ResourcesMaterialsAll About Stainless Steel Types and Grades
Published December 27, 2023
Updated October 30, 2024
A look at the five types of stainless steel along with 35 example grades
Stainless steel pipes. Image Credit: Shutterstock.com/ThomsonD
There are a few materials out there that have gained so much popularity, they’re essentially household names, and one of those happens to be stainless steel. This well-known family of carbon steel alloys, which is practically the celebrity of metals, can be parsed out into five different groups and then broken down further into a ton of grades. This is what it looks like:
stainless steel bolts
In this article, we break down the different types of stainless steel, as well as an overview of more than 35 grades. If you work with this metal a lot (or plan to) you might want to bookmark this page.
Types of Stainless Steel
All grades of stainless steel fall under one of five different categories: martensitic, austenitic, ferritic, duplex, or precipitation hardened. These types each have a different structure that gives them various properties and benefits (as well as letting you know what they’re not so good at). We’ll explain them in more detail in the table below, but first, a quick note on the structure. If you’d like some more information on how exactly stainless steel is structured, you’re in luck; we wrote a whole guide on this handy metal.
Body-centered tetragonal (BCT): A rectangular cuboid with atoms at each corner and one right in the middle (at the core).
Face-centered cubic (FCC): A cuboid with atoms at each corner, and one in the middle of each face.
Body-centered cubic (BCC): Similar to a BCT, but is a perfectly symmetrical square cube instead of being rectangle.
TypeDescriptionSteel GradePropertiesApplications
Type
Martensitic
Description
BCT structure, carbon content up to 1.2%, 10.5–18% of chromium
Steel Grade
403, 410, 414, 431, 422, 420, 416, 440
Properties
Good: heat treatability, ductility, toughness, tensile strength, creep resistance, fatigue resistance, magnetism
Fair: work hardening rate
Applications
Cutlery, knives, medical instruments, scissors, jet engines
Type
Austenitic
Description
FCC structure, up to 0.15% carbon, chromium 16–26%, up to 35% nickel, up to 15% manganese, 0.75–3% silicon, 0.045–2% phosphorus, trace amounts of sulfur, nitrogen, molybdenum, selenium, copper, titanium, cobalt
Steel Grade
201, 202, 205, 301, 302, 303, 304, 305, 308, 309, 310, 314, 316, 317, 321, 330, 347, 348, 384
Properties
Excellent: work hardening rate, weldability
Good: ductility, toughness, tensile strength, creep and fatigue resistance
Fair: corrosion resistance (up to 650°C), temperature resistance (up to 650°C)
Applications
Exhaust systems, hydraulics, cutlery, cookware, pressure vessels
Type
Ferritic
Description
BCC structure with 10.5–30% of chromium, no more than 0.2% carbon, and various other alloying elements including molybdenum, silicon, aluminum, and titanium (the last two are necessary for any steel to be classed as ferritic)
Steel Grade
430, 434, 409, 439, 444
Properties
Low work hardening rate
Excellent: magnetic response
Good: Tensile strength at low temperatures
Fair: corrosion resistance, temperature resistance, ductility, toughness
Poor: weldability
Applications
Ovens, kitchen sinks, solar panel support frames, aqueous chloride solution piping
Type
Duplex
Description
FCC and BCC structure, includes up to 26% chromium, 4–7% nickel, up to 4.5% molybdenum, and under 1% of copper, tungsten, nitrogen, and carbon
Steel Grade
2205, 2304, 2507, LDX2101
Four classes: lean duplex, standard duplex, super duplex, hyper duplex
Properties
Excellent: corrosion resistance, tensile strength (at moderate temperatures)
Good: ductility, toughness, creep resistance, and fatigue resistance (at moderate temperatures)
Fair: temperature resistance, weldability, magnetic response
Poor: heat treatability
Applications
Components for aqueous chloride plants, oil and gas industry environments, seawater desalination plants
Type
Precipitation-hardened
Description
Can have either FCC and BCC structure but with particles, has elements like chromium, iron, nickel, aluminum, titanium, and copper
Steel Grade
17-4, 13-8, 15-5
Properties
Can be magnetic or non-magnetic
Excellent: tensile and yield strengths, corrosion resistance
Good: ductility, toughness, heat treatability
Poor: Weldability
Applications
Components for marine, aerospace, medical, automotive
In this ultra close-up photo, you can see the ferritic and austenitic structures that make up duplex stainless steel—two types that are explained on the table above.
