ResourcesMaterialsEverything You Need to Know About 410 Stainless Steel
Rebecca Piccoli headshot
Published July 7, 2023
Updated December 17, 2024
Essential facts and helpful pointers to have in mind when manufacturing with this common alloy
410 stainless steel sheet. Image Credit: Shutterstock.com/SimoneN
Materials capable of adapting to different environments and applications become a handy go-to in the back pockets of manufacturers, and 410 stainless steel is definitely one such example. Thanks to its easy machinability and relatively low cost—along with a few other helpful properties—410 has risen among the ranks of useful stainless steels. Here’s what you should know about it.
What Is 410 Stainless Steel?
You’ll find this popular steel neatly categorized under the family of steels with martensitic structures. Its composition will vary slightly, but it’s usually made up of iron chromium, magnesium, and nickel, then around 0.08 to 0.15% of carbon, 1.0% or less of silicon, 0.03% or less of sulfur, and 0.04% or less of phosphorus. You can see the breakdown in the pie chart below.
Chemical composition of 410 stainless steel
Because 410 brings a decent corrosion resistance and good hardness to the table, it’s found in everything from your standard pair of kitchen scissors to heavy-duty steam turbine blades. You can also harden it, which can’t be said for other kinds of martensitic steels.
How It’s Made
With the help of an electric arc furnace, the components of this stainless steel are melted and formed into whichever format the manufacturer has in mind. Here’s how the process works on a more granular level:
  1. First, the raw bits needed to make 410 steel are poured into an electric arc furnace or an induction furnace—these usually include chromium, carbon, and other alloying elements. Higher grades will usually have this done under a vacuum. The melting process cuts out contaminants and oxides, creating a floating slag that’ll be removed.
  2. Once it’s melted down, the mixture will be poured into casts to form some kind of ingot or billet.
  3. After they’ve formed and cooled, the maker will reheat those ingots to get them to a place where they can be turned into different shapes. This’ll be done through forging, rolling, or extrusion.
  4. Then, these shapes will go through annealing to lessen internal stresses and boost their ductility and workability.
  5. After this, you or the manufacturer can choose from a few different finishing processes, including more annealing or heat treatment, hot rolling, or cold rolling.
  6. Lastly, grinding, polishing, and other surface treatments are popular in order to get the steel in shape for the application it’s being made for.
"410 is complicated to machine versus other stainless steels. Some challenges include work hardening, higher toughness compared to 304/316, material can stick to the tool and cause rough finishes/bad tool wear, and surface properties altering as heat builds from machining. Best practices would be to machine in the annealed condition, use new HSS or Carbide cutting tools, plenty of coolant, higher feed rate with a decent depth of cut to make it through any work-hardened layer."
Kurt Pokopac,
Solutions Engineer
Properties
The following table will give you a good understanding of some of the physical, thermal, chemical, and structural properties of 410 stainless steel.
PropertyValue
Property
Density
Value
7.8 g/cc
Property
Yield Strength
Value
1,225 MPa at a strain of 0.2%
Property
Ultimate Tensile Strength
Value
1,525 MPa
Property
Hardness
Value
126–192 Brinell hardness (annealed) or 201–255 Brinell hardness (hardened and tempered)
Property
Bulk Modulus
Value
200 GPa
Property
Melting Point
Value
1,480–1,530 °C
Property
Corrosion Resistance
Value
Good corrosion resistance in milder environments, including chemical-laden ones and water. Pitting, corrosion, and staining happen in salt water conditions and acidic environments.
Property
Magnetism
Value
Magnetic thanks to its martensitic structure and a permeability of 700–1,000.
Property
Thermal Conductivity
Value
Low, 24–27 W/mK
Property
Coefficient of Thermal Expansion
Value
9.9 to 11.0 x 10-6/°C between 0–100 °C
Property
Minimum and Maximum Service Temperature
Value
-70 °C (min), 400–580 °C (max)
Property
Machinability Rating
Value
Moderately so at 55% for a 12% chromium alloy, but it will strongly depend on the steel’s specific carbon content and how it is heat treated.
