CapabilitiesCustom Plastic Injection Molding ServiceLiquid Silicone Rubber Molding
Manufacture custom silicone prototypes and end-use production parts in 15 days or less in a range of durometers and grades of LSR materials. Subject to availability. Xometry doesn't guarantee that we can provide this service at any given time.
How Does Liquid Silicone Rubber Injection Molding Work?
First, a liquid silicone rubber molding tool is created using CNC machining. This tool must be a high-temperature tool in order to withstand the LSR injection molding process. The tool may then be polished to allow for different finish options.
Next, the finished tool is loaded into an LSR-specific injection molding press that is precision geared for accurate control of shot size to produce the most consistent LSR parts. Materials used include standard silicones and specific grades to fit different part applications. Because LSR is a thermosetting polymer, its molded state is permanent. Unlike thermoplastics, they can’t be melted again. Once the LSR injection mold parts are ready, they are removed from the mold and then put to use as prototypes or production parts.
Injection molded silicone rubber is a great solution for a variety of industries including medical, lighting, and automotive.
Xometry Injection Molding Capabilities
ServiceDetails
Service
Lead Time
Details
Starts at 15 business days, including 24-hour quote responses with design-for-manufacturing (DFM) feedback
Service
Production Options
Details
Domestic and international
Service
Machines Available
Details
Single, multi-cavity, and family molds; 50 to 3,700+ press tonnage; side actions including hand-loaded cores
Service
Inspection and Certification Options
Details
Includes FAI and PPAP. ISO 9001, AS9100, ISO 13485, UL, ITAR, and ISO 7 and 8 Medical Clean Room molding.
Service
Tool Ownership
Details
Customer-owned with mold maintenance
Service
Mold Cavity Tolerances
Details
+/- 0.005" when machining the mold and an additional +/- 0.002" per inch when calculating for shrink rate
Service
Part to Part Repeatability
Details
+/- 0.004" or less
Service
Critical Feature Tolerances
Details
Tighter tolerances can be requested and may increase the cost of tooling because of additional sampling and grooming. Xometry will mill to a steel-safe condition on critical features.
Service
Available Mold Types
Details
Steel and aluminum; Production grades range from Class 105, a prototype mold, to Class 101, an extremely high production mold. Xometry typically produces Class 104, 103, and 102 tools.
This table depicts the general tolerances for Xometry’s injection molding services and accounts for adequate draft, radii, and coring for manufacturability. Learn more about our injection molding manufacturing standards.
Additional Molding Options Available at Xometry
Insert Molding
Insert Molding Service
Make Strong, Functional Prototypes and Production Parts With Insert Molding
Overmolding Part
Overmolding Service
High Quality Process for Pilot Runs, Low-Volume Production, and Bridge Tooling
Injection Molded Parts
Liquid Silicone Rubber Injection Molding Materials
A wide variety of LSR materials for various applications and industries is available. Popular options include standard silicones along with medical-grade and fuel-resistant grade materials.
LSR Injection Molding Design Guidelines
FeatureTip
Feature
Undercuts
Tip
Reduce undercuts, which will increase the complexity and cost of the tool ejection mechanisms, by adding in pass-thru coring.
Feature
Wall Thickness
Tip
Prevent wall sink and voids by maintaining an even wall thickness. Thinner walls reduce cycle time and reduce costs.
Feature
Drafts
Tip
Ensure liquid injection molding parts are designed with a minimum draft angle of 0.5°, or up to 5°, for faces with medium textures.
Feature
Ribs/Gussets
Tip
Ribs should be 40-60% the thickness of outer walls and should still maintain draft.
Feature
Bosses
Tip
Bosses should be designed at a depth of 30% the wall thickness and with a 30% edge groove. Attach them to side walls or ribs for structural integrity.
To see these design-for-manufacturing recommendations in detail, view our Injection Molding Design Guide.
LSR injection molding machine graphic
Ready to Get an LSR Injection Molding Quote?
Applications and Advantages of LSR Injection Molding
Durability
Wide Hardness Range
Versatility
Why Use Xometry Injection Molding Services?
Massive Network Capacity
Xometry Instant Quoting Engine
Guaranteed Quality
We are ISO 9001:2015 certified and AS9100D compliant. Only the top molders that apply to become Suppliers make it through our qualification process.