Duplex steel
Duplex steel
Stainless Steel Grades
Now that you have an understanding of how stainless steel can be categorized, it’s time to get to know the different grades that exist. But just before, here’s a quick rundown of the naming conventions so you’re aware of what the different groups and grades of steel are called:
  • Austenitic: Group A
  • Duplex: Group AF
  • Ferritic: Group F
  • Martensitic: Group C
The below table will show you the grade, the specific composition of that stainless steel broken down by percentage, its properties, and the applications it’s normally used for.
Key
  • Carbon: C
  • Manganese: Mn
  • Silicon: Si
  • Chromium: Cr
  • Nickel: Ni
  • Phosphorus: P
  • Sulfur: S
  • Nitrogen:
  • Molybdenum: Mb
  • Tungsten: W
  • Copper: Cu
  • Iron: Fe
  • Boron: B
  • Titanium: Ti
  • Selenium: Se
  • Niobium: Nb
  • Tantalum: Ta
GradeComposition %PropertiesApplications
Grade
201
Composition %
C: 0.15, Mn: 5.5–7.5, Si: 1, Cr: 16–18, Ni: 3.5–5.5, P: 0.045, S: 0.015, N: 0.25
Properties
Good: ductility, work-hardening rate, weldability, low-temperature resistance
Applications
Architecture, sinks, cold-formed parts
Grade
202
Composition %
C: 0.15, Mn: 7.5–10, Si: 1, Cr: 17–19, Ni: 4–6, P: 0.045, S: 0.015, N: 0.25
Properties
Good: ductility, weldability (except through oxyacetylene welding), low-temperature resistance, cold working hardens this metal
Applications
Sinks, doors, railings, windows, kitchen appliances
Grade
205
Composition %
Cr: 16.5–18, Mn: 14–15.5, Ni: 1–1.75, N: 0.4
Properties
Good: ductility, work hardening rate, weldability
Fair: temperature resistance, corrosion resistance
Applications
Cutlery, cookware, decorative architectural and design elements, food and beverage equipment
Grade
2507
Composition %
Cr: 25, Ni: 7, Mb: 4, N: 0.28, W: 0.7, Cu: 0.7
Properties
Excellent: corrosion resistance, temperature resistance (it has a pitting resistance equivalent number of 43)
Good: weldability
Fair: work hardening rate, ductility
Applications
Parts for coal, pulp, paper, desalination plants
Grade
301
Composition %
C: 0.05–0.15, Mn: 2, Si: 2, Cr: 16–19, Ni: 6–9.5, P: 0.045, S: 0.015, Ni: 0.11, Mb: 0.8
Properties
Good: ductility, corrosion resistance, temperature resistance (and holds onto its toughness), weldability, work hardening rate
Applications
Watch bands, medical instruments, toys, office equipment, eating utensils
Grade
302
Composition %
C: 0.15, Mn: 2, Si: 1, Cr: 17–19, Ni: 8–10, P: 0.045, S: 0.03
Properties
Excellent: weldability, temperature resistance (and keeps its toughness)
Good: work hardening rate, corrosion resistance
Fair: ductility
Applications
Cold-working, dishwashers, blenders, stamps, cryogenic applications
Grade
302B
Composition %
Cr: 17–19, Ni: 8–10, C: 0.15, Mn: 2, Si: 2–3, P: 0.045, S: 0.03
Properties
Fair: ductility
Applications
Cold-working, screen mesh applications, wire rope, cryogenic applications, stamping
Grade
303
Composition %
Cr: 18, Ni: 9, S: 0.15–0.35, Cu: 1
Properties
Good: ductility, temperature resistance
Fair: corrosion resistance, work hardening rate
Very poor: weldability, magnetism
Applications
Cold-work hardening, aircraft parts, bushings, shafts, fasteners
Grade
303Se
Composition %
C: 0.15, Mn: 2, Si: 1, Cr: 17–19, Ni: 8–10, Se: 0.15, S: 0.06, P: 0.2
Properties
Same as 303
Applications
Same as 303
Grade
304
Composition %
Cr: 17.5–19.5, Ni: 8–10.5, C: 0.07, Mn: 2, Si: 1, P: 0.045, S: 0.015
Properties
Excellent: temperature resistance, weldability
Good: corrosion resistance, ductility
Applications
