CapabilitiesCustom Die Casting Services
High Quality Die Cast Metal Parts.
  • What is Die Casting?
  • Die Casting With Xometry
  • Types of Die Casting
  • Materials
  • Finishes
  • Applications
  • Advantages & Disadvantages
  • Why Xometry?
New!
Die Casting Process
Our project managers and experts personally review and manually quote each die casting project to ensure we meet your unique needs while providing a fast and easy manufacturing experience. Learn more about the process and our capabilities in the sections below.
Xometry's Die Casting Service
Start A Quote
Sample Approval
Production Begins
Hot Chamber Die Casting
Cold Chamber Die Casting
Die Cast Metal Materials
Aluminum Die Casting
  • Withstand high operating temperatures
  • Corrosion Resistance
  • Good stiffness
  • High thermal and electrical conductivity
  • A360.0
  • A380.0
  • A383.0 (ADC12)
  • A413.0
Zinc Die Casting
  • Impact strength
  • High hardness
  • Great stability
  • High-quality surface finish and easily plated
  • Low melting point
  • Zamak 2 (ZA-2)
  • Zamak 3 (ZA-3)
Available Die Casting Finishes
Standard (As-Cast)
Bead Blasted
Powder Coating
Wet Painting
Plating
Chemical Film
Media Tumbled
Custom
Isometric illustration of the die casting process.
Applications of Die Casting
  • Aerospace & Automotive Components
  • Connector Housings
  • Pumps and Plumbing Fixtures
  • Outdoor lighting
  • Gears
  • Appliances and Lighting
Die cast metal parts
Advantages of Die Casting
Complex Geometry
Strength
Precision
Custom Finishes
Disadvantages of Die Casting
Tooling Cost
Not for Low Quantities
Lead Times
New!
Built-In Tool Management
Xometry's platform has built-in features that make managing tooled projects a breeze, giving customers greater transparency into production. Find all your tooling quotes and orders in one space with your Tool Library. From there, you can explore their Tool Details page, which covers the current status, milestones, tool specifics, and activity related to that tool. You can also easily find and contact the Xometry team member assigned to your project, no matter the project's current phase.
Our Tool Library and Tool Details pages provide multiple benefits, such as:
  • Better Management of Tooled Quotes & Orders
  • Tool Organization & Categorization
  • Detailed Status Updates & Tooling Information
  • Easily Connect with Experts
  • Project Transparency
