CapabilitiesCustom Online 3D Printing ServiceFused Deposition Modeling (FDM) 3D Printing Service
High-Quality Large Format FDM 3D Printing
1-Day Expedite Available. Free Shipping on All US and International Orders.
  • Materials
  • Applications and Benefits
  • Sizes and Tolerances
  • About FDM
  • Download Guide
What is FDM 3D Printing?
Fused Deposition Modeling (FDM) is an additive manufacturing technology widely known for its speed, accuracy, and competitive cost. FDM machines precisely extrude melted material to create a part. FDM parts can be made in as fast as one day.
Xometry's FDM 3D printing service offers large build volumes up to 24″ x 36″ x 36″ on Stratasys Fortus platforms. FDM 3D printing offers the largest variety of colors and selection of production-grade thermoplastics of any 3D printing process. Material range from general-purpose ABS or ASA to high performing polycarbonate and heat resistant ULTEM.
Fused Deposition Modeling FDM Stratasys Fortus 450 and Fortus 900 3D printing service
Fused Deposition Modeling 3D Printing Materials
FDM Materials Available at Xometry:
Material NameColor(s)Tensile Strength, Yield (XZ MPa-ZX MPa)Elongation at Break (XZ%-ZX%)HDT @ 66 psi (°C)Data Sheets
Material Name
ABS-M30
Color(s)
Black, Blue, Dark Grey, Ivory, Red, White
32 MPa-28 MPa
7%-2%
HDT @ 66 psi (°C)
96 °C
Data Sheets
Material Name
ABS-ESD7
Color(s)
Black (electrostatic dissipative properties)
36 MPa
3%
HDT @ 66 psi (°C)
96 °C
Data Sheets
Material Name
ABSi
Color(s)
Translucent Natural, Translucent Amber, Translucent Red
37 MPa
4.4%
HDT @ 66 psi (°C)
86 °C
Data Sheets
Material Name
ASA
Color(s)
Black, Dark Blue, Dark Gray, Light Gray, Green, Ivory, Orange, Red, White, Yellow
27 MPa
9%-3%
HDT @ 66 psi (°C)
98 °C
Data Sheets
Material Name
Nylon 12
Color(s)
Black
49.3 MPa-41.8 MPa
30%-6.5%
HDT @ 66 psi (°C)
91.9 °C
Data Sheets
Material Name
PC-ABS
Color(s)
Black
41 MPa
6%
HDT @ 66 psi (°C)
110 °C
Data Sheets
Material Name
PC
Color(s)
White
57 MPa-42 MPa
4.8%-2.5%
HDT @ 66 psi (°C)
138 °C
Data Sheets
Material Name
PC-ISO
Color(s)
Translucent Natural, White
57 MPa
4%
HDT @ 66 psi (°C)
133 °C
Data Sheets
Material Name
Prototyping PLA
Color(s)
Black, Blue, Red, White
50 MPa-37 MPa
2.9%-1.9%
HDT @ 66 psi (°C)
55 °C
Data Sheets
Material Name
ULTEM 9085
Color(s)
Black, Tan
47 MPa-33 MPa
5.8%-2.2%
HDT @ 66 psi (°C)
153 °C
Data Sheets
Material Name
ULTEM 1010
Color(s)
Amber (Natural)
64 MPa-41 MPa
3.3%-2.0%
HDT @ 66 psi (°C)
216 °C
Data Sheets
Properties apply to US-based production (Fortus FDM and Desktop FFF). Not all options are available for Xometry's international economy option.
Prototyping PLA
Our available materials include Prototyping PLA, a low-cost, rigid thermoplastic produced via Fused Filament Fabrication (FFF) using an array of desktop 3D printers. Our standard PLA offering comes in four colors: black, red, white, and blue. PLA is great for developing concept models or low-wear indoor products.
Because of lower overhead and material costs, PLA is typically less than half the price of our other FDM options. In exchange, there are trade-offs with lower heat deflection (130°F compared to 186-420°F), lower print volume (~9” max dimension compared to 36”), and fewer plastic options. Keeping that in mind, PLA prints have finer layers, vibrant colors, and quick lead times.
    3D printed polypanels made of PLA.
    Available Finishes for FDM Parts
    Standard
    FDM parts are built with support material that is removed during post-processing. The part surfaces are left with fine layer lines.
    Custom
    Xometry can provide additional processing such as painting or vapor smoothing to meet your needs.
    Video: Quick Tips: FDM 3D Printing
    Greg Paulsen, our Director of Application Engineering, gives a brief overview of FDM 3D Printing.
    FDM Applications
    Concept models
    Concept Models
    The speed and versatility of FDM lets engineers create physical snapshots of their designs.
    Fast parts and fast shipping
    An FDM machine can be used to create durable prototypes that withstand thermal, chemical, and mechanical stress.
    Manufacturing tools
    Manufacturing Tools
    High-performance materials make FDM ideal for producing jigs, fixtures, and production tooling.
