CapabilitiesCustom Online 3D Printing ServiceNexa3D LSPc® Resin 3D Printing Service
Blazing Fast Parts Made From Production Photopolymers
Free Shipping on All US Orders
  • Gallery
  • Materials
  • Design Tips
  • Applications and Benefits
  • Sizes and Tolerances
  • About LSPc®
New!
Blazing Fast Prototypes and Production Parts without Tooling
Nexa3D's Lubricant Sublayer Photo-curing (LSPc®) technology provides extremely fast and accurate 3D printing, making it suitable for low volumes to production quantities. Get parts made from a wide selection of materials, including ones that emulate ceramic and rubbers to engineered functional resins for medical, dental, and commercial industries. Xometry’s supplier network utilizes the NXE 400Pro and XiP Pro production printers and the XiP desktop printer for low-volume and prototype work.
In addition to traditional printed prototypes, Nexa3D LSPc® and its advanced resins can produce end-use parts, making it a great alternative to urethane casting or low-volume injection molding.
    LSPc Materials Gallery
    xMODEL17
    Translucent prototypes or production parts
    xFLEX402
    Durable rubber-like materials
    xESD
    Static dissipative materials
    xCERAMIC3280
    Ceramic-filled material is porcelain-stiff and temperature resistant
    xPEEK147
    High temperature materials (HDT of 238°C)
    xFLEX475
    Soft rubber-like materials
    Nexa3D LSPc® Materials
    LSPc® Materials Available at Xometry:
    Material NameDescriptionTensile Strength (MPa)Elongation at Break (%)HDT at 0.45 MPa (°C)Data Sheets
    Material Name
    xMODEL17 Clear
    Description
    Clear/Translucent prototyping resin
    30 MPa
    22%
    47°C
    Data Sheets
    Material Name
    3843-xABS Black
    Description
    Engineering grade, ABS-like
    32± 1 MPa
    50%
    56°C
    Data Sheets
    Material Name
    xESD
    Description
    Engineering grade, static-dissipative (10^7 Ω)
    68.1 MPa
    3.8%
    91.3°C
    Data Sheets
    Material Name
    xPP405 Black
    Description
    Engineering grade, black PP-like
    35 ±2 MPa
    100%
    52.8°C
    Data Sheets
    Material Name
    xPEEK147
    Description
    Engineering grade, High temp (HDT 238C)
    75 ±2.0 MPa
    3%
    238°C
    Data Sheets
    Material Name
    xFLEX402
    Description
    Semi-firm rubber-like elastomer (Shore A 73)
    5.5 MPa
    230%
    (Unavailable)
    Data Sheets
    Material Name
    xFLEX475 Black
    Description
    Soft, high-rebound, rubber-like elastomer (Shore A 44)
    2.48 ±0.3 MPa
    150%
    (Unavailable)
    Data Sheets
    Material Name
    xFLEX475 White
    Description
    Soft rubber-like elastomer (Shore A 55)
    3.8 ±0.8 MPa
    159%
    (Unavailable)
    Data Sheets
    Material Name
    xCERAMIC3280
    Description
    Ceramic composite-filled resin, Highly stiff
    85 MPa
    1.2%
    205°C (278°C After Post-Thermal Cure)
    Data Sheets
    More LSPc® materials are available; select "Other" when quoting for custom requests!
    Available Finishes for Nexa3D LSPc® Parts
    Matte
    Our default finish. The supported surfaces will be lightly sanded with 220 or 320 grit sandpaper, then media blasted for a uniform matte finish.
    Natural
    Supported surfaces will be lightly sanded with 220 or 320 grit sandpaper for improved surface quality. Sanding scratches will be visible on supported surfaces.
    Strip and Ship
    Supported areas may show small grid-like dots or surface blemishes as a result of support removal.
    Custom
    Xometry provides additional finishing options, including but not limited to sanding, polishing, painting, post thermal processing, and plating to meet your needs.
    Design Tips for LSPc
    LSPc Resin 3D Printing Design Best Practices
    FeatureRecommended Size - Any Material (mm)xPEEKxABS, xPPxFLEX (elastomers)
    Feature
    Wall Thickness
    1-5 mm
    xPEEK
    0.3-25 mm
    xABS, xPP
    0.6-25 mm
    xFLEX (elastomers)
    0.5-50 mm
    Feature
    Gap Clearance
    0.5 mm
    xPEEK
    0.5 mm
    xABS, xPP
    0.5 mm
    xFLEX (elastomers)
    0.5 mm
    Feature
    Minimum Features, Extrude
    0.5 mm
    xPEEK
    0.3 mm
    xABS, xPP
    0.6 mm
    xFLEX (elastomers)
    0.8 mm
    Feature
    Minimum Features, Hole
    1 mm
    xPEEK
    0.3 mm
    xABS, xPP
    0.5 mm
    xFLEX (elastomers)
    0.6 mm
    Feature
    Hole Depth
    <3x Diameter (blind), <8x Diameter (thru)
    xPEEK
    <10x Diameter (blind), <25x Diameter (thru)
    xABS, xPP
    <8x Diameter (blind), <25x Diameter (thru)
    xFLEX (elastomers)
    <4x Diameter (blind), <12x Diameter (thru)
    Feature
    Text
    0.4-0.8mm depth, >4mm height
    xPEEK
    0.2-1.5mm depth, 2.5mm height
    xABS, xPP
    0.2-1.5mm depth, 2.5mm text height
    xFLEX (elastomers)
    Feature
    Unsupported angle
    >30°
    xPEEK
    >5°
    xABS, xPP
    >10°
    xFLEX (elastomers)
    >40°
    Feature
    Unsupported overhang
    <2mm
    xPEEK
    <4mm
    xABS, xPP
    <3mm
    xFLEX (elastomers)
    <2mm
    Feature
    Unsupported span
    <5mm
    xPEEK
    <20mm
    xABS, xPP
    <15mm
    xFLEX (elastomers)
    <8mm
    Source: Nexa3D
    Thin wall on a block
    Top 5 Design Tips for Nexa3D LSPc
    We've compiled our top design tips for Nexa3D's LSPc® 3D printing process. Keep reading to learn more about the guidelines you need to keep in mind to succeed with LSPc® technology!
