CapabilitiesWire EDM Machining Service
High-quality wire EDM parts with free shipping in the US. ISO 9001:2015, AS9100D, IATF 16949:2016 & ISO 13485 certified.
There was an error, please try again.
Xometry Part
Xometry Part
Xometry Part
Start A New EDM Quote
STEP | STP | SLDPRT | STL | DXF | IPT | 3MF | 3DXML | PRT | SAT files
  Xometry's Instant Quoting Engine is covered by U.S. Pat. Nos. 11,086,292, 11,347,201, 11,693,388, 11,698,623, 12,099,341, and 12,189,361. Other patents pending.
Custom Wire EDM Machining With Xometry
Other CNC Machining Services From Xometry
CNC milling
Custom CNC Milling Services
CNC milled prototypes and production parts in days | AS9100D | ISO 9001:2015 | ISO 13485 | IATF 16949:2016 | ITAR Registered | Free standard shipping on all US orders
CNC Turning
CNC Turning Service
CNC Turning Service
Wire EDM Machining Finishes Available
Standard Finish (as-milled)
Bead Blast
Tumbled
Type II  (MIL-A-8625/MIL-PRF-8625, Type II) creates a corrosion-resistant finish. Parts can be anodized in different colors—clear, black, red, and gold are most common—and is usually associated with aluminum. Type III (MIL-A-8625/MIL-PRF-8625, Type III, Class 1/2 "hardcoat") is thicker and creates a wear-resistant layer in addition to the corrosion resistance seen with Type II.
Titanium Anodize
PTFE Impregnated Hard Anodize
Chem Film
Passivation
Powder Coat
Electropolishing
Electroless Nickel Plating
Silver Plating
Silver offers high solderability and electrical conductivity but is susceptible to tarnish. Conforms to AMS QQ-S-365D. Thickness is about 0.00002” - 0.0003.”
Gold Plating
Zinc Plating
Ready to get started on your wire EDM machining project?
Free shipping available for domestic CNC orders ; learn more!
Cookie Policy
