CapabilitiesCustom Online 3D Printing ServiceResin 3D Printing Production Service
3D Print End-Use Production Parts Using Our Advanced Photopolymer Technologies and Materials
Free Shipping on All US Orders
  • Processes Available
  • General Purpose Resins
  • Engineered Resins
  • Flexible & Rubber-Like Resins
  • Why Xometry?
New!
Unlock Tooling-Free Production With 3D Printing
With Xometry, you can access advanced 3D printing technologies such as Carbon DLS™ and Nexa3D LSPc®, which offer industry-leading printing speeds and quality. Combined with a vast selection of engineering-grade photopolymer materials, these technologies can create parts that will hold up to end-use applications and environments. With production printing, there is no need to invest in expensive tools or molds, which means economic parts are in your hands more quickly than traditional production processes like injection molding.
Our production photopolymers are excellent choices for parts from various industries, including:
  • Medical & Dental
  • Automotive
  • Aerospace
  • Robotics & Electronics
  • And more!
Additive Production Processes
Some photopolymer printing technologies, such as Stereolithography (SLA) and PolyJet, are excellent for creating detailed prototypes or lifelike concept models; however, they are not typically suitable for end-use or production applications. That is where our Digital Light Synthesis™ (DLS) and Lubricant Sublayer Photo-curing® (LSPc) processes come in. Not only do these technologies print extremely fast and accurately, but their engineering-grade resins cover a wide range of properties that can be chosen to suit your project's specific needs. You can learn more about each of these processes in the section below.
    Carbon Digital Light Synthesis™ (DLS™)
    Carbon uses digital light projection, oxygen-permeable optics, and programmable liquid resins to produce products with end-use durability, resolution, and surface finish. The digital light synthesis process is continuous, without stopping layer-by-layer, as with most additive manufacturing. This gives the parts isotropic properties, meaning that strength is even regardless of orientation. DLS™ materials are urethane-based or epoxy-based, giving excellent mechanical properties, including elastomer and silicone resins that outperform most additive-manufactured rubber-like materials. Secondary thermal processing steps activate dormant epoxies or urethanes, making them much more robust than UV-curing alone. Along with Carbon's custom liquid resins, this technology unlocks new business opportunities and product designs previously impossible, including mass customization and on-demand inventory of end-use products.
    Nexa3D Lubricant Sublayer Photo-curing® (LSPc)
    LSPc® uses a LED (light-emitting diode) array as a light source and an LCD (liquid crystal diode) photomask to selectively shape image layers. The images pass through a membrane on which layers of photopolymer resin are cured. The key to Nexa3D's LSPc technology is their proprietary Everlast membrane designed to minimize peel and separation forces during printing. This specialized membrane is chemically inert and flexible. It does not rely on oxygen-permeable elements for lubricity, which enables LSPc technology to print in a wide range of resins with unparalleled speed and efficiency. Nexa3D's open material platform has various engineered materials, most of which do not require additional post-processing steps other than a standard UV cure to achieve final part properties.
    Nexa3D LSPc
    Nexa3D LSPc® Resin 3D Printing Service
    Blazing Fast Parts Made From Production Photopolymers Free Shipping on All US Orders
    Carbon Digital Light Synthesis (DLS) makes production parts without tooling
    High-Performing Prototypes and Serialized Production Parts Free Shipping on All US Orders
    Ready to Start Production?
    Production Photopolymers Offered By Xometry
    Xometry offers a wide selection of photopolymer materials suitable for production parts. Our options comprise specially engineered resins, polyurethane, and epoxies designed for practical end-use applications. The characteristics and properties of each vary greatly, allowing you to select the perfect material for your unique application. The chart below lists our standard production photopolymer options and can help you determine the right choice for your project.
