CapabilitiesCustom Online 3D Printing ServiceTPU 3D Printing Service
Get instant online quotes on TPU parts. Free shipping on all US orders. ISO 9001:2015, ISO 13485, IATF 16949:2016, and AS9100D certified.
Macro close-up of MJF TPU 88A with a natural finish.
About TPU 3D Printing
Most 3D printed plastic materials take the form of rigid thermoplastics, which limits the potential for prototyping in flexible materials. TPU bridges the gap by allowing for a thermosetting polyurethane to be 3D printed. As is the case with any elastomeric polymer, 3D printing with TPU has excellent resilience, impact resistance, and general toughness.
TPU (thermoplastic polyurethane) for Multi Jet Fusion printing is a thermoset polyurethane exclusive to MJF printers. 3D-printed TPU plastic has excellent flexibility, shock absorption, and elasticity. These properties make this material useful in a range of industries for automotive parts, sports equipment, and medical devices. It is also ideal for complex flexible lattice components.
3D Printed TPU at a Glance
Common ApplicationsAdvantagesDisadvantagesTypical Lead TimePriceMinimum Feature SizeTolerances
Common Applications
Sports footwear, orthopedic models, cable strain reliefs
Advantages
UV resistance, hydrolysis resistance
Disadvantages
Sensitive to humidity
Typical Lead Time
5 Days
Moderate
0.020" (0.508 mm) or greater
Tolerances
MJF TPU 88A
3D printing in TPU 88A is ideal for applications that require flexibility and resilience. Its elastomeric nature allows parts to deform to a high degree and then return to their original shape. Applications can include soft robot grippers, complex shock-absorbing shoe soles, or flexible bellows.
MJF TPU 88A Properties
Tensile Strength (MPa)Elongation at Break (%)Hardness (Shore A)Melting Temperature (℃)Glass Transition (℃)
9
220
Hardness (Shore A)
88
120-150
-48
TPU 88A Finishing Options
Xometry X-Tile made from TPU 88A with a standard (natural) finish.
Standard
Parts are removed and de-powdered with a grit-blasting process. MJF parts have a smooth matte surface finish straight off the machine.
Dyed Black
3D benchy printed in TPU 88A with a dyed-black finish.
Parts are submerged in a heated dye solution to produce a uniform matte black surface finish.
Dyed Black + Vapor Smoothed
Xometry X tile printed in TPU 88A with a combination of dyed black and vapor-smoothed finish.
An automated post-processing technology (AMT PostPro3D) is used to achieve a high-quality surface finish. Vapor smoothing brings most surfaces from matte to semi-gloss. Vapor smoothing also seals the surface, enhances mechanical properties, and provides a consistent cosmetic finish for production. Vapor-smoothing can also be performed on non-dyed parts. Click here to learn more about vapor smoothing.
Custom
Custom surface finishes like painting can also be requested.
Isometric illustration of the HP Multi Jet Fusion (MJF) printing process.
Need Parts 3D Printed in TPU?
Looking for Design Tips for MJF 3D Printing?
