CNC Machining in China
High-quality machined parts made in China | Take the complexity out of sourcing CNC parts in China with Xometry's managed service
Custom China CNC Machining Services With Xometry
Xometry's highly-vetted overseas network of CNC machining suppliers makes high-quality parts to spec and can meet a range of budget and lead time needs. Our US-based team handles the communication with the Chinese facility and fully manages your order from quote to delivery. If you want domestic CNC machining, we have that as an option as well. Simply specify the geography you want on the quoting form.
CNC Services offered in China include:
- ISO 9001 and ISO 13485 registered facilities
- Milling, turning, lathe, grinding, and routing
- 3-axis, 4-axis, and 5-axis options are available
- Small and large parts
We help you navigate the complexities of CNC machining in China. Our skilled team of engineers:
- Understands your end-use (prototype, saleable, low to high volume) and helps identify the right manufacturing solution
- Works with you to find the right Chinese supplier based on your unique needs
- Manages all communication with the overseas supplier so you don't have to. We have team members on the ground in China to help manage your project
For an instant quote and design-for-manufacturability feedback, please upload your CAD file. We want to earn your business. If you get a lower CNC machining quote, send it to us and we will try to beat it.
Xometry's Chinese CNC Machining Services
Custom CNC Milling Services
CNC Turning Service
Frequently Asked Questions About Machining in China
Will I get finishing certs when my CNC parts are made in China?
- No. Xometry does not provide finishing certs for parts that are made in China.
Is there a quality difference between parts that are made in the US vs parts that are made in China?
- No. All Xometry parts will meet the Xometry Manufacturing Standards regardless of country of origin.
Does Xometry collect duties and tariffs?
- Yes. Duties and tariffs are included in your part price. You are not required to pay any additional fees.
Does Xometry inspect parts from China?
- All parts made in China are manufactured and inspected in accordance with Xometry's Manufacturing Standards and our Inspection & Sampling Plan.
CNC Machining Finishes Available in China
Standard Finish (as-milled)
Bead Blast
Tumbled
Type II (MIL-A-8625/MIL-PRF-8625, Type II) creates a corrosion-resistant finish. Parts can be anodized in different colors—clear, black, red, and gold are most common—and is usually associated with aluminum. Type III (MIL-A-8625/MIL-PRF-8625, Type III, Class 1/2 "hardcoat") is thicker and creates a wear-resistant layer in addition to the corrosion resistance seen with Type II.
Titanium Anodize
PTFE Impregnated Hard Anodize
Chem Film
Passivation
Powder Coat
Electropolishing
Electroless Nickel Plating
Silver Plating
Gold Plating
Zinc Plating
