Nylon 3D Printing Service
Get instant online quotes on parts in nylon materials. Free shipping on all US orders. ISO 9001:2015, ISO 13485, IATF 16949:2016, and AS9100D certified.
Close-up of glass filed SLS PA12.
About 3D Printing Nylon
3D printed nylon comes in many different forms, namely as a filament for FDM (fused deposition modeling) or as a powder for SLS (selective laser sintering) and MJF (HP Multi Jet Fusion) printing. 3D printing nylon creates parts with excellent properties but it’s important to understand that the type of 3D printing process will determine the final part capabilities. For example, FDM prints will have an anisotropic structure caused by the extruded layer lines. Even SLS-printed parts will have a level of anisotropy between layers. MJF parts tend to have isotropic properties, meaning the material will behave the same regardless of the direction of the load. However, with correct setups and part orientation, anisotropic effects can largely be negated and parts can benefit from the excellent properties of nylon.
Nylon is a high-performance engineering thermoplastic found in a wide range of industries. Its popular usage stems from its excellent abrasion resistance, high fatigue resistance, and high load-bearing capacity. Due to these properties, 3D printing in nylon is a great way to make lightweight industrial and medical implements that are just as capable as heavier metal ones.
3D Printed Nylon at a Glance
ApplicationsAdvantagesDisadvantagesLead TimePriceLayer HeightBuild Envelope
Applications
Gears, screw elements, siding-contact components, snap fits.
Advantages
Low friction coefficient, excellent toughness, high impact resistance.
Disadvantages
Prone to moisture absorption; can warp during printing.
Lead Time
1 - 4 Days Typical. Economy options are available.
Low. Bulk pricing applies to higher quantities.
Layer Height
MJF: 0.0031"
SLS: 0.0047"
FDM: 0.007" - 0.013"
Build Envelope
MJF: 15 x 11 x 15"
SLS: 26" x 15" x 23"
FDM: 24” x 36” x 36”
Information based upon US-based services.
Nylon 3D Printing Materials
Xometry’s custom nylon 3D printing service is offered in a wide range of nylon materials, including MJF nylon 11 EX, FDM nylon 12, SLS nylon 12, and many more.
MJF Nylon 11 EX
Nylon 11 EX for MJF-printed parts has good mechanical properties with excellent chemical resistance and low moisture absorption rates. It is resilient and can deform to a much larger extent than other nylons, making it ideal for snap-fit components.
MJF Nylon 11 Properties
Tensile Strength (MPa)Elongation at Break (%)Hardness (Shore D)Heat Deflection Temperature (℃)Melting Point (℃)
52
55
Hardness (Shore D)
80
185
Melting Point (℃)
202
Properties apply to US-based production.
MJF Nylon 12
This MJF nylon offers good dimensional stability and maintains its mechanical properties over a long period of time. Parts printed from this material can be watertight, making them ideal for electronic housings that need to prevent moisture ingress.
MJF Nylon 12 Properties
48
20
Hardness (Shore D)
80
175
Melting Point (℃)
187
MJF Nylon 12 Glass Filled
The grade of MJF nylon 12 has glass beads included as a filler material. This increases the material’s overall stiffness and hardness and reduces its tendency to warp during printing. Its stiff nature makes it ideal for fixtures and tooling.
MJF Nylon 12 Glass Filled Properties
Tensile Strength, Yield (MPa)Elongation at Break (%)Hardness (Shore D)Heat Deflection Temperature (℃)Melting Point (℃)
30
10
Hardness (Shore D)
82
174
Melting Point (℃)
186
FDM Nylon 12
This resilient grade of FDM nylon is highly resistant to shocks and fatigue. It is ideal for tough applications that undergo multiple load/unload cycles or that experience a great deal of vibration.
