CapabilitiesCustom Online 3D Printing ServiceStereolithography (SLA) 3D Printing Service
High-Resolution Prototypes in Days
Free shipping on all US 3D printing orders
  • Materials
  • Applications and Benefits
  • Sizes and Tolerances
  • About SLA
  • Download Guide
High-Resolution, Accurate Parts without Tooling
Stereolithography (SLA) is a powerful 3D printing technology that produces extremely accurate and high-resolution parts that are capable of being used directly in end-use, low-volume production or for rapid prototyping. Xometry offers over 15 uniquely engineered SLA materials that can enable products to be brought to the market.
    Stereolithography Materials
    SLA Materials Available at Xometry:
    Material NameDescriptionFlexural Strength (MPa/KSI)Elongation at Break (%)HDT@0.46 MPa (°C)Data Sheets
    Material Name
    Accura 25
    Description
    White, PP-like
    58 MPa/KSI
    20%
    HDT@0.46 MPa (°C)
    63 °C
    Data Sheets
    Material Name
    Accura ClearVue
    Description
    Clear/Translucent, PC-like
    67 MPa/KSI
    7%
    HDT@0.46 MPa (°C)
    46 °C
    Data Sheets
    Material Name
    Somos WaterShed XC 11122
    Description
    Clear/Translucent, ABS-like
    69 MPa/KSI
    15%
    HDT@0.46 MPa (°C)
    50 °C
    Data Sheets
    Material Name
    Somos EvoLVe 128
    Description
    White, ABS-like
    70 MPa/KSI
    11%
    HDT@0.46 MPa (°C)
    52 °C
    Data Sheets
    Material Name
    Accura Xtreme Grey
    Description
    Grey, ABS-like
    71 MPa/KSI
    22%
    HDT@0.46 MPa (°C)
    62 °C
    Data Sheets
    Material Name
    Somos NeXt
    Description
    White, PP-like
    71 MPa/KSI
    10%
    HDT@0.46 MPa (°C)
    57 °C
    Data Sheets
    Material Name
    Somos Taurus
    Description
    Dark Gray, ABS-like
    74 MPa/KSI
    24%
    HDT@0.46 MPa (°C)
    62 °C
    Data Sheets
    Material Name
    Accura ABS Black (SL 7820)
    Description
    Black (painted), ABS-like
    78 MPa/KSI
    13%
    HDT@0.46 MPa (°C)
    51 °C
    Data Sheets
    Material Name
    Accura Xtreme White 200
    Description
    White, ABS-like
    79 MPa/KSI
    20%
    HDT@0.46 MPa (°C)
    47 °C
    Data Sheets
    Material Name
    Somos WaterClear Ultra 10122
    Description
    84 MPa/KSI
    7%
    HDT@0.46 MPa (°C)
    47 °C
    Data Sheets
    Material Name
    Accura 60
    Description
    101 MPa/KSI
    13%
    HDT@0.46 MPa (°C)
    55 °C
    Data Sheets
    Material Name
    Somos PerFORM*
    Description
    White, Ceramic-filled
    146 MPa/KSI
    1%
    HDT@0.46 MPa (°C)
    268 °C
    Data Sheets
    Material Name
    Accura Bluestone*
    Description
    Blue, Ceramic-filled
    154 MPa/KSI
    2%
    HDT@0.46 MPa (°C)
    284 °C
    Data Sheets
    *Requires post-thermal curing to achieve HDT.
    Available Finishes for SLA Printed Parts
    SLA mixed materials with matte finish
    Matte (Standard)
    Supported surfaces will be lightly sanded with 220 or 320 grit sandpaper, then media blasted for a uniform matte finish.
    Natural
    SLA stereolithography natural finish
    Supported surfaces will be lightly sanded with 220 or 320 grit sandpaper for improved surface quality. Sanding scratches will be visible on supported surfaces.
    Strip and Ship
    SLA part with supports removed
    Supported areas may show small grid-like dots or surface blemishes as a result of support removal.
    Quick Clear
    SLA Accura ClearVue Quick Clear finish
    Available for Accura ClearVue. Only supported surfaces are sanded. Parts will still have visible layering.  High gloss clear coat is applied to enhance natural clarity.
    Custom
    SLA nickel plated finish
    Xometry provides additional SLA finishing options, including but not limited to sanding, polishing, painting, post thermal processing, and plating to meet your needs.
