CapabilitiesCustom Online 3D Printing ServiceCarbon Digital Light Synthesis™ (DLS™) 3D Printing Service
High-Performing Prototypes and Serialized Production Parts
Free Shipping on All US Orders
  • Materials
  • Applications and Benefits
  • Sizes and Tolerances
  • About Carbon Digital Light Synthesis™
  • Download Guide
Overview: What is Carbon DLS™ Technology?
Carbon DLS™ Technology Basics
Carbon uses digital light projection, oxygen-permeable optics, and programmable liquid resins to produce products with end-use durability, resolution, and surface finish. This 3D printing technology is called Digital Light Synthesis™, or DLS for short. Another legacy term for the process is Continuous Liquid Interface Production (CLIP). Along with Carbon’s custom liquid resins, DLS unlocks new business opportunities and product designs previously impossible, including mass customization and on-demand inventory of end-use products.
    Isometric illustration of the carbon DLS printing process.
    DLS™ Materials
    DLS™ Materials Available at Xometry:
    Material NameDescriptionShore HardnessElongation at Break (%)Impact Strength (J/m)Data Sheets
    Material Name
    RPU 70
    Description
    Rigid polyurethane
    Shore Hardness
    80D
    100%
    22 J/m
    Data Sheets
    Material Name
    UMA 90
    Description
    Urethane methacrylate
    Shore Hardness
    86D
    17%
    33 J/m
    Data Sheets
    Material Name
    EPX 82
    Description
    Impact-resistant epoxy
    Shore Hardness
    89D
    5.9%
    44 J/m
    Data Sheets
    Material Name
    FPU 50
    Description
    Flexible polyurethane
    Shore Hardness
    71D
    280%
    40 J/m
    Data Sheets
    Material Name
    EPU 40
    Description
    Elastomeric polyurethane
    Shore Hardness
    68A
    310%
    N/A
    Data Sheets
    Material Name
    SIL 30
    Description
    Elastomeric silicone-urethane
    Shore Hardness
    35A
    330%
    N/A
    Data Sheets
    More carbon 3D materials are available upon request by selecting Material: Other and writing in the specific resin on your online quote.
    Available Finishes for Carbon DLS™ Parts
    Standard
    Parts built with Carbon DLS technology will typically have a matte to semi-gloss surface finish depending on feature direction. Extended protrusions will show vertical lines in the part that are parallel to the direction of growth. Supports are removed and mitigated as required.
    Custom Color (UMA 90)
    UMA 90 materials come in different colors available for custom mixing. Although the standard is black or white, other solid colors can be available for part productions.
    Custom
    Applications for Carbon DLS™ Technology
    Fast parts and fast shipping
    Carbon DLS™ technology can be used to create strong, flexible, and colorful prototypes
    End-Use Functional Parts
    Carbon DLS™ materials are fully dense and engineered for end-use
    Digital manufacturing
    Direct Digital Manufacturing
    Carbon DLS™ printing is ideal for serialize production of small to medium-sized parts
    Benefits of Carbon DLS™ 3D Printed Parts
    Carbon DLS RPU 70 rigid polyurethane
    Engineered Materials
    3D print directly in urethanes, epoxies, elastomers, and other specialty thermosets.
    Complex Shapes and Lattices
    Carbon DLS CE with complex lattice features
    Best-in-class at 3D printing of lattice structures and organic shapes.
    Scalability
    Carbon Digital Light Synthesis (DLS) makes production parts without tooling
    Produce small parts in serialized production at pricing competitive with injection molding.
    Carbon DLS™ General Tolerances
    DescriptionTolerance Notes
    Description
    General Tolerances
    Tolerance Notes
    +/- 0.003” for the first inch is typical, plus +/- 0.010” for every inch thereafter**.
    **See Our Manufacturing Standards for more detailed DLS tolerances.
    Description
    Build Size
    Tolerance Notes
    Description
    Ideal Part Size
    Tolerance Notes
    Part's below 2" x 1" x 3" or smaller tend to have the best production economy of scale.
    Description
    Minimum Wall Thickness
    Tolerance Notes
    0.030" or larger is suggested for any walls, text, or lattice features.
    Description
    DLP Pixel Resolution
    Tolerance Notes
    Approx. 0.005" square
    This table depicts the general tolerances for Digital Light Synthesis™. Stresses during the build, support strategy, and other geometry considerations may cause deviation in tolerances and flatness. Improved tolerances may be possible with a manual quote review, after successful completion of a prototype build, and must be approved on a case-by-case basis. General tolerances apply before secondary finishing or post-processing unless otherwise specified. Please check out Xometry's Manufacturing Standards for more information on tolerances per process.
    What Differentiates Carbon
    What differentiates Xometry's Carbon DLS 3D printing service from similar processes like Stereolithography (SLA) or PolyJet 3D prints is that the resin has a secondary thermal step which activates dormant epoxies or urethanes, making parts much stronger than UV-curing alone. Additionally, the digital light synthesis process is continuous, without stopping layer-by-layer as with most additive manufacturing. This gives the parts isotropic properties, meaning that strength is even regardless of orientation. This is a significant advantage over processes like Fused Deposition Modeling (FDM), where Z-direction features can be much weaker than similar features built in the XY-direction.
      Carbon DLS UMA
      Why Choose Xometry for 3D Printing?
      Download the Carbon DLS™ design guide