Cold-work hardening, high-pressure flanges, pressure vessels, pumps, parts found in petrochemical processing plants
Grade
304H
Composition %
C: 0.04–0.08, Mn: 2, Cr: 17.5–19.5, Ni: 8–11, Si: 1, P: 0.035, S: 0.015, N: 0.1
Properties
Excellent: temperature resistance (and it keeps its toughness), weldability
Fair: ductility
Applications
Cold-work hardening, pressure vessels, pumps, boilers, condensers, heat exchangers
Grade
304L
Composition %
C: 0.03, Mn: 2, Cr: 17.5–20, Ni: 8–12, Si: 1, P: 0.035, S: 0.015, N: 0.11
Properties
Fair: ductility
Applications
Cold-work hardening, pressure vessels, parts for mining, medical, nuclear power generation
Grade
304N
Composition %
C: 0.06, Mn: 2, Si: 1, Cr: 18–20, Ni: 8–11, P: 0.045, S: 0.015, N: 0.12–0.22
Properties
Good: corrosion resistance, temperature resistance, ductility
Applications
Cold-work hardening, vacuum testing chambers, decarburization columns, containers that hold liquid natural gas
Grade
S30430
Composition %
C: 0.04, Mn: 2, Fe: 63.9–72, Cr: 17–19, Ni: 8.5–10.5, Cu: 3–4
Properties
Good: corrosion and temperature resistance, ductility
Applications
Cold-work hardening, many kinds of screws, like self-tapping, light machine, sets, fasteners, bolts, rivet
Grade
305
Composition %
C: 0.06, Mn: 2, Si: 1, Cr: 17–19, Ni: 11–13, P: 0.045, S: 0.015, N: 0.11
Properties
Excellent: ductility
Poor: work hardening rate, weldability
Applications
Cold-working, acid production machinery, food and beverage equipment, deep-drawn components
Grade
308
Composition %
C: 0.08, Mn: 2, Si: 1, Cr: 19–21, Ni: 10–12, P: 0.045, S: 0.015, N: 0.11
Properties
Excellent: temperature resistance—retaining its toughness, weldability
Applications
Cold-work hardening, weldable parts, filler material in welding
Grade
309
Composition %
C: 0.2, Mn: 2, Si: 1.5–2.5, Cr: 19–21, Ni: 11–13, P: 0.045, S: 0.015, N: 0.11
Properties
Excellent: temperature resistance without losing its toughness
Fair: work hardening rate, weldability
Applications
Cold-work hardening, incinerators, kilns, coal burners, fluidized bed furnaces, paper mill equipment
Grade
310
Composition %
C: 0.25, Mn: 0.2, Si: 1.5, Cr: 24–26, Ni: 19–22, P: 0.045, S: 0.03
Properties
Excellent: temperature resistance while keeping its toughness
Applications
Cold-work hardening, furnaces, cryogenic components, burner grids, feeders
Grade
314
Composition %
C: 0.2, Mn: 2, Si: 1.5–2.5, Cr: 24–26, Ni: 19–22, P: 0.045, S: 0.015, N: 0.11
Properties
Excellent: temperature resistance (keeps its toughness)
Good: weldability, corrosion resistance, ductility
Applications
Cold-work hardening, heat exchangers, furnace conveyors, high-heat applications
Grade
316
Composition %
C: 0.07, Mn: 2, Si: 1, Mb: 2–2.5, Cr: 16.5–18.5, Ni: 10–13, P: 0.045, S: 0.015, N: 0.11
Properties
Good: Work hardening rate, corrosion resistance, temperature resistance, ductility, weldability
Applications
Cold-work hardening (but not with heat treatment), cookware, license plates, boat fittings, offshore structures, surgical instruments
Grade
316F
Composition %
C: 0.08, Mn: 2, Si: 1, Mb: 1.75–2.5, Cr: 16–18, Ni: 10–14, P: 0.2, S: 0.1
Properties
Good: corrosion resistance at hotter temperatures, ductility, temperature resistance, weldability
Applications
Cold-work hardening (but not with heat treatment), surgical implants, rubber processing plants, pulp and paper industry uses
Grade
316H
Composition %
C: 0.04–0.08, B: 0.0015–0.005, Mn: 2, Si: 1, Mb: 2–2.5, Cr: 16.5–18.5, Ni: 10–13, P: 0.035, S: 0.015, N: 0.11
Properties
Good: corrosion resistance at hotter temperatures, ductility, weldability
Applications
