50 bar to 1,000 bar. API 17J and API 17B standards govern flexible pipe design requirements, with PA12 liners validated for service lives exceeding 20 years in continuous hydrocarbon contact at temperatures from 60°C to 100°C. Offshore installations in the North Sea, Gulf of Mexico, and Brazilian pre-salt fields specify Nylon 12 internal sheaths in flexible risers from 500 m to over 3,000 m in length, connecting subsea wellheads to floating production platforms.
What Are the Advantages of Using Nylon 12?
The advantages of using Nylon 12 are listed below.
  • Lowest Moisture Absorption Among Nylons: Equilibrium moisture absorption of 0.25% to 0.9% preserves dimensional tolerances and mechanical properties in humid or wet environments, where PA6 and PA6/6 absorb 2.5% to 3.5% and lose stiffness proportionally.
  • Exceptional Flexibility: Elongation from 200% to 300% and impact resistance retained at -40°C cover flexible tubing, hose, cable jacketing, and SLS part applications requiring large deformation tolerance across wide service temperature ranges.
  • Lowest Density Among Standard Nylons: Density from 1.01 g/cm³ to 1.02 g/cm³ reduces component weight in automotive, aerospace, and wearable medical device applications compared to all other commercial polyamide grades.
  • Excellent Chemical Resistance: Resistance to hydrocarbons, fuels, oils, hydraulic fluids, and many solvents supports 20+ year validated service life in offshore flexible riser liners and automotive fuel system tubing under continuous fluid contact.
  • Superior SLS Processing Performance: Narrow melting range, consistent powder flowability, and sintered part toughness make PA12 the dominant SLS powder material globally, covering over 90% of polymer SLS production volume.
  • Wide Service Temperature Range: Continuous operation from -40°C to 100°C without mechanical property collapse covers automotive, industrial, marine, and outdoor consumer applications with specialized thermal stabilizer grades.
  • Versatile Processing Methods: Nylon 12 processes through injection molding, extrusion, SLS sintering, FDM filament printing, and fluidized bed powder coating, covering precision tubing, structural moldings, additive parts, and metal substrate protection in a single material platform.
