Urethane and Silicone Casting Services for American Samoa
High Quality Urethane and Silicone Casting serving American Samoa| ITAR Registered | Low Volume, Durable Parts with Production-Level Quality
Your American Samoa Urethane Casting Service
Urethane Casting Materials
Material Name | Shore Hardness | Description | Technical Information | Data Sheets |
Material Name General Purpose | Shore Hardness Shore D 76-80 | Description An impact-resistant Shore 78D material used for a variety of purposes, from enclosure housings to concept models. This material exhibits ABS-like properties. | Technical Information TC-878, TC-852, or equivalent | Data Sheets |
Material Name Rigid Clear | Shore Hardness Shore D 80 | Description A versatile, Shore D 80, clear polyurethane. A matte finish will give a frosted appearance and a higher gloss will increase its transparency. | Technical Information Poly-Optic 1410 or equivalent | Data Sheets |
Material Name ABS-Like, FR | Shore Hardness Shore D 78-82 | Description A tough Shore 80D flame retardant material that is UL Listed with a flammability rating at 1/16" (1.6 mm). | Technical Information TC-891-FR or equivalent | Data Sheets |
Material Name Polypropylene-Like | Shore Hardness Shore D 65-75 | Description A tough and abrasion-resistant flexible urethane with polypropylene-like ductility. | Technical Information TC-872, HP-2270D, or equivalent | Data Sheets |
Material Name Polycarbonate-Like | Shore Hardness Shore D 82-86 | Description A stiff, high impact, high HDT, material with a wide variety of uses. Simulates polycarbonate (non-clear), Shore 84D. | Technical Information TC-854 or equivalent | Data Sheets |
Material Name Glass-Filled Nylon-Like | Shore Hardness Shore D 85 | Description A stiff, USP Class VI, high-performance urethane with high impact strength and a HDT of 190°F (88°C). | Technical Information PT8902 or PT8952 (FR) | Data Sheets |
Material Name Rubber-Like Polyurethane | Shore Hardness Shore A 25-95 | Description A Shore A elastomer with a high elongation to break. | Technical Information F-130 to F-190 or equivalent | Data Sheets |
Material Name Clear Rubber-Like Polyurethane | Shore Hardness Shore A 40-95 | Description A colorless Shore A elastomer with a high elongation to break. Matte finish will give a frosted appearance, and higher gloss will increase its transparency. | Technical Information WC-540 to WC-595 or equivalent | Data Sheets |
Cast Silicone Materials
- Shore A 10 (TC-5005 or equiv.)
- Shore A 20-30 (TC-5130 or equiv.)
- Shore A 30-40 (TC-5140 or equiv.)
- Shore A 40-50 (TC-5150 or equiv.)
- Shore A 50-60 (Smooth‑Sil™ 960 or equiv.)
Available Finishes for Urethane Casted Parts Near American Samoa
Urethane Color Options
- Black
- Color-Match
- Natural (unpigmented)
- Clear (colorless)
Low-Volume Production
Advanced Prototyping
Market Testing
Urethane casting provides end-use, rigid, flexible, and rubber parts with production-level quality. The urethane casting process uses a 3D-printed master pattern to create a silicone mold that delivers high-quality, short-run parts as an economical alternative to low-volume injection molding.
How Urethane Casting Works
Urethane casting is similar to injection molding in that it requires a tool with a cavity in the shape of the final part. The major difference is that urethane casting uses a "soft" mold made of silicone whereas injection molding using a "hard" metal mold that has been CNC machined. The drawback to urethane casting, then, is that the mold wears out more quickly. However, it is vastly more cost-efficient for low-volume and prototype plastic parts that require production-level quality and surface finishes.
- The Master Pattern: In step one, a master pattern of the final part is made using an additive manufacturing process. Polyjet 3D or stereolithography (SLA) 3D printing processes are most often used due to their ability to produce high-resolution and naturally smooth finish parts. The master pattern is typically hand-finished to achieve optimal surface detail before the creation of the mold tool.
- Molding: In step two, the 3D printed master pattern is encased in liquid silicone that cures around the pattern, with the silicone encapsulating all the features of the printed parts. When the mold cures, it is cut into distinct halves and the master pattern or 3D printed part, is removed. This leaves an internal cavity perfectly shaped like the part.
- Pouring: In the final step of the urethane casting process, liquid urethane or silicone is poured into the silicone mold, and the mold is then placed in a chamber to help remove air bubbles in the liquid material. For opaque parts, the chamber is typically pressurized. For clear parts, the chamber typically pulls a vacuum to mitigate any bubbles and increase clarity. Once cured, the silicone halves are separated and the newly formed part is removed. This process is repeated until the desired quantity is achieved.
Benefits Of Urethane Casting
Urethane casting has a low-cost and quick turnaround for high-quality plastic parts compared to injection molding or 3D printing. Where injection molding requires an expensive upfront investment for the machining of the mold, the silicone mold required for urethane casting is inexpensive and easy to produce. Additionally, while most 3D printing processes require extensive post-processing to get to a near-finished state, urethane cast parts come out of the mold ready to go. Urethane casting is an excellent choice for creating high-quality prototypes or low-volume production of rigid, flexible, clear, colored, or rubber-like plastic parts.
Urethane Casting Tolerances
Description Distance Dimensions | Tolerance Notes =+/- 0.010” or +/- 0.003” per inch, whichever is larger, is typical. Irregular or overly-thick geometries may cause deviances or deflection due to shrinkage. |
Description Shrink Mitigation | Tolerance Notes A shrinkage rate of +0.15% can be expected due to thermal expansion of the liquid, and the response of the flexible mold. |
Description Surface Quality | Tolerance Notes Surface finish is externally smoothed to a satin or matte surface. Grow lines may be present on internal or difficult-to-access features. Polishing or custom finishes must be clearly defined and agreed upon at the point of order. |
Description Feature Definition | Tolerance Notes Sharp corners and text may appear slightly rounded. |
Description Size Recommendation | Tolerance Notes We can offer urethane cast parts as large as 30” (0.762 m) long. |
Why Choose Xometry for Urethane and Silicone Casting Services near American Samoa?
