CapabilitiesUrethane and Silicone Casting ServicesPuerto Rico
Urethane and Silicone Casting Services for Puerto Rico
High Quality Urethane and Silicone Casting serving Puerto Rico| ITAR Registered | Low Volume, Durable Parts with Production-Level Quality
Urethane Casting
Your Puerto Rico Urethane Casting Service
Urethane Casting Materials
    Cast Urethane Materials
    Material Name
    General Purpose
    Shore Hardness
    Shore D 76-80
    Description
    TC-878, TC-852, or equivalent
    Data Sheets
    General Purpose Data Sheet
    Material Name
    Rigid Clear
    Shore Hardness
    Shore D 80
    Description
    Poly-Optic 1410 or equivalent
    Data Sheets
    Material Name
    ABS-Like, FR
    Shore Hardness
    Shore D 78-82
    Description
    TC-891-FR or equivalent
    Data Sheets
    Material Name
    Polypropylene-Like
    Shore Hardness
    Shore D 65-75
    Description
    Data Sheets
    Material Name
    Polycarbonate-Like
    Shore Hardness
    Shore D 82-86
    Description
    TC-854 or equivalent
    Data Sheets
    Material Name
    Glass-Filled Nylon-Like
    Shore Hardness
    Shore D 85
    Description
    PT8902 or PT8952 (FR)
    Data Sheets
    Material Name
    Rubber-Like Polyurethane
    Shore Hardness
    Shore A 25-95
    Description
    F-130 to F-190 or equivalent
    Data Sheets
    Material Name
    Shore Hardness
    Shore A 40-95
    Description
    Data Sheets
    Cast Silicone Materials
    Available Finishes for Urethane Casted Parts Near Puerto Rico
    Matte/Frosted
    Semi-Gloss
    High-Gloss
    Textured
    Custom
    Urethane Color Options
    • Black
    • Color-Match
    • Natural (unpigmented)
    • Clear (colorless)
    Digital manufacturing
    Low-Volume Production
    Fast parts and fast shipping
    Advanced Prototyping
    Precision
    Market Testing
    How Urethane Casting Works
    Benefits Of Urethane Casting
    Urethane Casting Tolerances
    DescriptionTolerance Notes
    Description
    Distance Dimensions
    Tolerance Notes
    Description
    Shrink Mitigation
    Tolerance Notes
    Description
    Surface Quality
    Tolerance Notes
    Description
    Feature Definition
    Tolerance Notes
    Description
    Size Recommendation
    Tolerance Notes
    Why Choose Xometry for Urethane and Silicone Casting Services near Puerto Rico?
    Massive Network Capacity
    Quality assurance
    Xometry X Logo
