ResourcesInjection MoldingEverything You Need to Know About Compression Molding
picture of Joel Schadegg
 9 min read
Published October 9, 2020
Updated August 12, 2024
From medical components to video games, here’s how it’s used
Compression molding. Image Credit: Shutterstock.com/Soon_Sound
Compression molding is used across many industries and is a popular choice among Xometry customers. Although it came onto the scene in 1905, it has held its ground over the years through all of our technological advances. There are still plenty of reasons why companies and manufacturers turn to it over other methods. It has proven to be a solid and reliable choice for making everything from dental devices to video game controllers. Up ahead, we’ll go into detail about how compression molding works, what it’s used for, and both its advantages and disadvantages.
What to Know About Compression Molding
Compression molding is a manufacturing process used to create plastic and composite parts. Through a mixture of heat and high pressure, it squeezes materials—like thermosetting polymers or thermoplastic compounds—into set shapes. It’s the heat and pressure that allows solid materials to soften and reform into new structures that are wholly even and cured. During the process, curing triggers a chemical reaction, which helps give the final product strength and durability.
The Importance of Compression Molding
This is one process that’s helpful when it comes to turning pre-impregnated intermediate products into semi-structural and structural composite components. It’s also key for developing fibrous materials that have been impregnated with thermoset and thermoplastic matrices. Not only that, but compression molding is a great process for companies looking to cut costs, minimize waste, and make numerous products. Compression molding is also better suited for manufacturing certain part geometries, such as thick walls.
compression molding diagram
Compression molding diagram
How the Compression Molding Process Works
There are a few steps in the compression molding process. Here’s how it works, according to our engineers:
Step 1: The first step in compression molding is creating the molds, which are responsible for shaping the end product. These are usually made of steel or aluminum and, once they’re put together, have a cavity, an upper mold, and a lower mold.
Step 2: After the mold is created, the machine is set up for the process. Users will clean the mold, input the settings, and turn on the heat. Keeping the temperature controlled is essential for preventing defects and warping.
Step 3: For thermosets, the next step involves placing a charge made of fiber-reinforced resin, silicone, or rubber into the cavity. The mold is then closed while heat, pressure, and speed settings are locked in to begin the molding process.
It’s slightly different for thermoplastics. For these materials, temperature-controlled cooling molds are used instead.
Step 4: Once the shapes are complete, they cool and any extra edges or excess material are removed. Altogether, the process can take 1 to 5 minutes, but it largely depends on how thick the parts are.
Learn more about Xometry's Molding Services
Equipment Used in the Process
These are the main components of a compression molding machine and the tools needed to fulfill the process:
  1. Large tonnage press. This is usually 150 tons to 2,500 tons.
  2. Heated mold. As mentioned earlier, the mold will have an upper and lower portion as well as an inner cavity. They’re designed to control the flow of material as it melts and reshapes into the new desired object.
  3. Heating chamber. This or an oven will be used to heat materials and get them to their molten state.
  4. Heating lines. These long and cylindrical electrical resistors are the primary heating elements.
  5. Shop air. This helps clean the cavity and gets rid of debris, particles, and contaminants from different parts of the machine.
  6. Cutting tools. These are used to manually cut away any leftover materials.
Materials Used in the Process
These are the most common materials used for compression molding and why they’re popular:
  1. Epoxy: These resins have superb mechanical properties, high heat resistance, and dimensional stability. When they melt down, they flow easily and evenly into the cavity. After it has cooled down, epoxy parts are known to be durable and strong. Because of this, the material is usually used for aerospace parts, electrical insulation, and structural composites.
  2. Silicone: This is another material with top-notch heat resistance. Silicone is also flexible and ideal for electrical insulation. Like epoxy, silicone also flows well into the cavity and has no problem properly molding into intricate shapes. This makes it a great material for precision seals, gaskets, medical devices, and automotive components.
  3. Melamine: For excellent heat and chemical resistance, many manufacturers rely on melamine. Its hardness and stability are key features, too. It molds easily and once it’s formed into the right shape, the finish makes it a winning choice. That’s why melamine is often used for home goods like kitchenware, heat-resistant utensils, and decorative laminates—but it’s also used for electrical components.
  4. Urethane: Also known as polyurethane, this material is strong and resistant to wear and tear. Like the other materials, urethane flows perfectly fine into the cavity, covering every nook and cranny. This makes it another great choice for more detailed designs like automotive parts, rollers, wheels, and industrial seals.
