CapabilitiesCustom Plastic Injection Molding ServiceInsert Molding Service
Make Strong, Functional Prototypes and Production Parts With Insert Molding
  • Materials
  • Applications and Benefits
  • Download Guide
Custom Insert Molding With Xometry
Xometry offers insert mold services as part of its injection molding capabilities. For a free insert molding design review and quote, upload your CAD files. Our expert team of injection molders will get back to you within 24 hours. If you want to learn more about our injection molding capabilities, download our design guide here. If injection molding isn’t the best fit for you, you could also try urethane casting or 3D printing.
Insert Molding is an injection molding process that works especially well for parts that have threaded holes. It can also help you create better wheels, pulleys, fan blades, and other similar parts. Done correctly, insert molding can help:
  • Eliminate assembly: You can make insert molded parts all at once instead of having to do assembly after the fact.
  • Improve reliability: Metal mold inserts will guarantee the function of threads and mitigate wear and tear over the part's life.
Ready to get started on your custom insert molding quote?
Applications for Insert Molding
Part Production
End-Use Functional Parts
Insertion molding creates fully dense, smooth parts with superior mechanical performance.
Scaled Production
Scaled Production
Insert injection molding is best known for its unmatched production capabilities from thousands to millions of identical parts.
Certified Components
We offer ISO 9001, AS9100, ISO 13485, UL, ITAR, and ISO 7 & 8 Medical Clean Room molding.
Insert Molding Process Advantages
  • Durability: Metal inserts will guarantee the function of threads and mitigate wear and tear over the part’s life.
  • Strength: Because it’s a “one-shot” process, insert molding can produce stronger parts than overmolding and other processes.
  • Creating Production Parts: Insert molding is great for creating prototypes and production parts.
Injection Molding Inserts Materials
Other Types of Injection Molding at Xometry
Thermoplastic Injection Molding
Xometry delivers top quality plastic injection molded parts in as little as 10 business days. Our Manufacturing Partner Network can help you design and manufacture tools, dies, and molds for rapid tooling for prototyping to advanced mold making for production runs. Full injection molding capabilities including overmolding, unlimited undercuts, and internal/external threads are available.
Overmolding
Range of Mold Making Options
Our vetted network of partners allow us to quickly convert your 3D part data into a high-quality injection mold at top speed. We offer services from design and manufacturing for tools, dies, and molds for prototyping and production runs. Plastic blow molds, aluminum and steel tooling, 2-shot and 3-shot molding are also available. And with Xometry, you own your own tools, so our partner network also offers mold maintenance services.
Why Choose Xometry for Molded Inserts?
Download the injection molding design guide
