CapabilitiesCustom Online 3D Printing ServiceStainless Steel 3D Printing
Get instant online quotes on stainless steel 3D printed parts. Free shipping on all US orders. ISO 9001:2015, ISO 13485, and AS9100D certified.
About Stainless Steel Metal 3D Printing
3D printing stainless steel is commonly done using DMLS (direct metal laser sintering) technology which works by fusing individual layers of powder together with a laser until the part is complete. Stainless steel parts created with this method have the same density as cast versions of the metal—there are no porosity problems. Solution annealing is not required as parts come off the machine with the necessary properties.
3D Printed Stainless Steel at a Glance
DMLS Stainless Steel 316L
Stainless steel 316L is a steel alloy that is well known for its exceptional chemical and environmental resistance. This makes it ideal for complex medical applications as well as consumer-grade products. SS316 is however not suitable for temperatures between 427°C and 816°C. Parts made using stainless steel 3D printing can be polished and machined. Typical applications include spectacle frames, turbine blades, and components exposed to corrosive chemicals.
DMLS Stainless Steel 316L Properties
Tensile Strength, Yield (MPa)
640 ± 50
Fatigue Strength (MPa)
530 ± 60
Elongation at Break (%)
40 ± 15
Hardness (Brinell)
89
Density (g/cm^3)
7.9
DMLS Stainless Steel 17-4
Stainless steel 17-4 is precipitation-hardened stainless steel with good corrosion resistance and high strength (much higher than that of stainless steel 316L). Further heat treatment can increase the material strength to over 1300 MPa. This material is used in parts that need significant strength but must avoid carbon steel’s propensity for rusting. Surgical instruments are the most common items made from this material.
DMLS Stainless Steel 17-4 Properties
Tensile Strength (MPa)Yield Strength (MPa)Elongation at Break (%)Hardness (Brinell)Density (g/cm3)
886 ± 70.4
860.6 ± 75.7
19.9 ± 1.2
Hardness (Brinell)
247
Density (g/cm3)
7.79
Finishes
Stainless steel 3D printing results in parts with a density equal to that of machined steel. They can also be machined or polished in the same fashion.
Standard: Standard finishing refers to the removal of any support structures. The surface of the part is also medium blasted to create a uniform appearance.
CNC Machining or Polishing: In some cases, specific features can be machined or polished using a CNC unit. However, these are evaluated on a case-to-case basis.
    Cost-saving Design Tips
    To save money when stainless steel 3D printing, consider the following cost-saving tips:
    DFM: Design-for-manufacturing (DFM) principles are important. When designing parts for metal 3D printing, make sure that any enclosed areas have holes from which to remove unfused powder after printing.
    Material Choice: DMLS stainless steel 3D printing can produce high-strength functional parts, but it is not cheap. Ensure that stainless steel is necessary for your application over cheaper 3D printing metals like stainless steel or composite metals printed with binder jetting.
      design icon
      Need to 3D Print Stainless Steel?
