Manufacturing on Demand for the Lighting Industry
Quality Production of lighting components using Metal Stamping, Injection Molding, Die Casting, and other fabrication services
Commercial lighting fixtures. Image credit: R7 Photo
The One-Stop-Shop for Your Lighting Component Manufacturing Needs
With a full suite of manufacturing services available, Xometry is your single source for all your lighting component fabrication needs. Whether your component manufacturing requires metal stamping, die casting, 3D printing, or injection molding, Xometry’s team of manufacturing engineers and process specialists is ready to assist. Our network of manufacturing partners can handle any size project, from prototypes and short runs to full-scale production.
  • Full range of manufacturing processes & materials
  • Engineering design assistance
  • Design for Manufacturing (DFM) feedback
Lighting fixtures. Image Credit: AwaylGl/Shutterstock.com
The Brighter Solution for Custom Parts
Massive Network Capacity
Have instant desktop access to the production capacity of over 10,000 manufacturers with a full suite of manufacturing capabilities and certifications across 46 states and around the world.. Strict NDA agreements with our network protect your privacy and your designs.
Use our Instant Quoting Engine to receive immediate DFM feedback, lead times, and pricing in a matter of clicks, not days. Xometry IQ℠ puts Data Science to work for you so you can easily choose the optimal price/lead time option for your project. Compatible with STEP, Mesh, Parasolid, and ACIS files.
Xometry is certified to ISO 9001:2015, ISO 13485, and AS9100D. We are also ITAR registered and offer CoCs, material certifications, material and process lot traceability, full dimensional reports, inspection reports, and hardware certifications. You can learn more details about our Quality Assurance capabilities here.
Lighting Fixture Component Manufacturing
Xometry can manufacture a full range of lighting fixture components, including:
  • Cover and Back Plates
  • Heat Sinks
  • Trim plates
  • Flanges
  • End caps
  • Suspended ceiling light fixtures
  • Recessed lighting clips
  • Ceiling light mounting plates
  • LED light clips
  • Light cover clips
  • Metal light clips
  • Let Xometry help you choose the best manufacturing process for your components.
Light fixture disassembled. Image Credit: theLIMEs/Shutterstock.com
Light Fixture (Luminaire) Production
Xometry can produce parts for and assist with the assembly of any style of luminaire, such as:
  • Recessed cove fixtures
  • Direct or indirect pendant light fixtures
  • Recessed fluorescent fixtures
  • Recessed can fixtures
  • Wall sconce fixtures
  • Recessed wall wash fixtures
Our experienced team can fabricate parts for different lighting designs and technologies, including those used in:
  • Fluorescent lighting
  • Induction lighting
  • LED lighting
  • Instant quotes available for most processes
  • Options for materials and finishing services
LED lighting fixtures. Image Credit: demarcomedia/Shutterstock.com
Lighting Specialties
Xometry's manufacturing expertise spans the full spectrum of lighting industry specialties.
  • Industrial lighting
  • Commercial lighting
  • Residential lighting
  • Street lighting
  • Area lighting
  • Stage & theatre lighting
Lighting outside of a public facility. Image Credit: zhu difeng/Shutterstock.com
Material Options
At Xometry, we work with and can offer a wide range of material options for the fabrication of lighting industry components and parts. The common material choices include:
  • Aluminum
  • Cold-rolled steel
  • Stainless Steel
  • Copper
  • Brass
  • Plastics
  • Lexan
Brass bar stock. Image Credit: enes efe/Shutterstock.com
Secondary (finishing) Services
Your parts order from Xometry can include additional secondary or finishing services to simplify your production order and eliminate the need for managing multiple suppliers. Save time and improve order efficiency by letting Xometry handle your finishing services with your part production order.
  • Painting
  • Powder coating
  • Anodizing
  • Metal Plating (e.g., gold, silver nickel)
  • Electropolishing
  • Bead Blasting
  • Media Tumbling
  • Post-machining (e.g., drilling, tapping, deburring)
Powder coating metal parts. Image Credit: Yasni/Shutterstock.com
Value-added Services
Xometry X Logo
Product Design Assistance
Our specialists can review your mechanical component designs and assist with questions relating to fabrication, material options, and processes.
Xometry X Logo
DFM Feedback
Xometry provides DFM feedback to assure that your parts are produced with minimal risk and using the most suitable process.
Xometry X Logo
Product Inspection
We inspect our parts to the drawing requirements and can provide certifications and documentation to assure product quality.
Xometry X Logo
Product Testing
When needed, Xometry can work to implement product testing of lighting fixtures.
Assembly Services
Xometry offers assembly services for mechanical and electrical components used in lighting fixtures. We can fabricate your components to the desired specifications with tolerances and then partially or fully assemble the parts as needed.
  • Mechanical assembly of parts into fixtures
  • Electrical wire routing and connections
  • Continuity testing
A worker performing assembly in a factory. Image Credit: ESB Professional/Shutterstock.com
Lens Fabrication
Xometry's injection molding and laser cutting capabilities can assist with the fabrication of optical lenses and diffusers to provide optimal dispersion of light in light fixtures and luminaires. Contact us to learn how we can assist with optical molding or lens creation from Lexan, acrylic, or other materials.
  • Custom Part Molding
  • Custom Die Casting
  • Custom Urethane Casting
Globe lens on a street lamp fixture. Image Credit: Stephen Whybrow/Shutterstock.com
Lighting Component Manufacturing Capabilities
Xometry Capability
Metal Stamping Services
Die cast metal parts
Custom Die Casting Services
High Quality Die Cast Metal Parts.
Instant quotes for laser cutting or waterjet cut parts | No minimums | Get parts in days | Free standard shipping on U.S. and international orders | International prototype pricing includes tariffs | Now with up to 35% lower prices and 30% faster lead times
Xometry Capability
Xometry X Logo
