ResourcesMaterialsComparing 18/8, 18/10, and 18/0 Stainless Steels
Published April 5, 2024
Updated October 28, 2024
Learn about the differences, similarities, and best uses of these three popular grades.
Stainless steel utensils. Image Credit: Shutterstock.com/Africa Studio
You have most likely encountered the 18/8, 18/10, and 18/0 grades of stainless steel more than you realize. These steels are used in everything from the pipes that may have brought you the water for your morning coffee to the teaspoon you use to stir it with. Needless to say, these are very valuable materials in the world of manufacturing and are some of the most popular among Xometry customers.
For a quick overview of the differences between these three grades, we’ve outlined what each stainless steel grade consists of chemically, what it’s great (and not-so-good) at, and the ways in which Xometry’s services can be beneficial to processing stainless steel for your own business.
What is 18/8 Stainless Steel?
This kind of stainless steel is a member of the 300 grouping, and its most common and popular grade is 304. Its name basically gives away its composition—it’s got around 18% chromium and 8% nickel. Also included is roughly 67% iron, and a tiny trace of carbon (about 0.07%). It’s also part of the austenitic steel family, meaning they have better corrosion resistance than other families of stainless steel and can’t be hardened through heat treatments. That being said, it falters slightly in corrosion resistance when it comes to sitting in or being constantly exposed to saltwater.
This grade has an extra perk in that it’s food safe, meaning it can be made into cookware, like pots and pans, utensils and cutlery, and even those sleek stainless steel cooking worktops you find in restaurants. To make this grade, all the ingredients, including the alloying elements, have to be mixed together and then melted in an electric furnace. This part of the process takes around 8–12 hours. After that, it has to go through decarburization, which is basically getting rid of any carbon that has been left over, and this is done with argon or oxygen. It’s then poured into molds so that it can harden in the needed shape and size.
Stainless steel CNC machined parts from Xometry
What is 18/10 Stainless Steel?
The numbers in 18/10 stainless steel’s name also describe its makeup; it’s got 10% nickel, and around the same amount of chromium as the other two (18%). With that extra bit of nickel, 18/10 steel is known for having slightly better rust and corrosion resistance, making it a great option for flatware, cooking utensils, and kitchen appliances. It can hold its own in high temperatures—earning it another point for use within the food and restaurant industries.
Just like 18/8, the scrap is melted down in a furnace and then decarburized. The only difference is that its ingredients have slightly different proportions, i.e. slightly more nickel. It’s then formed into the shape the manufacturer has in mind and finished in various ways to get the final product.
Stainless steel sheet cut parts made by Xometry
What is 18/0 Stainless Steel?
This grade has no nickel in it — which is why there’s a zero in its name — but it does have the same amount of chromium as the other two grades. Its lack of nickel or molybdenum means it’s not as resistant to corrosion and oxidation. Perhaps balancing that out is its cost—it’s more affordable than the other two grades.
This steel is made just like the other two (melted in a furnace), just without any nickel. It’s then cast into whatever shape and size is needed, then. Once this is done, manufacturers will anneal it or put it through other processes to boost its benefits and improve its finish.
Comparing All Three Steels
You’ll want to think about the end purpose for the stainless steel you’ll be using and the environment it’ll be in, as well as the budget available for manufacturing and what specific characteristics are necessary. To help you decide, we’ve created the two tables below, which provide the strengths and weaknesses of each type of stainless steel, and their properties.
TypeAdvantagesDisadvantages
Type
18/8
Advantages
  • Good corrosion resistance (not in marine/extreme temperature environments)
  • High strength
  • Easy to weld
  • Safe around food
Disadvantages
  • Could corrode when exposed to saltwater, chloride, harsh chemicals, or acids
  • Can only harden through cold working (not always ideal for high-strength applications)
Type
18/10
Advantages
  • Can handle acidic or corrosive foods/liquids without disintegrating
  • Easy to clean, can be put in a dishwasher
  • Safe to use around food
  • Much shinier and aesthetically pleasing surface compared to other grades
  • Can handle high temperatures
Disadvantages
  • Not as easily machinable as other grades, needs more effort and time
  • Has non-magnetic properties not suitable for all uses
  • More expensive than other grades due to higher nickel percentage
  • Doesn’t hold up well in saltwater
Type
18/0
Advantages
  • Most budget-friendly grade
  • Rust resistance adequate for kitchen equipment and utensils
  • Ideal for medical devices, jewelry, and kitchen tools as it has no nickel, which could aggravate allergies
  • It’s magnetic
Disadvantages
  • More likely to corrode than others
  • Not the best for welding because it holds heat, has a high melting point, distorts, and struggles to attach to other materials
  • Doesn’t have as much of a shiny finish as other grades
  • Is much more brittle than other grades (due to no nickel), and can crack
Table 1: Comparing All Three Steels
Property Comparison
The chart below offers a peek at the physical properties, cost, and composition of these different grades of stainless steel:
Property18/8 Stainless Steel18/10 Stainless Steel18/0 Stainless Steel
Property
Corrosion Resistance
Moderate
High
Low
Property
Nickel Content
8-10.5%
10-14%
0%
Property
Chromium Content
18-20%
16-18%
16-18%
Property
strength
Good
Excellent
Moderate
Property
Cost
Moderate
Higher
Lower
Property
Staining Susceptibility
Moderate
Low
High
Table 2: Properties of 18/8, 18/10, and 18/0 Stainless Steels
How Can Xometry Help
At Xometry, we offer many different grades of stainless steel, including popular choices like grades 304 and 316. Best of all, you can an instant quote for custom-made parts in these materials through the various manufacturing processes we offer, including CNC machining, sheet metal fabrication, sheet cutting, and more!
Quick Links
  • Home
  • Contact Us
  • Help Center
  • About Us
  • Careers
  • Press
  • Investors
  • Xometry Go Green
