ResourcesMaterialsWhat is High Density Polyethylene (HDPE)?
Published April 29, 2022
Learn about this material, its properties, uses, and advantages.
Assorted HDPE bottles. Image Credit: JasminkaM/Shutterstock.com
This article will explore what HDPE is, how it is made, its material and chemical properties, applications, and supplier sources of HDPE.
High Density Polyethylene (HDPE for short) is a thermoplastic polymer derived from petroleum with a generalized chemical formula (C2H4)n. The HDPE formula represents the repeating monomer unit of ethylene and forms a poly-ethylene molecular chain. HDPE is distinct from other forms of polyethylene in that its side chain branching frequency is lower than other polyethylene types, where HDPE is commonly referred to as a “linear” chain.
This linear structure allows HDPE to pack together more tightly and is the reason for its impressive material characteristics. Other basic information about HDPE is contained in the table below:
Chemical Formula(C2H4)n
Chemical Formula
Common Names
(C2H4)n
HDPE, Polyethylene High-Density (PEHD), alkathene, polythene, #2 plastic
Chemical Formula
Density
(C2H4)n
0.958 g/cm3 (average)
Chemical Formula
Structure
(C2H4)n
Linear
Chemical Formula
Material properties
(C2H4)n
High strength-to-density ratio, impact and chemical resistances, recyclable, high melting point, easily molded and worked
How is High Density Polyethylene (HDPE) Made?
HDPE is made in a 4-step process:
  1. HDPE is derived from petroleum and is a linear polymeric chain containing few branches. The process of HDPE manufacturing is different depending upon the manufacturer, but the first step usually involves taking petroleum-based hydrocarbons and applying high heat, causing the hydrocarbon chains to break down into more useful monomers such as ethylene molecules (in HDPE production, this ethylene is collected as a gas).
  2. After collecting the necessary monomers, metallic catalysts (titanium tetrachloride, diethylaluminum chloride, chromium oxide on silica, etc.) mix with ethylene gas and other compounds which catalyze into a slurry of polyethylene.
  3. This slurry is cleaned of remaining catalyst and the HDPE is recovered by extraction, filtration, and drying.
  4. At this point, the HDPE is processed and manufactured into stock or specific products.
This is a HIGHLY simplistic overview of the process, as polymerization organic chemistry is much more detailed (and organic chemists still do not fully understand the reaction mechanism!). Regardless, note that HDPE is made from petroleum and is processed using catalysts to form long, linear, and dense polyethylene now known as high-density polyethylene.
Properties of High Density Polyethylene (HDPE)
Below is a table containing the material properties of HDPE. Note that each value is provided in a range, as various companies produce different blends of HDPE, each with its own set of material properties.
PropertyEnglishMetric
Property
Density
English
0.0337 – 0.0459 lb/in3
Metric
0.933 – 1.27 g/cm3
Property
Yield Strength (Tensile, @ -30.0 - 70.0 °C/ -22.0 - 158 °F   )
English
1000 – 4350 psi
Metric
6.89476 – 30 MPa
Property
Modulus of Elasticity
English
70 – 210 ksi
Metric
0.483 – 1.45 GPa
Property
Flexural Yield Strength
English
2400 – 13200 psi
Metric
16.5 – 91 MPa
Property
Izod Impact, Notched
English
0.375 – 14.1 ft-lb/in
Metric
0.20 – 7.50 J/cm
Property
Melting Point
English
78.8 – 275 °F
Metric
26.0 – 135 °C
Property
Maximum Service Temperature (Air)
English
176 – 248 °F
Metric
80.0 – 120 °C
Property
Linear Mold Shrinkage
English
0.00500 – 0.0400 in/in
Metric
0.00500 – 0.0400 cm/cm
Property
Water Absorption
English
0.0100 – 0.300%
Metric
0.0100 – 0.300%
Property
Coefficient of Friction
English
0.200 – 0.280
Metric
0.200 – 0.280
The important values for HDPE are its heat resistance and its density-to-strength profile. HDPE is known for its heat resistance, as it remains serviceable and rigid up until its max serviceable temperatures, where it is efficiently molded and worked. Its melting point can also be quite high, being generally higher than most other plastics in its weight class.
HDPE’s strength compared to its density allows small amounts of the material to be used to carry multiple pounds of weight with little trouble. This strength combined with its excellent tensile strength is why HDPE is commonly used in milk jugs, bleach bottles, and other liquid storage containers.
Uses of High Density Polyethylene (HDPE)
HDPE plastic is used in a laundry list of applications, as it is currently one of the most versatile plastic materials worldwide. Its strength, impact and corrosion resistance, chemical profile, and other valuable characteristics make it an ideal product material for various industries. Below is a brief list of some of the many uses of HDPE plastic:
  • Corrosion-resistant piping, HDPE sheet, and stock material
  • Fuel tanks
  • Food and beverage containers, plastic bottles, milk jugs, cups, etc.
