CapabilitiesCustom Online 3D Printing ServiceDirect Metal Laser Sintering (DMLS) 3D Printing Service
Capabilities
How It Works
Materials
Finishes
Applications and Benefits
Download Guide
DMLS Produces High-Quality Metal Parts Without Tooling
Direct metal laser sintering (DMLS) is a metal 3D printing technology used to build metal parts with exceptional mechanical properties and precision. Our Manufacturing Supplier Network gives you massive on-demand production capacity with a wide range of DMLS machines and high-performance materials.
Designers often chose DMLS for its ability to produce all-in-one metal assemblies and highly precise metal parts with complex features like internal supports and lattices. DMLS does not have upfront setup or tooling costs, making it an affordable option for fully dense metal parts, with the design freedom of additive manufacturing. With DMLS’s affordability, speed, and superior design freedoms, companies and creators can build metal designs they never thought possible and produce accurate metal components.
    Xometry Direct Metal Laser Sintering 3D Printing Service Capabilities
    FeatureDescription
    Feature
    Build Size
    Description
    10" x 10" x 10" (250 x 250 x 250 mm)
    Feature
    General Tolerances
    Description
    +/- 0.005” for the first inch is typical, plus +/- 0.002” for every inch thereafter
    Feature
    Layer Height
    Description
    .0012” - .0016" depending on material
    Feature
    Surface Roughness
    Description
    150-400 µin Ra, depending on build orientation and material used for the build
    Feature
    Infill
    Description
    100%
    This table depicts the general tolerances for Direct Metal Laser Sintering (DMLS). Stresses during the build and other geometry considerations may cause deviation in tolerances and flatness. Part designs with thicker geometries, flat or broad parts, and parts with uneven wall thicknesses may be prone to significant deviations or warp. Improved tolerances may be possible with a manual quote review, after successful completion of a prototype build, and must be approved on a case-by-case basis. General tolerances apply before secondary finishing or post-processing unless otherwise specified. Please check out Xometry's Manufacturing Standards for more information on tolerances per process.
    How a Direct Metal Laser Sintering Machine Works
    Direct metal laser sintering (DMLS) is an additive metal printing technology that builds metal parts from a CAD file by selectively fusing stainless steel or aluminum powder into thin layers.
    Direct metal laser sintering’s layer-by-layer printing allows multiple parts to be combined during the printing process. With traditional manufacturing processes, metal parts are machined or metal casted into several parts and assembled. Printing an all-in-one assembly strengthens the finished part while reducing the weight and cost of production significantly. DMLS techniques can also create parts at a high density. This is ideal for parts under high pressure such as in oil and gas industries.
    Direct Metal 3D Printing Materials
    DMLS Materials Available at Xometry:
    Material NameDescriptionData Sheets
    Material Name
    3D Printed Aluminum AlSi10Mg
    Description
    Lightweight aluminum alloy. A great alternative to machining complex geometries.
    Data Sheets
    Material Name
    3D Printed Stainless Steel 17-4
    Description
    Fully-Dense 17-4 PH stainless steel metal, hardness 40 HRC, heat treatable.
    Data Sheets
    Material Name
    3D Printed Stainless Steel 316/L
    Description
    Fully-dense 316L stainless steel metal, superb corrosion resistance, meets requirements of ASTM F138.
    Data Sheets
    Available Finishes
    Standard: In addition to the removal of support structures, the part surface is media blasted to provide a uniform finish.
    Custom: Additional DMLS post-processing, such as CNC Machining of features and polishing, are evaluated on a case-by-case basis and can be requested in the quoting tool.
      dmls aluminum
      Best Applications for DMLS
      Rapid tooling
      Rapid Tooling
      Because DMLS parts are strong yet lightweight, they are widely used for rapid tooling, fixtures, and jigs.
      Fast parts and fast shipping
      DMLS metal laser printing is typically affordable and fast, and therefore is often used to make proof-of-concept models and fully functional late-stage prototypes.
      Digital manufacturing
      Production
      Cast-quality finish (fully dense) and durable materials make DMLS printing a favorite technology for end-use products.
      Why Choose Xometry for DMLS 3D Printing?
      Download the DMLS Design Guide
      Quick Links
      • Home
      • Contact Us
      • Help Center
      • About Us
      • Careers
      • Press
      • Investors
      • Xometry Go Green
