Standard Inserts
Press-Fit Inserts for Plastic
ThreadMaximum Insert Length(in)Hole Diameter(in)
Thread
UNC/UNF
Hole Diameter(in)
Thread
0-80 UNC
0.125
Hole Diameter(in)
0.094
Thread
2-56 UNC
0.156
Hole Diameter(in)
0.125
Thread
4-40 UNC
0.188
Hole Diameter(in)
0.156
Thread
6-32 UNC
0.250
Hole Diameter(in)
0.188
Thread
8-32 UNC
0.313
Hole Diameter(in)
0.219
Thread
10-24 UNC
0.375
Hole Diameter(in)
0.250
Thread
10-32 UNF
0.375
Hole Diameter(in)
0.250
Thread
1/4-20 UNC
0.500
Hole Diameter(in)
0.313
Thread
5/16-18 UNC
0.563
Hole Diameter(in)
0.375
Thread
3/8-16 UNC
0.625
Hole Diameter(in)
0.438
Thread
Metric
Hole Diameter(in)
Thread
M3x0.5
0.189
Hole Diameter(in)
0.157
Thread
M3.5×0.6
0.252
Hole Diameter(in)
0.189
Thread
M4x0.7
0.315
Hole Diameter(in)
0.220
Thread
M5x0.8
0.374
Hole Diameter(in)
0.252
Thread
M6x1.0
0.500
Hole Diameter(in)
0.315
Tapping Inserts for Plastic
Thread
2-56 UNC
0.188
Hole Diameter(in)
0.1285
Thread
4-40 UNC
0.234
Hole Diameter(in)
0.152
Thread
6-32 UNC
0.281
Hole Diameter(in)
0.196
Thread
8-32 UNC
0.328
Hole Diameter(in)
0.228
Thread
10-24 UNF
0.375
Hole Diameter(in)
0.266
Thread
10-32 UNF
0.375
Hole Diameter(in)
0.266
Thread
1/4-20 UNC
0.484
Hole Diameter(in)
0.339
Heat-Set Inserts for Plastic
ThreadsMaximum Insert Length(in)Hole Diameter(in)
Threads
UNC/UNF
Hole Diameter(in)
Threads
0-80 UNC UNC
0.115
Hole Diameter(in)
0.118
Threads
2-56 UNC
0.188
Hole Diameter(in)
0.107
Threads
4-40 UNC
0.219
Hole Diameter(in)
0.141
Threads
6-32 UNC
0.250
Hole Diameter(in)
0.185
Threads
8-32 UNC
0.312
Hole Diameter(in)
0.206
Threads
10-24 UNC
0.375
Hole Diameter(in)
0.246
Threads
10-32 UNF
0.375
Hole Diameter(in)
0.246
Threads
1/4-20 UNC
0.500
Hole Diameter(in)
0.316
Helical Inserts
Thread
UNC/UNF
Hole Diameter(in)
Thread
2-56 UNC
0.215
Hole Diameter(in)
0.091
Thread
4-40 UNC
0.336
Hole Diameter(in)
0.118
Thread
4-48 UNF
0.168
Hole Diameter(in)
0.118
Thread
5-40 UNC
0.250
Hole Diameter(in)
0.134
Thread
6-32 UNC
0.414
Hole Diameter(in)
0.146
Thread
8-32 UNC
0.172
Hole Diameter(in)
0.25
Thread
8-36 UNF
0.172
Hole Diameter(in)
0.28
Thread
10-24 UNC
0.201
Hole Diameter(in)
0.28
Thread
10-32 UNF
0.570
Hole Diameter(in)
0.201
Thread
1/4-20 UNC
0.750
Hole Diameter(in)
0.264
Thread
Metric
Hole Diameter(in)
Thread
M2x0.4
0.086
Hole Diameter(in)
0.083
Thread
M2.5×0.45
0.248
Hole Diameter(in)
0.104
Thread
M3x0.5
0.295
Hole Diameter(in)
0.126
Thread
M4x0.7
0.394
Hole Diameter(in)
0.167
Thread
M5x0.8
0.492
Hole Diameter(in)
0.209
Thread
M6x1.0
0.590
Hole Diameter(in)
0.248
Thread
M8x1.25
0.787
Hole Diameter(in)
0.331
Thread
M10x1.5
0.591
Hole Diameter(in)
0.413
Thread
M12x1.75
0.472
Hole Diameter(in)
0.492
Dowel Pins
Pin SizeDecimal Size (in)Max Pin Length (in)
Pin Size
Inch
Decimal Size (in)
Max Pin Length (in)
Pin Size
1/32″
Decimal Size (in)
0.03125
Max Pin Length (in)
.625
Pin Size
1/16″
Decimal Size (in)
0.0625
Max Pin Length (in)
1.000
Pin Size
3/32″
Decimal Size (in)
0.09375
Max Pin Length (in)
1.000
Pin Size
1/8″
Decimal Size (in)
0.125
Max Pin Length (in)
1.000
Pin Size
5/32″
Decimal Size (in)
0.15625
Max Pin Length (in)
0.500
Pin Size
3/16″
Decimal Size (in)
0.1875
Max Pin Length (in)
1.000
Pin Size
1/4″
Decimal Size (in)
0.250
Max Pin Length (in)
1.000
Pin Size
Metric
Decimal Size (in)
Max Pin Length (in)
Pin Size
1mm
Decimal Size (in)
0.0394
Max Pin Length (in)
0.394
Pin Size
1.5mm
Decimal Size (in)
0.059
Max Pin Length (in)
0.630
Pin Size
2mm
Decimal Size (in)
0.0787
Max Pin Length (in)
0.787
Pin Size
2.5mm
Decimal Size (in)
0.0984
Max Pin Length (in)
0.472
Pin Size
3mm
Decimal Size (in)
0.118
Max Pin Length (in)
1.181
Pin Size
4mm
Decimal Size (in)
0.157
Max Pin Length (in)
1.575
Pin Size
5mm
Decimal Size (in)
0.197
Max Pin Length (in)
0.787
Pin Size
6mm
Decimal Size (in)
0.236
Max Pin Length (in)
0.551
Pin Size
8mm
Decimal Size (in)
0.315
Max Pin Length (in)
0.787
