CapabilitiesCustom Online 3D Printing ServiceX1 Metal 316i Binder Jet 3D Printing Service
Get instant online quotes on parts in over 70 metal and plastic materials. Free shipping on all US orders. ISO 9001:2015, ISO 13485, IATF 16949:2016, and AS9100D certified.
Applications for X1 316i Metal 3D Printing
This material system from ExOne has low magnetic properties which makes it particularly useful for applications in the food and medical industries. The copper alloy acts as a natural antibacterial agent making it easy to decontaminate printed parts. Since the matrix material is easy to polish, additional applications exist in bath and kitchen hardware prototypes and low volume production.
X1 316i Stainless Steel infiltrated with bronze is a matrix material composed of 60% stainless steel and 40% bronze infiltrant. The lower yield strength of the material enables it to be easily machined and polished. This material also exhibits enhanced corrosion resistance properties.
Typical X1 316i Material Properties
Material PropertiesTest MethodValues
Material Properties
Tensile Strength - Ultimate Strength
Test Method
ASTM E8
Values
84 ksi (580 MPa)
Material Properties
Yield Strength (0.2% offset)
Test Method
ASTM E8
Values
41 ksi (283 MPa)
Material Properties
Elastic Modulus (ASTM E8)
Test Method
ASTM E8
Values
19.5 Mpsi (135 GPa)
Material Properties
Elongation
Test Method
ASTM E8
Values
14.5%
Material Properties
Hardness
Test Method
ASTM E18
Values
60 HRb
Material Properties
Fractional Density
Test Method
MPIF 42
Values
95%+ approximate
Material Properties
Density
Test Method
MPIF 42
Values
0.284 lbs/in^3 (7.86 g/cm^3)
Material Properties
Machinability
Test Method
Values
Conventionally machinable
Material Properties
Weldability
Test Method
Values
Use silicone bronze rod & TIG weld
Material Properties
Thermal Conductivity (Room Temp.)
Test Method
Values
11 BTU/hr ft °F (19 W/m °K)
Material Properties
Specific Heat
Test Method
ASTM E1269-11
Values
0.131 BTU/lb °F (548 J/kg °K)
Material Properties
Thermal Expansion Coefficient
Test Method
ASTM E831-14
Values
10.37 x 10-6/ °F (18.6 x 10-6/ °K)
Source: ExOne
Surface Finish
  • After sintering: ≈ 600 μin Ra  (15 μm Ra )
  • Bead blasting: ≈ 300 μin Ra  (7.5 μm Ra )
  • Barrel finishing: ≈ 50 μin Ra  (1.25 μm Ra )
Post Processing
After printing is complete, the parts are cured in an oven, which enables the parts to be handled. After curing, the parts are sintered and infiltrated with bronze above 1100°C. Cool down can be varied to control the machinability and hardness of the material.
  • Zirblast (Standard)
  • Tumble Polished
  • Medieval Pewter
  • Damascus Steel
  • Antique Bronze
  • Wheat Penny
bead blasted X1 316i binder jetting
See All Our 3D Printed Materials
dmls aluminum
3D Printed Metal Materials
3D Printed Plastic Materials
Need X1 420i 3D Printed Parts?
Quick Links
  • Home
  • Contact Us
  • Help Center
  • About Us
  • Careers
  • Press
  • Investors
  • Xometry Go Green