  • Shampoo/conditioner bottles, ointment tubes, personal care product containers, etc.
  • Trash cans, recycle bins, plastic containers, etc.
  • Bread bags, cereal box liners, food storage containers, etc.
  • Laundry detergent bottles
  • Recycled plastic lumber and composites
  • Medical equipment
  • 3D printing filament
  • Boating components
  • Coax cable insulators
  • Sewage mains
  • Pyrotechnic components
and many, many more applications.
HDPE is found in nearly every business in some capacity but can be found in high concentrations (along with its other PE brethren) in hospital settings thanks to its low moisture absorption, chemical resistance, recyclability, and low bacterial retention rate. HDPE and similar plastics are ideal materials in medical tubing, films, connectors, labware, catheters, IV bags, face masks, device housings, membranes, drug-delivery components, packaging, and much more. Some specialty forms of HDPE, such as ultrahigh molecular weight polyethylene (UHMWPE), are even used in orthopedic implants such as knee or hip replacements for their low friction coefficient, high wear resistance, impact strength, chemical and corrosive resistance, and biocompatibility.
Advantages of Using High Density Polyethylene (HDPE)
HDPE plastic has primary benefits over other materials that give it the celebrity status it deserves. Below is a brief list of the advantages of HDPE:
  • High strength-to-weight ratio
  • Low friction coefficient and low moisture absorption
  • High impact strength, resistant to dents and scratches
  • Mold, mildew, rotting, mineral acids/bases, soil, and weather-resistant
  • Resistant to chemicals, water, solvents, acids, detergents, and cleaning fluids
  • Very malleable when heated and experiences medium to low shrinkage
  • Easily recycled
  • Can be sterilized via boiling, does not harbor bacteria well, and is dishwasher safe
  • Replaces heavier materials in some applications
  • Cost-effective
Disadvantages of Using High Density Polyethylene (HDPE)
HDPE, just like every other material, comes with its own set of tradeoffs. Below is a brief list of the disadvantages of HDPE plastic:
  • In certain forms, it can be flammable as it is a petroleum-based product
  • Exhibits high thermal expansion
  • Weak to oxidizers and chlorinated hydrocarbons
  • Difficult to bond
  • Sensitive to stress-cracking in suboptimal environments
HDPE Formulations and Use Cases
HDPE formulations and use cases
HDPE comes in many formulations based on brand and specific application, but generally, the types of HDPE are broken into two grades based on density: 300 grade and 500 grade (where the number denotes the material density). Both types come in either white or black colors, but 500 grades can typically be colored into any desired hue.
HDPE can be manufactured specially-formulated for different applications. Below is a list of some types of HDPE blended for specific environments or situations in mind:
HDPE can be formulated for:
  • Enhanced stiffness
  • UV stabilization
  • Engraving
  • Antimicrobial properties
HDPE common use cases:
Polyethylene vs. High Density Polyethylene
Polyethylene is the general name to denote all plastics formed from the (C2H4)n monomer, while High Density Polyethylene is a specific form of polyethylene that has been formulated to be denser, more linear in chain structure, and stronger than other forms. Polyethylene encompasses all the possible types such as low-density polyethylene (LDPE), linear low-density polyethylene (LLDPE), and ultrahigh molecular weight polyethylene (UHMWPE), as well as others. In industry, polyethylene is the class of materials, while HDPE is a specific instance of that class of polymers.
To learn more, see our guide on What is Polyethylene.
High Density Polyethylene (HDPE) vs Low Density Polyethylene (LDPE)
HDPE and LDPE are built from the same monomer units, but are functionally two different polyethylene materials. HDPE has a more linear chain structure, making it stronger, denser, and stiffer than low-density polyethylene (LDPE). LDPE is more flexible for this reason and has a lower crystallinity. Both materials are recyclable, however, they cannot be recycled together as LDPE tends to soften quickly and gum up recycling machinery.  LDPE Is weak to heat, succumbing to decreases in density after temperatures beyond 20 °C, while HDPE can remain functional through high temperatures like 100 °C. HDPE has overall better mechanical and chemical resistances, but both are generally weak to oxidizing agents and select hydrocarbons. LDPE is more transparent than HDPE, and both are easily worked and are considered a waterproof material.
Deciding on which polyethylene polymer works best for a given application depends on budget, intended material properties, and special considerations. It is impossible to say if HDPE or LDPE is best (as both are highly popular), but both have cases for their use beyond strength and resistance comparisons. If price is the determining factor, then LDPE wins out; if looking to create a structural part, HDPE will probably be the better choice.
This article presented what high density polyethylene plastic (HDPE) is and how it is used throughout industry as a versatile engineering material.
About Xometry
Xometry provides 3D printing services and plastic injection molding services for all of your production needs. Visit our website to explore the full range of our capabilities or to request a free, no-obligation quote.
Quick Links
  • Home
  • Contact Us
  • Help Center
  • About Us
  • Careers
  • Press
  • Investors
  • Xometry Go Green
