CapabilitiesSheet Metal Fabrication Services
Upload your CAD files to get an instant online fabrication quote on custom formed sheet metal prototypes and production parts. Lead times as fast as days and free standard shipping on all US orders.
  • Sizes and Tolerances
  • How It Works
  • Materials
  • Finishes
  • Design Guide
  • Design Guidelines
  • Applications
  • Why Xometry?
  • Customer Examples
Sheet Metal Fabrication with Xometry
Sheet metal fabrication is a subtractive manufacturing process that forms parts from thin metal sheets. Engineers often choose sheet metal parts for their high precision and durability, especially for end-use applications like chassis, enclosures, and brackets.
Xometry’s online sheet metal fabrication services provide a fast and cost-effective solution for any parts that need to be made from 3D CAD files or engineering drawings. Xometry offers a range of sheet metal materials, including aluminum, copper, steel, and stainless steel, as well as assembly services like installing PEM inserts, welding, and finishing services. With a network of domestic and overseas fabricators, Xometry can supply any quantity of sheet metal parts from low-volume, high-mix prototypes to high-volume production runs. Xometry offers competitive, custom sheet metal fabricating prices for low-volume prototypes and cost savings for high-volume production runs.
    Sheet Metal Services Available at Xometry
    Upload your CAD files for an instant quote for laser cutting or waterjet cut prototypes and production parts. No minimums. Get parts in days and free standard shipping on US and international orders.
    Laser Cutting
    High-quality Laser Cut Parts in Days | Free Standard Shipping on All US Orders
    Waterjet Cutting
    Instant Quotes and Cost-effective, On-demand Fabrication | Free Standard Shipping on All US Orders
    Xometry Capability
    Metal Stamping Services
    Xometry Sheet Metal Fabrication Capabilities
    FeatureDescription
    Feature
    Blank Size
    Description
    5’ x 10’ (1.52 m x 3.05 m). We accommodate larger part volumes upon request.
    Feature
    Standard Lead Time
    Description
    3 business days
    Feature
    Sheet Thickness
    Description
    0.024” - 0.250” typical. We accommodate thicker or thinner gauges upon request.
    Feature
    Tight Tolerances
    Description
    We offer auto-quoting for tolerances as tight as +/- 0.005". Tighter tolerances are available upon manual review.
    Feature
    General Tolerances
    Description
    See our Sheet Metal manufacturing standards for details on general tolerances and standards.
    Feature
    Braking (Hydraulic)
    Description
    14′ length
    Feature
    Braking (Magnetic)
    Description
    6 tons of magnetic pull across the entire beam, 5/8″ minimum reverse bend
    Feature
    Description
    2″ diameter hole capacity, or larger upon request
    Feature
    Description
    Welded edges and seams, weldments, and assemblies
    This table depicts the general tolerances for Xometry’s sheet metal services. Learn more about our sheet metal manufacturing standards.
    What is Sheet Metal Forming?
    Sheet stock is procured in a flat state and cut then formed into its final state through a series of progressive steps. For a typical sheet metal project, the first step is equivalent to sheet cutting, where a shear, laser, waterjet, plasma, or punch press is used to create the internal holes and edge features of the part. This process is also known as blanking.
    Once the blank is produced, the next step is to form sheet metal using various tools, but most commonly some sort of brake. A brake press can be manual or automated and uses die inserts to create a desired angular bend, forming the two-dimensional sheet into a three-dimensional object. Sheet metal forming can bend the part in multiple directions, creating simple parts such as brackets up to highly complex geometries which may require custom die tools. Once the tools are in place, making subsequent sheet parts in production is very cost-effective. This makes sheet metal fabrication and forming ideal for low to high volume production.
      How Xometry Sheet Metal Fabrication Works
      Xometry makes sheet metal fabrication simple. Just upload your bent sheet metal design to the Xometry Instant Quoting Engine® to get started. We automatically calculate pricing and lead times for virtually endless part configurations, including those with tight tolerances as tight as +/- 0.005", inserts, welding, and finishing requirements. When you place your order, we will utilize our diverse manufacturing network to find the right supplier for the job. In a matter of days, your custom sheet metal parts will be delivered to your door.
