Manufacture Aerospace & Defense Parts
with Confidence
Accelerate procurement with vetted manufacturers on demand
ITAR
CMMC Level 2
JCP
AS9100D
ISO 9001:2015
ISO13485:2016
IATF 16949:2016
Xometry Instant Quoting Engine® is covered by U.S. Patent Numbers shown here.
Xometry values your privacy and security. Learn more.
Secure Platform
FedRAMP-compliant AWS hosting with FISMA High and DoD Impact Level 5 authorization.
Scale Without Limits
On-demand capacity for processes and specialized materials like titanium or Inconel.
Sourcing Precision
Use regional filters to manage your supply chain and select sourcing locations.
End-to-End Quality
Guaranteed transparency from initial order to final part delivery.
Industry Experience
Xometry partners with 85% of Fortune 500 aerospace and defense companies.
Massive Network Capacity
Thousands of vetted US manufacturing partners with top certifications, including AS9100D, ISO 9001:2015, NADCAP, ITAR/EAR, DFARS, NIST SP 800-171, CMMC Level 2, and CUI/JCP.
Xometry's Instant Quoting Engine®
Get DFM feedback, lead times, and instant pricing quotes. Xometry Instant Quoting Engine® helps you choose the best price and lead time for your project.
CNC Machining
Trusted Precision: Sub ±0.001′′ Accuracy
Get precision components built with certified processes, whether you’re ordering critical sustainment parts or scaling to full-rate production.
  • Tight tolerances for metal or plastic parts, finished to exact specs
  • Scalable capacity to meet surge and long-term program demands
Learn More
Innovate and Scale Quickly
Specialized additive manufacturing processes deliver critical parts faster and bypass legacy supply chain gaps.
  • Access high-performance materials, including titanium, Inconel, ULTEM, Antero, and high-temp resins
  • Zero minimums for traceable, launch-ready parts produced in as little as 24 hours
  • Includes: DMLS, FDM, SLS, SLA, and more
Sheet & Tube Fabrication
One Source for Complex Assemblies
One partner to cut, form, finish, weld, and assemble precise components that are both strong and light.
  • Tight tolerances (sub ±0.005”) on mission-ready, high-durability parts
  • MIL-spec finishes that safeguard hardware for long-term field deployment
  • Includes: laser sheet and tube cutting, bending, welding, mechanical assembly, and more
Injection Molding
Flexible Tooling for Tactical System Readiness
This process delivers high-volume production with tight tolerances, repeatable performance, and disciplined quality controls suited for demanding defense applications. It supports rugged engineering resins, ESD-safe and conductive materials, along with compliant finishing options for field-deployed systems.
  • Tooling pathways from rapid tooling to full-rate production
  • Expert DFM support and structured program management aligned to defense requirements
  • Applications: tactical electronics housings, insert and overmolding, ruggedized enclosures, and more
High-Volume Metal Production
Custom Metal Parts at Scale
Take advantage of specialized tooling for die casting, metal stamping, and extrusion to deliver high-strength, field-hardened components.
  • Unlock capacity for full-rate production and rapid surge requirements
  • Multiple high-volume metal processes sourced on one platform
  • Reliable production of high-strength components for defense-grade systems
  • Includes: metal stamping, metal extrusion, and die casting
End-Use Production
Custom-Made Aerospace Parts
  • Leverage a network of AS9100D and NADCAP-certified manufacturers to produce parts with full material and process lot traceability.
  • Scale from single flight parts to full production runs for aircraft OEMs and satellite operators, utilizing CMM and First Article Inspection (FAI) to guarantee quality and safety.
  • Sensitive flight hardware data is encrypted and handled only by qualified domestic partners, in full compliance with ITAR and DFARS.
Replacement Parts
Maintain Mission Readiness and Address Obsolescence
  • Source mission-critical replacement parts for aging platforms and legacy systems, eliminating supply chain obsolescence.
  • Use legacy drawings or reverse-engineering to access hard-to-find components and minimize equipment downtime.
  • Support your ongoing needs with secure, scalable production runs through our domestic network.
Rapid Prototyping & Design Validation
Accelerate Innovation and Design Validation
  • Scale from a validated prototype to certified, full-scale production.
  • Run "fit check" gauges and functional testing to reduce time-to-market for complex aerospace & defense systems.
Vetted Supplier Recruiting
Drone Part Manufacturing
Real Stories, Real Impact
Chat with an expert
Phone
+1-800-983-1959
Email
hello@xometry.com