Cold-work hardening (but not with heat treatment), power generation, wastewater treatment plants, medical equipment, parts for the pulp and paper industry
Grade
316L
Composition %
C: 0.03, Mn: 2, Si: 1, Mb: 2–3, Cr: 16.5–19, Ni: 10–15, P: 0.045, S: 0.015, N: 0.11
Properties
Applications
Cold-work hardening (but not with heat treatment), parts for marine environments, textile production, chemical processing, petroleum refining
Grade
316Ti
Composition %
C: 0.08, Ti: 0.7, Mn: 2, Si: 1, Mb: 2–2.5, Cr: 16.5–18.5, Ni: 10.5–13.5, P: 0.045, S: 0.015
Properties
Excellent: strength at high temperatures
Good: work hardening rate, corrosion resistance at high temperatures, ductility, weldability
Applications
Products that require resistance to pitting and corrosion
Grade
317
Composition %
C: 0.08, Mn: 2, Si: 1, Mb: 3–4, Cr: 18–20, Ni: 11–15, P: 0.045, S: 0.03, N: 0.11
Properties
Good: corrosion resistance, work hardening rate, ductility, temperature resistance, weldability
Applications
Cold-working, heat-treatment, components that’ll be near or holding oil, gasses, chemicals, food, beverages, paper pulp
Grade
317L
Composition %
C: 0.03, Mn: 2, Si: 1, Mb: 3–4, Cr: 17.5–19.5, Ni: 13–17, P: 0.045, S: 0.03, Nitrogen: 0.11
Properties
Good: corrosion resistance (even at elevated temperatures), ductility, temperature resistance, weldability
Applications
Cold-working, petroleum refining, explosives, pulp and paper processing
Grade
317L
Composition %
Properties
Applications
Grade
317LMN
Composition %
C: 0.03, Mn: 2, Si: 1, Mb: 4–5, Cr: 16.5–18.5, Ni: 12.5–14.5, P: 0.045, S: 0.015, N: 0.12–0.22
Properties
Excellent: corrosion resistance (even at hot temperatures)
Fair: strength, hardening rate
Applications
Pharmaceutical equipment, air pollution components, food and beverage processing parts
Grade
321
Composition %
C: 0.08, Mn: 2, Ti: 0.7, Si: 1, Cr: 17–19, Ni: 9–12, P: 0.045, S: 0.015
Properties
Good: corrosion resistance at high temperatures, ductility, weldability, strength at high temperatures
Applications
Work-hardening, manifolds for aircraft piston engines, food processors, expansion joints
Grade
347
Composition %
C: 0.08, Mn: 2, Nb: 1, Si: 1, Cr: 17–19, Ni: 9–12, P: 0.045, S: 0.015
Properties
Good: work hardening rate, ductility, temperature resistance, weldability
Applications
Cold-work hardening, kitchen utensils, chemical processing equipment, heat exchangers, catalytic cracking units
Grade
348
Composition %
C: 0.08, Mn: 2, Nb: 0.8, Ta: 0.1, Si: 1, Cr: 17–19, Ni: 9–13, P: 0.045, S: 0.03
Properties
Fair: weldability (through shielded gas methods)
Good: corrosion resistance (at hot temperatures), work hardening rate, ductility, temperature resistance
Applications
Cold-work hardening, lining the insides of reactors and fuel cells in nuclear reactors
Grade
330
Composition %
C: 0.08, Mn: 2, Si: 0.75–1.5, Cr: 17–20, Ni: 34–37, P: 0.03, S: 0.03
Properties
Good: ductility, weldability, temperature resistance, work hardening rate
Applications
Salt pots and waste remediation unit parts in chemical processing and thermal treatment plants
Grade
384
Composition %
Properties
Fair: weldability (with shielded gas techniques)
Applications
Cold-work hardening, fasteners, parts made for steam turbines
Grade
409
Composition %
C: 0.03, Ti: 0.65, Mn: 1, Si: 1, Cr: 10.5–12.5, P: 0.04, S: 0.015
Properties
Excellent: corrosion resistance at hot temperatures
Good: ductility
Fair: strength at hot temperatures, weldability
Very poor: can’t be work hardened or hardened through heat treatments
Applications
Agricultural equipment, car parts like exhaust systems, fuel filters