      The efficiency and high precision of sheet metal fabrication, coupled with Xometry’s variety of materials, range of sheet metal fabricators, and post-processing options, means you can get parts for any application. We regularly serve aerospace, defense, automotive, energy, industrial, medical, dental, and consumer product industries.
      A bent aluminum part demonstrating ductility
      Sheet Metal Materials Available at Xometry
      Aluminum 1100-H14
      Aluminum 5052-H32
      Aluminum 6061
      Learn more about aluminum sheet metal.
      Copper
      Copper 101
      Copper C110
      Copper C110, H02
      Copper 260 (Brass)
      Learn more about copper sheet metal.
      Bronze
      Bronze 220
      Bronze 510
      Learn more about bronze sheet metal.
      Stainless Steel
      Stainless steel 301
      Stainless steel 304
      Stainless Steel 304 #4 brushed
      Stainless Steel 304, #8 mirror polish
      Stainless steel 316/316L
      Stainless Steel 316, #4 brushed
      Steel
      Steel 1018 (Low Carbon)
      Steel 1045 (Hot Rolled)
      Steel A569/ASTM A1011 (Hot Rolled)
      AZ55 Galvalume
      A653 Galvanized
      1095 Spring Steel
      Steel A36
      Steel A36, pickled and oiled
      Steel A366/1008
      Nickel Alloys
      Inconel 625
      Nickel Alloy 200
      Nickel Alloy 400
      Titanium
      Titanium (Grade 2)
      Titanium 6AI-4V (Grade 5)
      Standard Sheet Thicknesses
      Various material finishes are available for an instant online sheet metal quote. If you do not see the material finish combination you are looking for, please choose "Other" under the finish drop-down on your quote page and submit for an expert engineering review once you have specified features, tolerances, inspection needs, and quantities required.
      Check out our finishing galleries to see examples of our standard finishes.
        Standard
        Bead Blast
        Anodize (Type II Or Type III)
        Type II (MIL-A-8625/MIL-PRF-8625, Type II) creates a corrosion-resistant finish. Sheet metal parts can be anodized in different colors—clear, black, red, and gold are most common—and are usually associated with aluminum. Type III (MIL-A-8625, Type III, Class 1/2 "hardcoat") is thicker and creates a wear-resistant layer in addition to the corrosion resistance seen with Type II.
        Powder Coat
        This is a sheet metal fabrication process where powdered paint is sprayed onto a part that is then baked in an oven. This creates a strong, wear- and corrosion-resistant layer that is more durable than standard painting methods. A wide variety of colors are available to create the desired aesthetic. See examples of our options in our powder coating finishes gallery.
        Electroless Nickel Plating
        A sheet metal fabrication process that provides uniform nickel coating which offers protection from corrosion, oxidation, and wear on irregular surfaces. The finished part will be brighter. Thickness starts at .0001” and this finish conforms to MIL-C-26074.
        Gold Plating
        Silver Plating
        Get In-Depth Tips With Our Design Guide
        Sheet Metal Design Guidelines
        FeatureDescription (MT = Material Thickness)
        Feature
        Minimum Bend
        1X MT
        Feature
        Minimum Hole to Edge Distance
        2X MT
        Feature
        Minimum Hole to Hole Distance
        6X MT
        Feature
        Minimum Bend Edge to Hole Distance
        6X MT
        Feature
        Minimum Feature to Countersink Distance
        8X MT
        Feature
        Minimum Countersink Depth
        0.6X MT
        Feature
        Relief Cuts
        1X MT
        Feature
        Corner Fillets
        0.5X MT
        To see more design-for-manufacturing recommendations, view our Sheet Metal Fabrication Design Guide.
        Applications and Advantages of Sheet Metal Fabrication
        Laser cutting metal sheet
        Rapid Tooling
        Sheet Metal
        End-Use Production
        Ready to Get a Sheet Metal Fabrication Quote?
        Free shipping available for domestic sheet metal orders ; learn more!
        Why Use Xometry's Sheet Metal Fabrication Services?
        Choose from thousands of possible combinations of sheet metal materials, finishes, tolerances, markings, and certifications for your order.
        Examples of Our Sheet Metal Fabrication Work
        Article
        By Nathan Miller
        Article
        Asylon drone
        Article
        Zaiput flow machine
