CapabilitiesLaser Tube Cutting Services
High-quality tube laser cutting for metal rectangular, square, and round tubes | Free standard shipping on US and international orders | International prototype pricing includes tariffs
  • Laser Tube Cutting Overview
  • Sizes and Tolerances
  • Shapes and Materials
  • Tube Cutter Types
  • Advantages & Disadvantages
  • Why Xometry
  • Design Guide
Tube Cutting with Xometry
Laser tube cutting uses a precision laser to cut tube or pipe stock into custom shapes, holes, designs, or channels. The material is rotated in a controllable lathe as the laser cuts, allowing for features like through-holes as small as the wall thickness and channels for easier bending and welding.
Xometry offers laser tube cutting services with instant online pricing, DFM feedback, and fast lead times. We use fiber and CO2 lasers to achieve tight tolerances and cut wall thicknesses up to 1/2”. Upload your 3D CAD to the Xometry Instant Quoting Engine® to get started and configure your quote easily. What you see is what you pay. Your price for prototypes includes tariffs and shipping for standard parcels.
Our team of experts is ready to support your project and ensure a smooth, fast manufacturing experience tailored to your needs.
    Our laser tube cutting service can cut round, square, or rectangular tubes with a variety of sizes and wall thicknesses. Kerf sizes vary based on the specific material, laser type, laser power, and operation parameters but are overall much thinner than traditional cutting methods, reducing material waste.
    Review Xometry's Standard Tube Sizes for a comprehensive list of available tube stock.
    • Minimum round outer diameter: .500"
    • Maximum round outer diameter: 6.000"
    • Minimum square or rectangle dimension: .500"
    • Maximum square or rectangle dimension: 6.000"
    • Minimum wall thickness: .035"
    • Maximum wall thickness: .500"
    Tolerances are outlined in Xometry's Manufacturing Standards for Tube Cutting
    • Cut Type: Normal-to-Surface
    • Edge-to-Edge Tolerances: +/- .010” nominal on the inner face of the tube.
    • Minimum feature size: Generally no larger than the tube thickness.
    Laser tube cutting systems have settings for handling tubes of various shapes and profiles. These include round, square, and rectangular tubes.
    The following materials are available for tube cutting.
    • Stainless Steel: 304 and 316 Welded and Seamless
    • Aluminum 6061 Extruded and Drawn
    • Alloy Steel 4130 Seamless
    • Steel A513 DOM, HREW, and CREW
    Laser Tube Cutting Material Options
    Standard Profile and Material Options for Laser Tube Cutting Services
    MaterialRound TubeRectangular TubeSquare Tube
    Material
    Round Tube
    • 6061, Extruded
    • 6061, Drawn
    Rectangular Tube
    • 6061, Extruded
    Square Tube
    • 6061, Extruded
    Material
    Stainless Steel
    Round Tube
    • SS 304, Welded
    • SS 304, Seamless
    • SS 316, Welded
    • SS 316, Seamless
    Rectangular Tube
    • SS 304, Welded
    • SS 316, Welded
    Square Tube
    • SS 304, Welded
    • SS 316, Welded
    Material
    Alloy Steel
    Round Tube
    • Steel A513 Type 1, HREW
    • Steel A513 Type 2, CREW
    • Steel A513 Type 5, DOM
    • Steel 4130 (Chromoly), Seamless
    Rectangular Tube
    • Steel A513
    • Steel 4130 (Chromoly), Cold Drawn Seamless
    Square Tube
    • Steel A513
    See our standard tube sizes page for more details.
    Isometric illustration of the laser tube cutting process.
    Types of Laser Tube Cutters
    Advantages and Disadvantages
    Here are the advantages of the laser tube cutting process:
    • Semi-to-fully automated process with high throughput.
    • Low/no material wastage.
    • Offers highly complex, clean, and repeatable cuts.
    • Works with nearly every metal.
    • Most/nearly all tube stock up to 6" is accepted.
    The disadvantages or limitations of laser tube cutting include the following:
    • Some cut materials may show a small halo discoloration from the backsplash or overspray near the cut edges.
    • A small bump of material or a different edge condition may be present at the lead-in and lead-out in a cutting profile.
    • The process is generally reserved for thin-walled materials less than 0.500"-1.000" thick.
    Why Choose Xometry for Tube Laser Cutting?
    Access the capacity of hundreds of laser tube cutting suppliers through our easy-to-use platform.
    We are ISO 9001:2015, ISO 13485, IATF 16949:2016, and AS9100D certified. Only the top shops that apply to become network suppliers make it through our qualification process.
    Expert help
    Our team of Solutions Engineers and Process Specialists are available to support you and provide answers to all of your fabrication and manufacturability questions.
    Related Capabilities
    Tube Bending Services
    Xometry offers precision tube bending services for round metal tube stock to meet your needs.
    Instant quotes for laser cutting or waterjet cut parts | No minimums | Get parts in days | Free standard shipping on U.S. and international orders | International prototype pricing includes tariffs | Now with up to 35% lower prices and 30% faster lead times
    Welder is welding a flange assembly. Image Credit: Shutterstock.com/Chumphon_TH
    Custom Online Weldment Services by Xometry
    High quality custom weldment services available with a variety of materials, manufacturing processes, finishes, and more. Subject to availability. Xometry doesn't guarantee that we can provide this service at any given time.
    Need design tips for tube fabrication?
