CapabilitiesLaser Tube Cutting Services
Xometry provides tube laser cutting for metal rectangular, square, and round tubes.
  • Laser Tube Cutting Overview
  • Sizes and Tolerances
  • Shapes and Materials
  • Tube Cutter Types
  • Advantages & Disadvantages
  • Why Xometry
New!
Overview
Laser tube cutting is the process by which tube stock material is selectively cut to form various shapes, holes, designs, and/or channels using a controllable precision laser. The stock material (tube/pipe) is held in a controllable lathe, where the tube will rotate in line with the design specifications as the laser makes cuts. Laser tube cutting can create through-holes of any shape as small as the wall thickness of the material and is also often used to cut channels that allow for easy bending and welding of the tube for angled tubing.
Xometry offers an extensive range of laser tube cutting services with instant online pricing, DFM, and lead times. Laser types utilized include fiber laser or CO2 lasers, depending upon the material and application, allowing for very tight tolerances and the ability to cut through wall thicknesses up to 1/2“. Using Xometry’s online quote engine, it is simple to start a quote for your next laser tube cutting project, upload your 3D CAD, and select from our drop-downs to create your quote.
Our project managers and experts are here to assist you along the way with any questions or concerns, ensuring we meet your unique needs while providing a fast and easy manufacturing experience.
    laser tube cutting
    Our laser tube cutting service can cut round, square, or rectangular tubes with a variety of sizes and wall thicknesses. Kerf sizes vary based on the specific material, laser type, laser power, and operation parameters but are overall much thinner than traditional cutting methods, reducing material waste.
    Review Xometry's Standard Tube Sizes for a comprehensive list of available tube stock.
    • Minimum round outer diameter: .500"
    • Maximum round outer diameter: 6.000"
    • Minimum square or rectangle dimension: .500"
    • Maximum square or rectangle dimension: 6.000"
    • Minimum wall thickness: .035"
    • Maximum wall thickness: .500"
    Tolerances are outlined in Xometry's Manufacturing Standards for Tube Cutting
    • Cut Type: Normal-to-Surface
    • Edge-to-Edge Tolerances: +/- .010” nominal on the inner face of the tube.
    • Minimum feature size: Generally no larger than the tube thickness.
    Laser tube cutting systems have settings for handling tubes of various shapes and profiles. These include round, square, and rectangular tubes.
    The following materials are available for tube cutting.
    • Stainless Steel: 304 and 316 Welded and Seamless
    • Aluminum 6061 Extruded and Drawn
    • Alloy Steel 4130 Seamless
    • Steel A513 DOM, HREW, and CREW
    Laser Tube Cutting Material Options
    Standard Profile and Material Options for Laser Tube Cutting Services
    MaterialRound TubeRectangular TubeSquare Tube
    Material
    Round Tube
    • 6061, Extruded
    • 6061, Drawn
    Rectangular Tube
    • 6061, Extruded
    Square Tube
    • 6061, Extruded
    Material
    Stainless Steel
    Round Tube
    • SS 304, Welded
    • SS 304, Seamless
    • SS 316, Welded
    • SS 316, Seamless
    Rectangular Tube
    • SS 304, Welded
    • SS 316, Welded
    Square Tube
    • SS 304, Welded
    • SS 316, Welded
    Material
    Alloy Steel
    Round Tube
    • Steel A513 Type 1, HREW
    • Steel A513 Type 2, CREW
    • Steel A513 Type 5, DOM
    • Steel 4130 (Chromoly), Seamless
    Rectangular Tube
    • Steel A513
    • Steel 4130 (Chromoly), Cold Drawn Seamless
    Square Tube
    • Steel A513
    See our standard tube sizes page for more details.
    Isometric illustration of the laser tube cutting process.
    Types of Laser Tube Cutters
    Advantages and Disadvantages
    Here are the advantages of the laser tube cutting process:
    • Semi-to-fully automated process with high throughput.
    • Low/no material wastage.
    • Offers highly complex, clean, and repeatable cuts.
    • Works with nearly every metal.
    • Most/nearly all tube stock up to 6" is accepted.
    The disadvantages or limitations of laser tube cutting include the following:
    • Some cut materials may show a small halo discoloration from the backsplash or overspray near the cut edges.
    • A small bump of material or a different edge condition may be present at the lead-in and lead-out in a cutting profile.
    • The process is generally reserved for thin-walled materials less than 0.500"-1.000" thick.
    Why Choose Xometry for Tube Laser Cutting?
    Access the capacity of hundreds of laser tube cutting suppliers through our easy-to-use platform.
    We are ISO 9001:2015, ISO 13485, IATF 16949:2016, and AS9100D certified. Only the top shops that apply to become network suppliers make it through our qualification process.
    Expert help
    Our team of Solutions Engineers and Process Specialists are available to support you and provide answers to all of your fabrication and manufacturability questions.
    Related Capabilities
    Tube Bending Services
    Xometry offers precision tube bending services for round metal tube stock to meet your needs.
    Upload your CAD files to get an instant online fabrication quote on custom formed sheet metal prototypes and production parts. Lead times as fast as days and free standard shipping on all US orders.
    Sheet Cutting Services
    Upload your CAD files to get an instant quote for laser cutting or waterjet cut prototypes and production parts. No minimums. Get parts in days and free standard shipping on all US orders.
    Welder is welding a flange assembly. Image Credit: Shutterstock.com/Chumphon_TH
    Custom Online Weldment Services by Xometry
    High quality custom weldment services available with a variety of materials, manufacturing processes, finishes, and more. Subject to availability. Xometry doesn't guarantee that we can provide this service at any given time.
