Xometry Chem Film Service
Get Quotes in Two Hours and Parts Coated and Shipped to you in as Fast as 2 Days
ITAR Registered
ISO 9001
ISO 13485
AS9100D Certified
Chem Film Overview
Chem Film Coating is a type of chemical conversion coating used to passivate aluminum. It improves adhesion of paint finishes and other coatings and prevents corrosion, though it provides less corrosion resistance than some other finishes like anodizing. It also serves as a base for organic coatings while leaving dimensions unchanged. Specifications: MIL-DTL 5541
- Benefits of Chem Film Coating:
- Extend Part Life
- Minimal Surface Oxidation on Aluminum
- Wear Resistance
- Cost-Effective
- Ideal for Paint Adhesion
Competitive Pricing
Access a deep network of world-class chem film coaters, helping you find the suppliers you need at competitive prices.
Fast Quoting
Streamlined Communication
- Type II Anodize
- Type III Hard coat
- Type III w/ PTFE
- Copper Plating
- Electroless Nickel
- Electrolytic Nickel
- Nickel Plating
- Nickel Sulfamate
- Nickel Watts
- Tin
- Zinc
- Black Oxide
- Dry Film Lubricants
- Powder Coat
- Wet Paint
- Chem Film
- Chromate Conversion Coating
- Heat Treat
- Passivation
- Pickle and Oil
- Bead Blasting
- Electropolishing
- Etching
- Ink Stamping
- Laser Marking
- Silk Screening
- Annealing
- Carburizing
- Cryogenic Treatment
- Flame Hardening
- Hydrogen Embrittlement Relief
- Induction Hardening
- Nitriding
- Stress Relieving
- AS 9100D
- ISO 13485
- ISO 9001:2015
- ITAR
- NADCAP
- RoHS
Finishing Services at Xometry
Find Your Finisher
Find verified finishers using our robust search tools with over 50 different criteria including location, finishing capabilities, and certifications.
Create and Submit Your Request
Send a breakdown of your project's requirements to the finisher of your choice complete with details on your finishing needs and any necessary files.
Manage Your Order
Manage your order from start to finish in one place, including fast and easy transactions with your credit card or apply for net-30 terms with no hassle or risk.