Grade
410
Composition %
C: 0.08–0.15, Mn: 1.5, Si: 1, Cr: 11–13.5, Ni: 0.75, P: 0.04, S: 0.015
Properties
Good: strength at low temperatures
Fair: ductility and corrosion resistance (at moderate temperatures), can be heat treated
Poor: weldability
Applications
Wide range of applications, like scissors and more specialized component for petroleum refinery plants
Grade
420
Composition %
C: 0.15–0.42, Mn: 1–1.5, Si: 1, Cr: 12–14, P: 0.04, S: 0.015
Properties
Good: strength in cold temperatures
Fair: thermal treating, corrosion resistance, ductility
Poor: weldability
Very poor: can’t be work-hardened
Applications
Needle valves, knives, hand tools, wear plates
Grade
430
Composition %
C: 0.08, Mn: 1, Si: 1, Cr: 16–18, P: 0.04, S: 0.015
Properties
Good: ductility
Fair: corrosion resistance and strength at hot temperatures, weldability
Poor: work hardening rate and can’t be hardened with heat treatments
Applications
Chimney liners, dishwasher parts, lashing wires
Grade
434
Composition %
C: 0.08, Mb: 0.9–1.4, Mn: 1, Si: 1, Cr: 16–18, P: 0.04, S: 0.015
Properties
Good: corrosion resistance and strength at hot temperatures
Fair: ductility, weldability
Poor: work hardening rate and be hardened with thermal treatment
Applications
Furnace combustion chambers, vehicle trim, medical equipment
Grade
440C
Composition %
C: 0.95–1.2, Mb: 0.4–0.8, Mn: 1, Si: 1, Cr: 16–18, P: 0.04, S: 0.03
Properties
Excellent: strength at cold temperatures
Poor: ductility, corrosion resistance, weldability
Applications
Heat hardenable (but not work hardening), knives, chisels, valve seats, roller element bearings
Grade
904L
Composition %
C: 0.02, Cu: 1.2–2, Mb: 4–5, Mn: 2, Ni: 24–26, Si: 0.7, Cr: 19–21, P: 0.03, S: 0.01, N: 0.15
Properties
Excellent: Work hardening rate
Good: corrosion resistance, temperature resistance, ductility, weldability
Applications
Containers for acids, components in chemical processing plants, pulp and paper mills (for bleaching), parts for brackish water processing plants
Below you can see another picture of machined parts made of stainless steel parts that we’ve made here at Xometry.
Stainless steel machined parts from Xometry
International Equivalents
The table below shows different names for stainless steel standards across the globe and how they compare to the American Iron and Steel Institute (AISI) names:
StandardExampleNotes
Standard
European Standard (EN)
Example
1.4301
Notes
Stainless steel names are identified numerically by 1.4 and then have three digits after that share the composition
Standard
Japanese International Standard (JIS)
Example
SUS304
Notes
Japan uses the AISI standard but adds the SUS prefix
Standard
British Standard (BS)
Example
BS 970
Notes
Britain has adopted the AISI standard as well
Standard
Chinese National Standard (GB)
Example
Notes
It all depends on where the steel comes from and what its composition is
Standard
German Standard (DIN)
Example
DIN X12CrNi17-7
Notes
It’s governed by DIN17006 and the name will have an X, then the content of the alloying elements that make up more than 5%
Standard
International Organization for Standardization (ISO)
Example
ISO15510
Notes
ISO has adopted Germany’s DIN standard.
Stainless steels are one of the most popular materials we help our clients with at Xometry, too. You can get a free quote from us on tons of different services, including stainless steel 3D printing, stainless steel CNC machining, and stainless steel laser cutting.
Quick Links
  • Home
  • Contact Us
  • Help Center
  • About Us
  • Careers
  • Press
  • Investors
  • Xometry Go Green
