Liquid Silicone Rubber Molding
Manufacture custom silicone prototypes and end-use production parts in 15 days or less in a range of durometers and grades of LSR materials. Subject to availability. Xometry doesn't guarantee that we can provide this service at any given time.
How Does Liquid Silicone Rubber Injection Molding Work?
First, a liquid silicone rubber molding tool is created using CNC machining. This tool must be a high-temperature tool in order to withstand the LSR injection molding process. The tool may then be polished to allow for different finish options.
Next, the finished tool is loaded into an LSR-specific injection molding press that is precision geared for accurate control of shot size to produce the most consistent LSR parts. Materials used include standard silicones and specific grades to fit different part applications. Because LSR is a thermosetting polymer, its molded state is permanent. Unlike thermoplastics, they can’t be melted again. Once the LSR injection mold parts are ready, they are removed from the mold and then put to use as prototypes or production parts.
Injection molded silicone rubber is a great solution for a variety of industries including medical, lighting, and automotive.
![The camera housing for the feevr device is compression molded](https://images.prismic.io/xometry-marketing/648efa9f-dbbd-4cff-8cef-8a6d05d5029c_feevr+housings.png?auto=compress%2Cformat&rect=0%2C0%2C1440%2C1440&w=492&h=492&fit=max)
Xometry Injection Molding Capabilities
Service | Details |
Service Lead Time | Details Starts at 15 business days, including 24-hour quote responses with design-for-manufacturing (DFM) feedback |
Service Production Options | Details Domestic and international |
Service Machines Available | Details Single, multi-cavity, and family molds; 50 to 3,700+ press tonnage; side actions including hand-loaded cores |
Service Inspection and Certification Options | Details Includes FAI and PPAP. ISO 9001, AS9100, ISO 13485, UL, ITAR, and ISO 7 and 8 Medical Clean Room molding. |
Service Tool Ownership | Details Customer-owned with mold maintenance |
Service Mold Cavity Tolerances | Details +/- 0.005" when machining the mold and an additional +/- 0.002" per inch when calculating for shrink rate |
Service Part to Part Repeatability | Details +/- 0.004" or less |
Service Critical Feature Tolerances | Details Tighter tolerances can be requested and may increase the cost of tooling because of additional sampling and grooming. Xometry will mill to a steel-safe condition on critical features. |
Service Available Mold Types | Details Steel and aluminum; Production grades range from Class 105, a prototype mold, to Class 101, an extremely high production mold. Xometry typically produces Class 104, 103, and 102 tools. |
This table depicts the general tolerances for Xometry’s injection molding services and accounts for adequate draft, radii, and coring for manufacturability. Learn more about our injection molding manufacturing standards.
Additional Molding Options Available at Xometry
![Insert Molding](https://images.prismic.io/xometry-marketing/20821cf1-aedc-4097-ad81-966c7b43a5eb_AdobeStock_174143719+Insert+Molding.jpeg?auto=compress%2Cformat&fit=max&w=300&h=169)
Insert Molding Service
![Overmolding Part](https://images.prismic.io/xometry-marketing/fa16f177-b77a-4b93-944f-a1181bb0815b_overmolding_blog.jpg?auto=compress%2Cformat&fit=max&w=300&h=138)
Overmolding Service
![Injection Molded Parts](https://images.prismic.io/xometry-marketing/9189fb91-99d8-4efe-a539-ff056d6d69b7_capabilities-injectionmolding-hero.jpg?auto=compress%2Cformat&fit=max&w=300&h=200)
Liquid Silicone Rubber Injection Molding Materials
A wide variety of LSR materials for various applications and industries is available. Popular options include standard silicones along with medical-grade and fuel-resistant grade materials.
LSR Injection Molding Design Guidelines
Feature | Tip |
Feature Undercuts | Tip Reduce undercuts, which will increase the complexity and cost of the tool ejection mechanisms, by adding in pass-thru coring. |
Feature Wall Thickness | Tip Prevent wall sink and voids by maintaining an even wall thickness. Thinner walls reduce cycle time and reduce costs. |
Feature Drafts | Tip Ensure liquid injection molding parts are designed with a minimum draft angle of 0.5°, or up to 5°, for faces with medium textures. |
Feature Ribs/Gussets | Tip Ribs should be 40-60% the thickness of outer walls and should still maintain draft. |
Feature Bosses | Tip Bosses should be designed at a depth of 30% the wall thickness and with a 30% edge groove. Attach them to side walls or ribs for structural integrity. |
To see these design-for-manufacturing recommendations in detail, view our Injection Molding Design Guide.
![LSR injection molding machine graphic](https://images.prismic.io/xometry-marketing/427714c6-136e-409b-b21c-74d8dca4c4a9_Rounded+Square+Injection+Molding+Services+Process+Icon.png?auto=compress%2Cformat&rect=0%2C1%2C256%2C256&w=200&h=200&fit=max)
Ready to Get an LSR Injection Molding Quote?
Applications and Advantages of LSR Injection Molding
![Injection Molded Part](https://images.prismic.io/xometry-marketing/0382d654-b039-4f55-8b3f-fbe72c320d7a_blue-injection-molding-part.jpg?auto=compress%2Cformat&rect=128%2C0%2C511%2C511&w=486&h=486&fit=max)
LSR molded parts offer great UV and ozone resistance and outstanding electrical insulation
![Injection molding parts with pass thru coring](https://images.prismic.io/xometry-marketing/51907c54-6f3c-4a71-9a68-081d357def03_injection-molding-blog-hero-20200310.jpg?auto=compress%2Cformat&rect=350%2C0%2C700%2C700&w=486&h=486&fit=max)
Range from 10 to 80 durometer shore A
![plastic pellets used for molding](https://images.prismic.io/xometry-marketing/0eb1c154-6b27-4db7-9e4a-7c498af5e73a_injectionmolding-rawmaterial-multicolor-pellets-002-20180823-adobestockID-191072589.jpeg?auto=compress%2Cformat&rect=826%2C0%2C3264%2C3264&w=486&h=486&fit=max)
LSR molding is a great for gaskets, cushioning pads in portable communications, ruggedized electronic devices, and many more applications.
Why Use Xometry Injection Molding Services?
We are ISO 9001:2015 certified and AS9100D compliant. Only the top molders that apply to become Suppliers make it through our qualification process.