    Read the Full Case Study
    Applications for Nexa3D LSPc® Technology
    Ultrafast Printing
    LSPc® technology is the fastest in it's category, enabling rapid prototyping and production quantities
    Engineering Grade Materials
    Choose from a wide selection of materials designed for end-use including rigid composites, rubber-like elastomers, and specialty options
    Direct Digital Manufacturing
    LSPc® technology provides accurate parts from low volume to production quantities, making it a cost-effective alternative to traditional molding or casting processes
    Benefits of LSPc® 3D Printing
    The speed and efficiency of Nexa3D's LSPc® 3D printing process make it an excellent solution for quickly iterating designs and producing pieces in higher quantities. A host of carefully selected and engineered printing resins allows components to exhibit unique properties and withstand end-use applications and environments. LSPc® printed parts demonstrate high resolution, detail, dimensional accuracy, and excellent surface finish.
    With LSPc®, the number of parts does not affect the printing speed of each layer. This makes it particularly advantageous for printing high quantities of smaller pieces in a short amount of time. Simple post-processing procedures and swappable build trays in platforms like Nexa3D's XiP printer allow further production efficiency. LSPc® can act as a great bridge between initial production and higher quantity production solutions such as our injection molding service.
    • Ultrafast printing speeds
    • Wide range of engineered materials
    • High dimensional accuracy and detailed resolution
    • Smooth natural surface finish
    • End-use parts in high quantities
    Timelapse demonstrating the Nexa3D LSPc 3D printing process
    Nexa3D LSPc® General Tolerances
    DescriptionTolerance Notes
    Description
    Tolerance, XY Plane
    Tolerance Notes
    +/- 0.005” for the first inch is typical, plus +/- 0.002” for every inch thereafter
    Description
    Tolerance, Z Plane
    Tolerance Notes
    +/- 0.010” for the first inch is typical, plus +/- 0.002” for every inch thereafter
    Description
    Layer Height
    Tolerance Notes
    100 µm / 0.004 in
    Description
    Ideal Part Size
    Tolerance Notes
    Part's below 2" x 1" x 3" or smaller tend to have the best production economy of scale.
    Description
    Build Volume
    Tolerance Notes
    Up to 10.8 x 6.1 x 15.7 in
    Description
    Minimum Wall Thickness
    Tolerance Notes
    0.030" or larger is suggested for any walls, text, or lattice features.
    Description
    Pixel Size
    Tolerance Notes
    52µm - 76.5µm
    This table depicts the general tolerances for LSPc®. Stresses during the build, support strategy, and other geometry considerations may cause deviation in tolerances and flatness. Improved tolerances may be possible with a manual quote review, after the successful completion of a prototype build, and must be approved on a case-by-case basis. General tolerances apply before secondary finishing or post-processing unless otherwise specified. Please check out Xometry's Manufacturing Standards for more information on tolerances per process.
    Overview: What is Nexa3D LSPc® Technology?
    LSPc stands for Lubricant Sublayer Photo-curing, which can be categorized as a type of mSLA (masked stereolithography apparatus) printing process. This type of printing technology uses an LED (light-emitting diode) array as a light source and an LCD (liquid crystal diode) photomask to selectively shape image layers. The images pass through a membrane on which layers of photopolymer resin are cured. As each layer is cured, the build platform moves up, the resin is replenished, and the next layer begins to set, building up parts over time. The key to Nexa3D's LSPc technology is their proprietary Everlast membrane designed to minimize peel and separation forces during printing. The specialized membrane is chemically inert, flexible, and does not rely on oxygen-permeable elements for lubricity. This enables LSPc technology to print in a wide range of resins with unparalleled speed and efficiency.
    After printing, the parts are washed to remove uncured resin and receive a final post-cure in a UV light oven. Nexa3D's open material platform has a host of engineered resins, most of which do not require any additional post-processing steps other than the standard UV cure to achieve final part properties. While similar technologies and their materials, such as Carbon DLS™, may require and benefit from additional processing steps, they can lead to longer post-processing times and higher material costs. The efficiency and simplicity of post-processing LSPc® parts is another factor that makes this technology advantageous for high-volume 3D printing and a potential substitute for other production methods such as urethane casting or quick-turn molding.
      Components that make up LSPc printing technology
      Why Choose Xometry for Your Production Needs?
      Ready to Start Your Project?
      Free shipping available; learn more!
