Xometry’s Domestic and Global Manufacturing Partner Network
10,000+ Global Manufacturing Suppliers • 50+ countries and 49 US states • 30 million+ network machine hours
Tap into the Power of the Xometry Manufacturing Partner Network
Xometry’s Manufacturing Partner Network is the backbone of our on-demand manufacturing platform. Our network contains thousands of manufacturers in the United States and around the world, with active suppliers based on four continents. Our U.S. facilities include ITAR-qualified; ISO 9001:2015, ISO 13485, IATF 16949:2016, AS9100D, CMMC Level 2 certified; ISO 2768 compliant; and NADCAP facilities. The Xometry Manufacturing Partner Network is the largest of its kind, with more than 30 million available machine hours.
Massive Production Capacity
At Xometry, you are no longer subject to the limits of your local suppliers. We integrate seamlessly with thousands of vetted manufacturing facilities across 49 U.S. states and more than 50 countries. By partnering with us, you can dynamically scale your product development needs and production output while easily adapting to changing trade policies without compromising quality. Our platform connects you with the right supplier for the job based on the manufacturing processes, materials, and finishes you select, as well as the certifications you require and how quickly you need your parts.
With high-precision industrial manufacturing and a variety of finishes on solid metal or plastic parts, Xometry guarantees that your custom parts will be built to your specifications. Manufacturing partners in Xometry’s network undergo a vetting process to monitor quality and on-time delivery. Our partners provide updates for each order while parts are in process and inspection reports upon completion.
Comprehensive Capabilities
Xometry’s Manufacturing Partner Network offers a wide range of capabilities to meet your custom manufacturing needs, from prototyping to bridge tooling to production runs. The Xometry Instant Quoting Engine® uses the power of AI to analyze your designs and match you with the ideal suppliers in our network, empowering you to consolidate the vendors in your supply chain.
With a diverse range of capabilities — from CNC turning and milling and industrial-grade metal and plastic 3D printing to sheet metal fabrication and laser tube cutting — Xometry can provide competitive prices and lead times for your projects.
State-of-the-Art Equipment
Machine shops in the Xometry Manufacturing Partner Network have the latest equipment, including 3-axis, 4-axis, and 5-axis machining centers and lathe machines.
- Haas Automation
- Mazak
- DMG Mori (Mori Seiki)
- Doosan (Daewoo)
- Okuma Corp
- Sodick
- And many more
Xometry offers a comprehensive selection of industrial 3D printing materials and technologies on a single online platform. Our network operates trusted brands of commercial and industrial-grade printers.
- Stratasys
- EOS
- HP
- 3D Systems
- Formlabs
- And many more
Finishing and Assembly Services
When you order parts from Xometry, you can add finishing or assembly to complete your project, consolidating production and saving you time and logistical headaches. From anodizing to precious metal plating, we offer dozens of finishing options and custom finishes upon request. Metal and plastic part, electromechanical, and cable and harness assembly are available, as well as physical and functional testing.
Learn What Makes Xometry the Global Leader in Manufacturing on Demand
We are ISO 9001:2015, AS9100D, ISO 13485:2016, IATF 16949:2016, and CMMC Level 2 certified, and ITAR registered. Xometry stands behind the delivery and quality of your parts.
Machine Learning Technology
We put big data to work to save you time and money in custom manufacturing.
Experience It for Yourself
All uploads are secure.
