ResourcesDesign GuidesDesign Guide: Urethane Casting
Urethane casting produces end-use, rigid or flexible plastic parts with high durability, fast lead times, and production-level quality for your parts. We’ve created this guide to give you tips on creating highly accurate parts with a wide variety of cosmetic finish options.
Download the Guide
Urethane Casting
Urethane casting provides end-use, rigid, or flexible plastic parts with production-level quality. Built without expensive and time-consuming hard tooling, our urethane casting process uses a 3D printed master pattern and silicone molds to deliver high-quality, short-run parts up to 30” long. We’ve created this guide to give you tips on creating highly accurate parts with a wide variety of high-quality cosmetic finish options.
  • Overview
  • Typical build process
  • General tolerances
  • Wall thickness
  • Drafts
  • Letters and logos
  • Ribs
  • Radii and fillets
  • Inserts
  • Materials and finishing options
  • Additional resources at Xometry
About Xometry
Xometry supports any urethane casting process, material or finish you could need. Our extensive network of SLA and Polyjet 3D printing partners means we can handle everything from the master pattern and mold-making, to the production casting of parts and custom finishes. With more than 4,000 vetted manufacturing partner facilities across the U.S., Xometry is able to pair your part order with the machine shop best suited to handle the quality, surface finishes, performance, and color requirements you need — resulting in competitive prices and ideal lead times for your projects.
Xometry X Logo
Quick Links
  • Home
  • Contact Us
  • Help Center
  • About Us
  • Careers
  • Press
  • Investors
  • Xometry Go Green
