The Best CNC Materials for the Medical Device Industry
The medical device industry covers an enormous line of products, but even so, there are often overlapping material requirements between applications. Learn about medical industry materials that offer low moisture, high heat-resistance, low corrosion, high hardness, and more.
The medical device industry covers an enormous line of products ranging from artificial joints to diagnostic equipment to therapeutic devices. Even so, across varying applications are often overlapping requirements that help narrow the list of material choices. For example, most devices need surfaces that do not absorb moisture and can be sterilized easily.
Medical device components are often manufactured through injection molding, additive manufacturing (3D printing), and CNC machining. CNC machining has the advantage of high customization, tight tolerances, great surfaces finishes, and certified material selection. When using CNC machining, parts are typically milled using 3 to 5 axes or turned using a live-tooling CNC lathe. Below are the top metal and plastic materials machined for medical device products.
Plastics and Composites for Medical Devices
The most common plastics for medical devices boast low water absorption (moisture resistance) as well as decent thermal properties. Most of the following materials can be sterilized using an autoclave, gamma, or EtO (ethylene oxide) method. Low surface friction, as well as better temperature resistance, is also preferred for the medical industry. Beyond direct or indirect contact housings, fixtures, and guides, plastics can act as a substitute for metals where magnetism or RF (radio frequency) signature may interfere with diagnostic results.
Name | Description |
Name Delrin (Acetal) | Description Resin with good moisture-resistance, high wear-resistance, and low friction. |
Name Polycarbonate (PC) | Description With almost twice the tensile strength of ABS, polycarbonate has superior mechanical and structural properties. Used widely in automotive, aerospace, medical, and other applications that require durability and stability. Solid infill parts are fully dense. |
Name PEEK | Description Offering excellent tensile strength, PEEK is often used as a lightweight substitute for metal parts in high-temperature, high-stress applications. PEEK resists chemicals, wear, and moisture. |
Name UHMW PE | Description UHMWPE is a general-purpose material. It offers a unique combination of wear and corrosion resistance, low surface friction, high impact strength, high chemical resistance, and does not absorb moisture. |
Name PTFE (Teflon) | Description Teflon surpasses most plastics when it comes to chemical resistance and performance in extreme temperatures. It resists most solvents and is an excellent electrical insulator. |
Name Polypropylene (PP) | Description PP has excellent electrical properties and little or no moisture absorption. It carries light loads for a long period in widely varying temperatures. It can be machined into parts requiring chemical or corrosion resistance. |
Name Garolite G-10 | Description Garolite G-10 is constructed from an epoxy resin with fiberglass fabric reinforcement and is also called epoxy-grade industrial laminate and phenolic. This material offers high strength and low moisture absorption. CNC machined Garolite is often used as a substitute for metal components when structural features cannot be magnetic. |
Metals for Medical Devices
The best machinable metals for the medical device industry boast inherent corrosion resistance, the ability to be sterilized, and are easily cleaned. Stainless steels are very common because they do not rust, have low or no magnetic properties, and are machinable. Some grades of stainless can be further heat treated to enhance hardness. Materials like titanium offer high strength-to-weight ratios that benefit handheld, wearables, and implantable medical devices.
Name Stainless Steel 316/L | Description Stainless Steel 316/L is a highly corrosion-resistant steel popular for medical devices. |
Name Stainless Steel 304 | Description Although one of the most widely used stainless steel alloys due to a great balance of corrosion resistance and machinability, stainless steel 304 cannot be heat treated for hardening. 18-8 stainless steel is recommended if hardening is required. |
Name Stainless Steel 15-5 | Description 15-5 stainless steel offers corrosion resistance similar to Stainless 304. Improved workability, hardness, and high corrosion resistance. |
Name Stainless Steel 17-4 | Description Stainless steel 17-4 is a high strength, corrosion-resistant stainless alloy that easily heat treatable. This material is typically used in medical equipment. |
Name Titanium Grade 2 | Description Titanium grade 2 is a high strength, low weight, and high thermal conductivity metal. It is is a high purity, non-alloy material. |
Name Titanium Grade 5 | Description Excellent strength-to-weight ratio and the high aluminum content in Ti-6Al-4V increases its strength. This is the most commonly used titanium, offering good corrosion resistance, weldability, and formability. |
CNC Machining Medical Parts
Whether a medical or dental project requires machined titanium or slippery PTFE, manufacturing platforms like Xometry can instantly price, provide lead times, and allow for custom certifications and inspection all in one interface. Xometry takes the guesswork out of choosing the best material with its knowledgable engineers and extensive design-for-manufacturing resources. The platform also helps you choose the best machine shop by pairing the work ordered through its AI-driven quoting platform with the best manufacturing partner for that project.