    Benefits of Fused Deposition Modeling (FDM)
    Ultem round object
    Precision
    Ultem round object
    We use the most advanced industrial FDM printers designed to meet tolerances of +/- a single build layer thickness (e.g. 0.010") for the first inch and +/- .002” for every inch thereafter.
    Strength
    3D printed strong bracket FDM 3D printing services
    FDM printed parts are available in a variety of high-performance plastics for applications that require resistance to the elements.
    Large Build
    Xometry can produce FDM parts with large build volumes up to 24″ x 36″ x 36″
    Rapid Turnaround
    3D printed FDM jig in ABS-M30 red with COTS handle
    FDM parts do not require tooling which reduces the manufacturing lead time from weeks to days.
    Real Thermoplastics
    FDM ABS-M30 Blue and other materials
    FDM has the highest variety of real engineered thermoplastics.
    Part Production
    Fused deposition modeling FDM production of parts in large format 3D printing build
    An FDM printer is capable of producing end-use parts on-demand, increasing throughput and helping you get to market faster.
    FDM General Tolerances
    General Tolerances for FDM 3D Printing
    Tolerance NoteDescription
    Tolerance Note
    General Tolerance
    Description
    +/- a single build layer thickness for the first inch and +/- .002” for every inch thereafter.
    Tolerance Note
    Build Size
    Description
    Up to 24" x 36" x 36"
    Tolerance Note
    Layer Height, less than 16"
    Description
    0.010" Layers (0.008" for PLA)
    Tolerance Note
    Layer Height, greater than 16" (up to 36")
    Description
    0.013" Layers
    Tolerance Note
    Minimum Wall Thickness
    Description
    0.047"(less than 16"), 0.060" (greater than 16")
    FDM 3D printed parts can be built up to 24" x 36" x 36". Stratasys Fortus 400/450-series machines will produce parts up to 16" and Stratasys Fortus 900MC or F900 platforms are used for parts larger than 16". Prototyping PLA is built on Prusa MK3S/MK4 or Bambu Lab X1C desktop FFF machines with a build volume of 9.8" x 8.3" x 8.3. General tolerances apply before secondary finishing or post-processing unless otherwise specified. To learn more tips about FDM 3D printing, check out our Fused Deposition Modeling (FDM) Design Guide. Applies to US-based production only.
    FDM Infill Options
    Solid
    Light
    Ultralight
    3D Printed Parts
    An Overview of the FDM Process
    How Fused Deposition Modeling Works
    With FDM technology, a spool of the chosen feedstock is introduced to a typical fused deposition modeling system via an extruder, which regulates the feed movement of the polymer to the heater where it melts. This molten polymer is extruded through a nozzle and deposited onto the print bed, also known as the build platform. The extruder, heater, and nozzle are all contained in a printhead which is attached to a gantry above the flat build platform. This is designed to offer relatively high freedom of motion in the X and Y axes as the material is deposited.
    The fused deposition modeling system uses innovative printer software to separate a 3D computer-aided design (CAD) file into individual slices, or cross-sections. Each slice in the file is converted into machine code, which essentially uses the Cartesian coordinate system to determine the path the printer head must follow across the X and Y axes to deposit the first layer of material onto the build platform. Once the bottom layer is complete, the build platform descends by a small amount – relative to the deposited layer thickness – and the printhead repeats the process to deposit the second layer. This procedure is repeated in sequential layers until the part is finished.
    FDM icon
    Most FDM systems have a two-nozzle system that can selectively extrude sacrificial support structures as they part prints. Depending on the feedstock, this support may be soluble in a sodium hydroxide (NaOH) bath, leaving only the printed part after processing. The support structure can also be removed manually without damaging the printed part.
    The benefits of this technique are manifold, particularly when it comes to the development of concept models and rapid prototypes for research and design (R&D) processes.
      Why Use FDM For Your Parts?
      Fused deposition modeling (FDM) is among the most easily accessible and recognizable additive manufacturing technologies worldwide. Available to both 3D printing hobbyists and large-volume manufacturers alike, it is known for its speed and precision in generating three-dimensional polymeric structures using a choice of feedstock materials. The range of filaments available for fused deposition modeling include:
      Acrylonitrile butadiene styrene (ABS-M30, ABS-M30i, ABSi)
      Acrylonitrile styrene acrylate (ASA)
      Polycarbonates (PC, PC-ABS and PC-ISO)
      High-performance plastics (PPSF, Ultem 1010, Ultem 9085, and Nylon-12)
      Benefits Of Fused Deposition Modeling
      FDM printing is a cost-effective additive manufacturing process, especially for rapid prototyping or low-volume production. Since FDM prints require little post-processing and use more readily available materials, leads times from quote to print and delivery are fast.
        Closeup of FDM part
        Why Choose Xometry for FDM 3D Printing?
        Download the FDM design guide
