CapabilitiesCustom Online CNC Machining ServicesCNC Turning Service
CNC Turning Service
Instant quotes on custom metal and plastic turned parts | Quick-turn prototypes and production parts in days | Free standard shipping on all US orders | International prototype pricing includes tariffs | ISO 9001:2015, ISO 13485, IATF 16949:2016, AS9100D certified. ITAR registered.
  • Materials
  • Applications and Benefits
  • Tolerances
  • About CNC Turning
  • Download Guide
CNC Turning with Xometry
With access to a network of over 10,000 shops, including those with CNC lathes and turning centers, Xometry provides you with the capacity and capabilities your project needs, while also delivering the most competitive pricing and lead times. Xometry's machine learning-trained technology platform also provides instant manufacturability feedback to ensure that your part is optimized for the CNC turning process and fits the requirements you need.
Our on-demand manufacturing platform can deliver high-quality metal and plastic CNC turning parts for rapid prototyping or low-to-high volume production runs. Get an instant quote from your 3D CAD file today. The price for your turned prototypes includes tariffs and shipping for standard parcels.
    Xometry CNC Materials
    MaterialAvailable Varieties
    Material
    Available Varieties
    Aluminum 5052,
    Aluminum 7075,
    Aluminum 7075-T6,
    Aluminum 6063-T5,
    Aluminum 7050-T7451,
    Aluminum MIC-6,
    Aluminum 6061-T6,
    Aluminum 2024-T3
    Material
    Brass/Bronze
    Available Varieties
    Brass C360,
    Brass 260,
    C932 M07 Bearing Bronze
    Material
    Copper
    Available Varieties
    EPT Copper C110,
    Copper 101
    Material
    Plastics
    Available Varieties
    ABS,
    Acetal [Delrin],
    Acrylic,
    G-10 Garolite,
    Nylon 6/6,
    PEEK,
    Polycarbonate,
    PTFE [Teflon],
    Polypropylene,
    Ultra-High Molecular Weight, Polyethylene
    Material
    Steel
    Available Varieties
    Alloy Steel 4130,
    Alloy Steel 4140,
    ASTM A36,
    Stainless Steel 15-5,
    Stainless Steel 17-4,
    Stainless Steel 18-8,
    Stainless Steel 303,
    Stainless Steel 304,
    Stainless Steel 316/316L,
    Stainless Steel 416,
    Stainless Steel 420,
    Steel 1018,
    Steel A36
    Material
    Titanium
    Available Varieties
    Titanium Grade 2,
    Titanium 6Al-4V
    Material
    Zinc
    Available Varieties
    Zinc Sheet Alloy 500
    Additional alloys and tempers are available upon request. We can source to your project specifications.
    Custom Sourced Materials
    Various CNC-turned metal and plastic part options are available for an instant online quote. If you do not see the material stock you are looking for, please choose "Other" under the material drop-down on your quote page and submit for an expert engineering review once you have specified features, tolerances, inspection needs, and quantities required.
    Finishes
    As-Milled
    Bead Blast
    Powder Coat
    Custom
    Don’t see the finish you need? Submit an RFQ and we’ll look into a finishing process for process for your custom lathe work.
    Ready to get started on your CNC turning quote?
    Applications of CNC Turning
    Rapid Tooling
    Because CNC can be applied to virtually any material, it is perfect for rapid tooling, i.e., creating fixtures or molds.
    The range of materials available, low cost per unit, and speed of production makes CNC a great option for prototyping.
    Serial Production
    High-quality finish, vast material options, and precise tolerances have made CNC lathe turning a favorable technology for serial production parts.
    Advantages of CNC Turning
    Rapid Turnaround
    Using the latest CNC machines, Xometry produces highly accurate, quick turn parts in as fast as 1 day.
    Custom Finishes
    Select from a variety of finishes on solid metal and plastic parts, built to precise design specifications.
    Material Selection
    Choose from over 50 metal and plastic materials. CNC Machining offers a wide variety of certified materials.
    Precision
    Offers high-precision tolerances ranging from +/-0.001″ – 0.005″, depending on customer specs.
    Scalability
    CNC Machining is perfect for production of 1-10,000 CNC machined parts.
    CNC General Tolearances
    DescriptionGeneral Tolerance
    Description
    Distance Dimensions
    General Tolerance
    For features of size (Length, width, height, diameter) and location (position, concentricity, symmetry) +/- 0.005”.
    Description
    Orientation and Form Dimensions
    General Tolerance
    0-12" +/- 0.005", Angularity 1/2 degree. For 24" and beyond please consult Xometry's Manufacturing Standards.
    Description
    Edge Condition
    General Tolerance
    Sharp edges will be broken and deburred by default. Critical edges that must be left sharp should be noted and specified on a print.
    Please check out Xometry's Manufacturing Standards for more information on tolerances per process. Unless we have agreed to other tolerances in your Quote, we will work to achieve and hold the tolerances noted.
    Overview: What is CNC Turning?
    The Basics Of CNC Lathes
    A CNC lathe machine, also called live tooling lathes, is ideal for cutting any symmetrical cylindrical or spherical parts. Characteristically, a lathe spins a workpiece on a vertical or horizontal axis, while a fixed shaping instrument moves around it on a more or less linear path. The act of cutting a workpiece on a CNC lathe is called turning.
    How CNC Turning Works
    CNC lathes use a subtractive method to create the desired shape. With the G-Code created, a blank bar of stock material is loaded into the chuck of the lathe's spindle. The chuck holds the workpiece in place while the spindle spins. When the spindle is up to speed, a stationary cutting tool is brought into contact with the workpiece to remove material until the desired geometry is achieved.
    There are many operations that can be performed on a live tooling lathe, including facing, threading, knurling, drilling, boring, reaming, and taper turning. Different operations require tool changes and can increase cost and set-up time.
    When all machining operations are completed, the part is cut from the stock for further post-processing. The CNC lathe is then ready to repeat the operation with little-to-no set-up time in between.
    Types Of CNC Lathes
    There are many types of lathes, but the most common are 2-axis CNC lathes and Swiss-type lathes. Swiss-type lathes are unique in that stock material is fed through a guide bushing, allowing the tool to cut nearer to the point of support, which makes them particularly useful for long, slender CNC lathe parts and micromachining. Some Swiss-type lathes also come equipped with a second tool head that operates as a CNC mill, allowing them to perform multiple machining operations without having to move the workpiece to a different machine. This makes Swiss-type lathes extremely cost-effective for complex turned parts with CNC lathe services.
    Benefits Of CNC Turning
    Like CNC mills, CNC lathes can be easily set up for high repeatability, which makes them great for everything from rapid prototyping to low and high-volume production. Multi-axis CNC turning centers and Swiss-type lathes allow for multiple machining operations in one machine. making them a cost-effective option for complex geometries that would otherwise require multiple machines or tool changes in a traditional CNC mill.
      Instant Quote Demo
      See how simple it is to get an instant quote for CNC turning using the Xometry Instant Quoting Engine®.
      Download the CNC Design Guide