    Applications of Stereolithography (SLA) 3D Printing
    Concept models
    Concept Models
    The speed, accuracy, and great surface finish of SLA parts lets product developers create physical snapshots of their designs through the iterative process.
    Fast parts and fast shipping
    SLA prototyping is a fully-functional prototype, with materials that can simulate polypropylene, polycarbonate, ABS, and rigid composites.
    Digital manufacturing
    Direct Digital Manufacturing
    The high accuracy and consistency of SLA makes it an ideal way to build large quantities of discrete or customized parts.
    Benefits of SLA 3D Printing
    SLA is a go-to choice for 3D printed models that require accurate features and a smooth surface finish. Xometry's stereolithography 3D printing service offers both standard and high-resolution options for fine detail parts, and can also print larger sized parts and products, offering up to a 29" inch build area. With the ability to produce complex features with good mechanical properties, an SLA 3D print is often used for final fit checks before moving to injection molding services.
    In addition, Xometry's manufacturing partner network allows us to offer a larger variety of materials than other 3D printing companies - we offer a wide range of both Accura and Somos brand materials.
    • Outstanding surface finish and post processing options
    • Tight tolerances and high detail precision
    • Complex shapes with a high degree of precision
    • High selection of engineered materials
    SLA machine 3D printing black parts using a UV laser
    SLA General Tolerances
    DescriptionStandard ResolutionHigh Resolution
    Description
    Build envelope
    Standard Resolution
    29” x 25” x 21”
    High Resolution
    10” x 10” x 10”
    Description
    Layer height
    Standard Resolution
    0.004"
    High Resolution
    0.002"
    Description
    Tolerance, XY Plane
    Standard Resolution
    +/- 0.005” for the first inch is typical, plus +/- 0.002” for every inch thereafter.
    High Resolution
    Description
    Tolerance, Z Plane
    Standard Resolution
    +/- 0.010” for the first inch is typical, plus +/- 0.002” for every inch thereafter.
    High Resolution
    Description
    Minimum linear feature size
    Standard Resolution
    Under 0.030” are at risk and under 0.020” will not build.
    High Resolution
    Under 0.020” are at risk and under 0.010” will not build.
    Description
    Minimum radial feature size
    Standard Resolution
    0.035"
    High Resolution
    0.030"
    The table below depicts the general tolerances for industrial-grade stereolithography (SLA) services. Stresses during the build, support strategy, and other geometry considerations may cause deviation in tolerances and flatness. Improved tolerances may be possible with a manual quote review, after successful completion of a prototype build, and must be approved on a case-by-case basis. General tolerances apply before secondary finishing or post-processing unless otherwise specified. Please check out Xometry's Manufacturing Standards for more information on tolerances per process.
    3D Printed Parts
    Overview: What is Stereolithography (SLA) 3D printing?
    How Stereolithography Works
    The stereolithography process is an additive manufacturing process that uses ultraviolet (UV) light on a vat of liquid photopolymer resin to selectively solidify part features, building the part layer by layer. The UV light continues this process through the entire vat of resin, selectively curing and solidifying the resin to match the design of the CAD file. Support structures are created during the pre-build setup process and manually removed after the print is completed. The parts are then washed in a solvent solution to remove uncured resin, and then receive a final post-cure in a UV light oven.
    Xometry's SLA printing service offers higher resolution printing than many other 3D printing technologies, allowing customers to print parts with fine details and surface finishes. SLA 3D printing is a highly-versatile platform for making custom parts in prototype and production settings, often acting as a stand-in for injection molded parts.
    With a broad range of suitable materials and a rapid turnaround for even complex net-shapes, SLA technology is an ideal tool for a broad range of manufacturing sectors. It is primarily used in auto-engineering, as it enables the cost-effective generation of intricate parts with various surface finishes and fine detailing. Parts can be embossed or engraved, with matte, natural, and myriad other finishes available depending on the manufacturing requirements. While its primary success has been in rapid, functional prototyping and design assistance for the automotive sector, stereolithography is rapidly being adopted at scale in various mechanical modeling sectors.
    Stereolithography SLA 3D printing services
    Why Choose Xometry for 3D Printing?
    Isometric illustration of the stereolithography (SLA) printing process.
    Download the SLA design guide