  5. High-Density Polyethylene (HDPE): This type of plastic is perfect for melting and molding. It offers fantastic chemical resistance, strength, and rigidity. On top of this, it’s capable of handling major impact, which is why it’s used for automotive components and industrial parts.
  6. Polyphenylene Sulfide (PPS): For electrical components, industrial equipment, and some automotive parts, manufacturers will often use PPS. This is because it flows well once it’s melted down but cools into a stiff but strong finish.
  7. Polytetrafluoroethylene (PTFE): You’ll likely recognize this material in the kitchen as it’s used to create non-stick surfaces. In compression molding it offers much of the same benefits—stability in high temperatures, chemical resistance, and a slick surface.
"Compression molding works really well for rubber products that have thicker or uneven walls--think insoles, phone cases, or silicone kitchen gadgets."
Greg Paulsen,
Applications of Compression Molding
Thanks to its customizable parts and settings and its flexibility with materials, compression molding spans many different industries. It has a lot of different uses, with just a small chunk of those listed below.
  • Kitchenware: The staples in your cooking space may exist thanks to compression molding. This process can make products like bowls, cups, plates, and utensils and create versions that are resistant to heat and breaks.The ever-popular melamine plates used for eating outdoors are often made this way.
  • Automotive parts: Both small and large components for vehicles like cars, trucks, and tractors can be made through compression molding. As examples, you can get door panels, dashboards, and parts for engines.
  • Electrical components: With the previous materials listed, it’s no surprise that compression molding can be used to make electrical components. Manufacturers can get precise shapes, reliable functionality, and consistency across the board.
  • Video games and computer devices: The devices we spend hours on wouldn’t function the same without the help of compression molding. This process can produce keypads for computers, video game controllers, and parts that provide electrical insulation.
  • Medical and dental components: You could probably name quite a few tools and devices your doctor and dentist rely on, but without some finer details and tiny components, they wouldn’t be usable! Compression molding can create plastic and silicone parts like syringe stoppers and pieces for respirator masks.
Case Study: Combating COVID-19 with a Contactless, AI-Based Thermal Imaging Device
Xometry manufactured various housings and mounts for X.Labs, a startup developing a thermal imaging device to identify individuals in a crowd with elevated temperatures, in just one month. The device comes at a pivotal moment in the COVID19 outbreak.
Read the Full Case Study
Advantages and Disadvantages
There are pros and cons to think about when you’re weighing up compression molding and other similar processes. Here are some of the advantages and disadvantages that Xometry makes their customers aware of when considering the process:
Advantages include:
  • Ultra-strong parts that last through immense wear and tear and heavy-duty use.
  • Molds are highly customizable and can be created for intricate designs or more basic styles.
  • Compression molding can handle various materials, including highly viscious materials, and therefore make a wide range of different products.
  • Molds are efficient when it comes to using material, which saves money in the long run.
  • The parts made from compression molds have excellent finishes.
  • Batch production is possible and users can create settings and cycles for maximum efficiency.
  • Compression molding machines can use recycled and eco-friendly materials—a perk for sustainably-minded companies.
Disadvantages include:
  • Complex parts are no problem, but intricate components with thin walls is a no-go.
  • Pressure range limits make it difficult to create detailed shapes
  • While it only takes a few minutes, compression molding is slower than other processes like injection molding.
  • The heat, pressure, and cooling process can lead to longer production times, too.
  • Flash can happen and create imperfect parts, wasting material, time, and resources.
The Future of Compression Molding
At Xometry, we have only seen demand for compression-molded products increase over time. The need for products that are produced through this method is increasing thanks to specific industries seeing a boom in growth—whether that’s new medical and dental developments or an influx of new car parts.
Machine learning, AI, and automated systems is also making compression molding simpler to execute. While the demand for compression molded products is growing, so are the available materials that can be used in these types of machines. With how easy it is to manufacture everyday items like dishes and more advanced components for a computer to function, it’s hard to see this manufacturing process winding down in the near future.
Compression vs. Injection Molding
Compression and injection molding are similar but have a few key differences. These can influence your decision when it comes to selecting the best process for the job. Compression molding uses heat and pressure to form a shape within the mold. Injection molding, as its name suggests, funnels or injects hot material into a closed mold.
Injection molding is better for objects that require intricate details (like threading or ribbing), thin walls, or complex parts. Compression molding wins out when it comes to thicker products needed for their strength, robustness, and durability. Overall, Injection molding processes tend to be quicker than compression processes.
Xometry provides a wide range of manufacturing capabilities, including injection molding and other value-added services for all of your prototyping and production needs. Get an instant quote today.
