Sheet Metal Fabrication Services for New Hampshire
High Quality New Hampshire Sheet Metal Fabrication | Fast lead times and free standard shipping on all US orders.
Rapid Tooling
End-Use Production
Your New Hampshire Sheet Metal Fabrication Service: Prototypes and Production Cuts
Stainless steel 301
Stainless steel 304
Stainless steel 316/316L
Steel 1018 (Low Carbon)
Type II (MIL-A-8625, Type II) creates a corrosion-resistant finish. Sheet metal parts can be anodized in different colors—clear, black, red, and gold are most common—and are usually associated with aluminum. Type III (MIL-A-8625, Type III, Class 1/2 "hardcoat") is thicker and creates a wear-resistant layer in addition to the corrosion resistance seen with Type II.
Standard Sheet Thicknesses
Locations near New Hampshire
