Resources3D Printing DesignSLS vs. DMLS: What You Should Know About These 3D Printing Methods
Rebecca Piccoli headshot
Published July 15, 2022
Updated January 16, 2025
A closer look at commonly compared 3D printing technologies
Metal 3D printing. Image Credit: Shutterstock.com/MarinaGrigorivna
Juggling different 3D printing methods and determining which is right for the products you want to make isn’t easy. There are so many options, and it’s sometimes easiest to break it down by subcategory, whether by technology type or print attributes. That’s what we’re doing with SLS and DMLS printing. These two types of powder bed fusion methods work with different materials and don’t necessarily share the same benefits and disadvantages. Let’s get into it below.
"SLS or Selective Laser Sintering, is a polymer-based laser powder bed fusion process. DMLS or Direct Metal Laser Sintering is the metals side of laser powder bed fusion. The primary difference being metals and plastics."
Matt Schmidt,
Senior Solutions Engineer
What Is Selective Laser Sintering (SLS)?
SLS is a powder bed fusion technology that works with plastic powders and was originally developed in the mid-1980s. It’s often compared to other methods like FDM and, of course, DMLS. It uses one or two types of lasers, most usually a CO2 laser, to trace out the cross-section of a part and sinter the plastic particles together. Once every layer is formed, you have your final build. For a visual example, you can see a photo of one of our SLS machines at Xometry in action below.
An SLS 3D Printing Machine at Xometry
An SLS 3D printing machine at Xometry.
What Is Direct Metal Laser Sintering (DMLS)?
Like SLS, DMLS involves powder bed fusion tech and sintering, but it works with metals instead of plastics. It became a commercialized process back in 1995 and works by lasering metal powder particles together until every layer is complete. These printers also have a chamber that fills with inert gas to cut down on the possibility of combustion and oxidation. You can see a diagram showing the parts of a DMLS printer below.
DMLS Schematic
DMLS Schematic
Comparing These 3D Printing Processes
AttributeSLSDMLS
Attribute
Typical layer height
SLS
100–120 microns
DMLS
30–40 microns
Attribute
Typical tolerance standards
SLS
± 0.015” or ± 0.002" per inch — whichever is greater*
DMLS
+/- 0.005” for the first inch, plus +/- 0.002” for every inch that comes after
Attribute
Typical build volume
SLS
330 x 330 x 580 mm
DMLS
250 x 250 x 250 mm
Attribute
Minimum recommended feature size
SLS
1 mm
DMLS
0.5 mm
Attribute
Parts need support structures
SLS
No
DMLS
Yes
Attribute
Has isotropic material properties
SLS
Yes
DMLS
Yes
Attribute
Material types
SLS
Thermoplastics like polyamides and nylons, metal, ceramic, and glass
DMLS
Metals and alloys such as aluminum, copper, and stainless steel
Attribute
Print volume
SLS
Can print builds around 2 feet in length
DMLS
Smaller builds, around a 10-inch cube in size
Attribute
Can print in metal
SLS
No
DMLS
Yes
Attribute
Advantages
SLS
  • Cheaper for prototyping and testing out product forms
  • Parts don’t need supports for printing
  • Can be dyed different colors and vapor smoothed
  • Larger build volumes than DMLS printers
  • Can make more parts at once
DMLS
  • Can create high-strength parts with many different types of metals
  • Parts are super durable and have great chemical, mechanical, and thermal properties compared to SLS
  • Parts usually have better resolution than SLS parts
Attribute
Disadvantages
SLS
  • Limited to only working with plastics
  • Not as great of mechanical properties as DMLS parts
  • Parts are more prone to shrinking and warping
DMLS
  • DMLS tends to be more expensive because of its high material costs
  • DMLS prints need support structures during the build process
  • They have smaller build volumes
  • They also print smaller quantities than SLS machines
* The tolerances we’ve listed for SLS are when working with nylon 12 material, but tolerances will differ depending on what material you choose for printing.
Isometric illustration of the selective laser sintering (SLS) printing process.
Need metal or plastic 3D printed parts?
Alternative Methods
While SLS and DMLS have their fair share of perks, there are a couple of alternative printing options you can consider depending on the project you have in mind.
  • Multi-jet fusion (MJF): This is also a type of powder-bed fusion process (and one that we offer, too). MJF is a good alternative for SLS because it works with similar polyamide materials but uses a printer head that deposits the materials more like an inkjet printer as opposed to the laser that SLS uses.
  • Metal binder jetting: We also offer metal binder jetting, which also involves working with metal like DMLS. It also uses a print head to lay out a binding agent that fuses metal layers together, and then it’s left to cure and later sintered or infiltrated with bronze. It’s much cheaper than DMLS but has a higher chance of shrinkage and more pores (and often not as fine of features).
FAQs About SLS and DMLS
What are the costs for SLS and DMLS printing?
When you compare the prices of SLS and DMLS printing, you’ll find that DMLS is almost always more expensive than the former. This is because printing with metal powder is much more expensive than printing with other materials, like plastic.
How do the surface finishes compare between SLS and DMLS?
With both SLS and DMLS printing, you can expect pretty rough and matte surface finishes. DMLS tends to have a slightly smoother finish because of the finer layer height that the printer produces, but both will usually need post-processing done, whether through bead blasting, tumbling, or polishing.
You won’t be short of 3D printing options here at Xometry. Speak to our team for customized help or use our online quote generator to get pricing for metal 3D printing, carbon digital light synthesis, stereolithography, and more.