Property
Applications
Value
Scissors, knife blades, kitchen utensils, valves, pumps, pipe fittings, petroleum refining/processing equipment, firearm barrels, fasteners, screws, bolts, nuts, steam turbine blades, springs, and Belleville washers.
410 Stainless Steel Properties
Common Formats of 410 Stainless Steel
There are a few formats that are most typically found when you’re sourcing or making 410 stainless steel, and we’ve put a small explanation of shapes and finishing processes below:
Shapes
  • Sheet: This is a flat-profile sheet material that often has a thickness between 0.5 to 3.5 mm and can come as a hot-rolled or cold-rolled variation, the latter usually being stiffer.
  • Bar: You can find bars in a few distinct shapes, including round, hexagonal, rectangular, or other customized dimensions. They can also go through hot and cold rolling, depending how hard you need it to be.
  • Plate: This type looks pretty similar to a sheet, but is usually thicker (though there isn’t a standard definition between when steel becomes a plate rather than a sheet). Typically plates are around 2 to 3 mm, but it’s a guide rather than a strict requirement.
Processes
  • Hot Rolled: This is a sizing process that gets ingots or billets into the thickness that manufacturers need for additional processing.
  • Cold Rolled: After sizing happens during hot rolling, steel can be cold rolled which gives it a nicer surface finish and more precise thickness. This process also work-hardens it slightly.
  • Annealed: Stainless steel that’s gone through annealing means that it hasn’t been hot- or cold-rolled and instead cooled from red hot to the stage it’s in now. This gives the material a better chance to grow its crystal structure without as many internal stresses.
  • Cold Drawn: Steel that goes through this will be cold-pulled through a die for better dimensions and work hardening. This process improves its strength and hardness, but reduces its ductility (and it can be brittle after).
410 Stainless Steel Worldwide Equivalents
Country/Organizational BodyEquivalent Grade
Japan
Equivalent Grade
JIS SUS 410
AISI
Equivalent Grade
AISI 416 / AISI 420 (close grade)
Europe
Equivalent Grade
X12Cr13 (1.4006)
UNS
Equivalent Grade
S41000
EN
Equivalent Grade
1.4006
FAQs About 410 Stainless Steel
Here are some of the most common questions that arise when you’re weighing up 410 stainless steel or planning on manufacturing with it.
How do you heat treat 410 stainless steel?
Manufacturers typically heat treat 410 stainless steel through hot quenching and tempering to harden, strengthen, and toughen it. The process usually involves preheating the material to a temperature between 760–815 °C, and then when it’s hot, it gets quickly quenched in oil, water, or air. This freezes the steel’s microstructure when it has a fine crystallinity. Once this is done, it’ll often get tempered to reduce internal stress—and the temperature this is done at will determine how hard and ductile it remains.
What are the advantages of 410 stainless steel?
Using 410 stainless steel has a few specific advantages, including that it has great corrosion resistance and hardness, as well as pretty high tensile strength. It also has great wear and heat resistance and does well with heat treatment. Lastly, it’s machinable and relatively inexpensive compared to other steels.
What are the disadvantages of 410 stainless steel?
There are a few downsides to working with 410 stainless steel, one being that it isn’t capable of handling highly corrosive environments that have a lot of exposure to chemicals and salt. It’s also not the best steel out there for welding, and it gets brittle in cold temperatures. It’s also good to note that it’s magnetic and has limited formability, which are disadvantages for some scenarios.
What are the differences between 410 stainless steel and 304 stainless steel?
When you look at both 410 and 304 stainless steels, you’ll notice that 410 has lower corrosion resistance when up against 304 but better strength and hardness. 304 is ideal for corrosive environments that 410 might falter in, but it isn’t as strong.
We’re no stranger to working with various stainless steel materials here at Xometry, including 410. Some of the related services we offer that you can get a free quote for through our website include stainless steel 3D printing, stainless steel laser cutting, and stainless steel sheet metal fabrication.
Quick Links
  • Home
  • Contact Us
  • Help Center
  • About Us
  • Careers
  • Press
  • Investors
  • Xometry Go Green
