Waterjet Metal Cutting
Water jet, also known as waterjet or abrasive jet cutting, is one of Xometry's machining processes that directs a high-pressure jet of water and an abrasive substance to cut materials for industrial applications such as machine part manufacturing. Modern water jet cutters are controled by CNC (Computer Numerical Control) systems runing G-code to position the water jet nozzle and increase accuracy. Important benefits of water jet cutting with an abrasive substance include the ability to cut metals without increasing the material surface temperature and compromising internal structure of the material (no Heat Affected one, or HAZ); the ability to cut sharp corners, holes, and complex shapes with small inner radii; fast turn-around rates; and minimal material waste thanks to the precise cutting and the narrowness of the nozzle.
Xometry's Manufacturing Partner Network offers water jet cutters with tilting waterjet nozzles with 4- or 5-axis CNC control at accuracy up to 0.1 mm that can cut metal sheets and plates up to 4 inches thick. For thinner and softer materials, laser cutting might be more appropriate.
XOMETRY’S WATERJET CUTTING
  • Tilting waterjet head with 4 or 5-axis CNC control
  • High accuracy, up to 0.1mm
  • Cut more than 4″ sheet/plate metal
Get an Instant Quote
Sheet Metal Design Guide
Sheet metal fabrication is a process by which parts are cut and bent from a roll of stock metal material. It can be a very cost-effective way to make straightforward metal parts. Check out our design for tips on how to optimize your files for sheet metal!
Download your free guide for more design tips and information on material selection and whether to choose laser cutting or waterjet cutting.
Download Guide
Manufacturing On Demand
Massive scale when you need it
We integrate seamlessly with over 1000 vetted manufacturing partners in the US including ITAR qualified facilities. You are no longer subject to the limits of your existing local suppliers. Dynamically scale your manufacturing capacity when you need the flexibility. And Xometry guarantees your custom parts will be built to your specifications.
Extensive capabilities on one platform
Xometry’s Partner Network offers wide-ranging capabilities from CNC Machining, industrial-grade 3D Printing, Sheet Metal, Urethane Casting, and production-grade Injection Molding. All just a click away.
Fast lead times, low prices, & lightning-fast quoting
Xometry gives you instant pricing, lead times, and DFM on materials and manufacturing processes for your custom parts. Our proprietary pricing engine uses Machine Learning to analyze 3D CAD drawings and provide instant feedback on pricing, lead times, and the best process to make your custom parts. We turn around Injection molding within 24 hours.
back to Sheet Metal Fabrication