FDM Nylon 12 Properties
32
30
Hardness (Shore D)
N/A
75
Melting Point (℃)
178
SLS Nylon 12 (PA 2200)
Much like its MJF counterpart, this SLS nylon offers good dimensional stability and maintains its properties over a long period of time. It does have a higher level of anisotropy than MJF and this must be taken into account when designing parts using this material. The upside is that it exhibits greater tensile strength than MJF nylon 12 version.
SLS Nylon 12 (PA 2200) Properties
48
18
Hardness (Shore D)
75
154
Melting Point (℃)
176
SLS Nylon 12 Glass Filled
As with any glass-filled material this SLS nylon has improved stiffness and hardness. It has a higher tensile strength than MJF nylon glass-filled but will not deform much before breaking. It is also highly resistant to chemical reactions.
38.1
2
Hardness (Shore D)
80
179
Melting Point (℃)
185
SLS Nylon 12 AF (PA 605-A)
This nylon for SLS printing has the unique property of being aluminum-filled and thus creates parts with a surface finish similar to cast aluminum, also gaining much of the metal’s excellent thermal conductivity. This makes it ideal for tooling, fixtures, or automotive components that get exposed to elevated temperatures.
SLS Nylon 12 AF Properties
N/A
3
Hardness (Shore D)
76D
180
Melting Point (℃)
181
SLS Nylon 12 CF (PA 602-CF)
This nylon for SLS printing uses carbon as its filler material. This has the benefit of stiffening the material and reducing overall part weight while also being highly resistant to warping at high temperatures. This makes it ideal for applications that demand low weight like sports equipment or racing components.
SLS Nylon 12 CF (PA 602-CF) Properties
Ultimate Tensile Strength (MPa)Elongation at Break (%)Hardness (Shore D)Heat Deflection Temperature (℃)Glass Transition Temperature (℃)
85
4
Hardness (Shore D)
N/A
179
N/A
SLS Nylon 12 HST (PA 620-MF)
SLS nylon 12 HST (PA 620-MF) contains mineral fibers that increase stiffness and maintain a high strength rating while also allowing for high-temperature operations. This makes it ideal for tooling or aerospace applications.
SLS Nylon 12 HST (PA 620-MF) Properties
Ultimate Tensile Strength (MPa)Elongation at Break (%)Hardness (Brinell)Heat Deflection Temperature (℃)Melting Point (℃)
51
5
Hardness (Brinell)
75
184
Melting Point (℃)
184
Finishes
Xometry offers a wide range of surface finishes for printing nylon, some of which are listed below. Follow this link to learn about our other finishing options.
Standard: This type of finish is possible for all 3D printing technologies listed above. Printing supports are removed from the part, but no additional work is done to the finish. Note that SLS and MJF parts have much better off-the-machine finishes than FDM and do not require the removal of support structures.
Color Dyeing: Parts are submerged in a dye solution that penetrates roughly ~0.010” into the surface, altering the surface’s color. Coloration may vary slightly from batch to batch. Available for SLS and MJF nylon parts.
Vapor Smoothing: Vapor smoothing creates a uniform, sealed surface with a semi-gloss appearance. It can be combined with our color dyeing option. Available for SLS and MJF nylon 12 parts.
Nickel plating: This surface treatment is not for cosmetic applications as it creates a rough nickel finish. However, it adds additional durability, stiffness, and wear resistance. This finish is only available for SLS nylon parts.
    Samples of SLS PA12 dyed in various colors.
    Cost-saving Design Tips
    DFM: Each type of 3D printing technology requires special considerations during the design phase. FDM parts, for example, may need additional support as well as consideration for which layer orientation will generate maximum strength. SLS parts need drain holes to remove unused powder from internal cavities. Design-for-manufacturability (DFM) principles need to be applied from the start.
    Choose the right plastic and process: Each of the above plastics and machine combinations is better suited to certain applications. If the goal is to produce a temporary tooling jig then FDM may be the best option. However, if a visual prototype is required, then SLS or MJF may better suit your needs.
      quote engine
      Need Parts 3D Printed in Nylon?