    General Purpose
    Material NameProcessCharactersticsUse Case ExamplesElongation At Break (%)Data Sheets
    Material Name
    UMA 90
    Process
    Carbon DLS™
    Characterstics
    Single-cure resin, customizable color options, tougher than most SLA resins
    Use Case Examples
    Prototyping, jigs, fixtures, general purpose
    17%
    Data Sheets
    Material Name
    RPU 70
    Process
    Carbon DLS™
    Characterstics
    High flexural strength, tough, moderate heat resistance
    Use Case Examples
    Housings, mechanical features, guides, end-use
    100%
    Data Sheets
    Material Name
    xABS3843
    Process
    Nexa3D LSPc®
    Characterstics
    Good flexural & elongation, weather resistant
    Use Case Examples
    Housings, brackets, arms and levers, general purpose
    50%
    Data Sheets
    Material Name
    x45
    Process
    Nexa3D LSPc®
    Characterstics
    Good toughness, fast processing speed
    Use Case Examples
    Rapid prototyping, jigs, general purpose
    >12%
    Data Sheets
    Material Name
    xPRO410
    Process
    Nexa3D LSPc®
    Characterstics
    High dimensional accuracy, detailed surface finish, rigid and stiff
    Use Case Examples
    Functional prototypes, display models, consumer goods
    5.5%
    Data Sheets
    Material Name
    xMODEL17 Clear
    Process
    Nexa3D LSPc®
    Characterstics
    High-clarity clear/translucent, fine detail
    Use Case Examples
    Prototyping, packaging concepts, lighting applications
    22%
    Data Sheets
    Engineered Resin Photopolymers
    Material Name
    EPX 82
    Process
    Carbon DLS™
    Characterstics
    High chemical resistance, impact strength & toughness, good temperature resistance
    Use Case Examples
    Automotive housings and connectors, parts for use in industrial environments
    5.9%
    Data Sheets
    Material Name
    xPEEK147
    Process
    Nexa3D LSPc®
    Characterstics
    Excellent heat resistance (HDT 230C), very stiff, good toughness
    Use Case Examples
    Tooling and high heat applications, general end-use
    3%
    Data Sheets
    Material Name
    xESD
    Process
    Nexa3D LSPc®
    Characterstics
    Static-dissipative, stiff and tough
    Use Case Examples
    Electronic housings, electro mechanical, robotics
    3.8%
    Data Sheets
    Material Name
    xPP405
    Process
    Nexa3D LSPc®
    Characterstics
    High elongation & toughness, durable, available in clear
    Use Case Examples
    Snap fits, consumer goods, manufacturing aids, packaging
    100%
    Data Sheets
    Material Name
    FPU 50
    Process
    Carbon DLS™
    Characterstics
    Excellent elongation, impact and fatigue resistant
    Use Case Examples
    Repetitive stress applications, living hinges, friction fits, clips
    280%
    Data Sheets
    Material Name
    xCERAMIC3280
    Process
    Nexa3D LSPc®
    Characterstics
    Ceramic composite-filled, excellent rigidity and heat deflection (HDT 280C @ 0.45Mpa)
    Use Case Examples
    Electronic housings and enclosures, wind tunnel testing models, mold tooling
    0.5%
    Data Sheets
    Flexible & Rubber-Like Materials
    Material Name
    EPU 40
    Process
    Carbon DLS™
    Characterstics
    Extremely durable rubber-like, excellent elongation, Shore 68A
    Use Case Examples
    Buttons, grommets, strain reliefs
    310%
    Data Sheets
    Material Name
    SIL 30
    Process
    Carbon DLS™
    Characterstics
    Tear-resistant silicone urethane elastomer, Shore 35A durometer
    Use Case Examples
    Wearable devices, cushioning, gaskets
    330%
    Data Sheets
    Material Name
    xFLEX402
    Process
    Nexa3D LSPc®
    Characterstics
    Semi-firm rubberlike, good springiness and rebound, Shore 73A durometer
    Use Case Examples
    Bumpers, protective casing, elastomeric inserts
    230%
    Data Sheets
    Material Name
    xFLEX475
    Process
    Nexa3D LSPc®
    Characterstics
    Soft rubber-like, tear resistant, Shore 44A durometer
    Use Case Examples
    Shoe midsoles, handle grips, seals, gaskets
    150%
    Data Sheets
    More materials are available! Select "Other" when quoting for custom requests.
    Why Choose Xometry for Your Production Needs?
    Production Photopolymer Design Resources
    Nexa3D LSPc® Design TipsCarbon DLS™ Design GuideProduction 3D Printing Infographic
    Quick Links
    • Home
    • Contact Us
    • Help Center
    • About Us
    • Careers
    • Press
    • Investors
    • Xometry Go Green
