6061 Aluminum Metal
aluminum 6061
6061 Compatible Capabilities
CNC milling
Custom CNC Milling Services
CNC milled prototypes and production parts in days | AS9100D | ISO 9001:2015 | ISO 13485 | IATF 16949:2016 | ITAR Registered | Free standard shipping on all US orders
CNC Turning
CNC Turning Service
CNC Turning Service
Laser Cutting
High-quality Laser Cut Parts in Days | Free Standard Shipping on All US Orders
Table 1: Material Properties of 6061 Aluminum Alloy
Material PropertiesValue
Material Properties
Hardness, Vickers
Value
107
Material Properties
Hardness, Rockwell A
Value
40
Material Properties
Hardness, Rockwell B
Value
60
Material Properties
Hardness, Knoop
Value
120
Material Properties
Hardness, Brinell
Value
95
Material Properties
Elongation at Break
Value
12%
Material Properties
Modulus of Elasticity
Value
10,000 ksi or 68.9 Gpa
Material Properties
Tensile stress
Value
42,000 psi or 290 Mpa
Material Properties
Yield stress
Value
35,000 psi or 241 Mpa
Material Properties
Ultimate bearing stress
Value
88,000 psi or 607 Mpa
Material Properties
Fatigue stress
Value
14,000 psi or 96.5 Mpa
Material Properties
Poisson's Ratio
Value
0.33
Material Properties
Shear stress
Value
30,000 psi or 207 Mpa
Material Properties
Shear modulus
Value
3770 ksi or 26 Gpa
Material Properties
Machinability
Value
50%
Material Properties
Thermal Conductivity
Value
167 W/m-k
Material Properties
Specific heat capacity
Value
0.896 J/g-°C
Material Properties
Melting Point
Value
582–652 °C
Material Properties
Density
Value
2.7 g/cc
Material Properties
Artificial Aging Temperature
Value
160 °C
Material Properties
Solution Aging
Value
529 °C
Finishes
Image of an aluminum stand with a bead blasted finish.
Mechanical Finishes
  • Bead Blast
  • Tumbled
Anodizing
Image of an aluminum stand with a type ii green anodized finish.
  • Type II
  • Type III Hardcoat
Chemical Conversion Coatings
Image of an aluminum stand with a gold chromate conversion finish.
  • Clear Chem Film
  • Gold Chem Film
Metal Plating
Image of a metal part with a gold plated finish.
  • Nickel
  • Zinc
  • Gold
  • Silver
Powder Coating
Image of an aluminum stand with a type III clear hardcoat PTFE impregnated anodized finish.
Electropolishing
Image of a metal part with an electropolished finish.
Applications of 6061 Aluminum
Various metal stamped pieces
Structural components
Medical Robot Built by Galen Robotics
Medical devices
Aerospace Machining
Aerospace components
6061 Aluminum's Frequently Asked Questions
Can 6061 aluminum be bent?
Yes, 6061 can be bent, however its common temper 6061-T6 aluminum (found in many machine shop stocks) makes it much more prone to failure due to increased brittleness, and so it is recommended to bend this aluminum alloy in its untempered or in its annealed state.
Can 6061 aluminum be welded?
Yes, 6061 aluminum is routinely welded, however it can experience solidification cracking if mishandled. Using filler material such as 4043 aluminum and 5356 aluminum is highly recommended.
Why use 6061 aluminum alloy?
6061 aluminum has a fantastic blend of characteristics for both general and application-specific applications; it is relatively cheap, strong, workable, machinable, weldable, able to be heat-treated, resistant to corrosion, and can be polished to an aesthetic finish.
Which aluminum is stronger, 6061 or 6063 aluminum?
It depends on the temper, application, and environment, but generally speaking 6061 aluminum has a higher yield strength ans fatigue strength than 6063 aluminum.
How is 6061 aluminum made?
6061 aluminum is an alloy blend of several elements such as silicon, magnesium, chromium, manganese, zinc, iron, titanium, copper, and other elements with a majority composition of pure aluminum (typically >97%). It is made by mixing pure aluminum with the right ratio of these alloying elements in a foundry.
What is 6061 aluminum used for?
Being one of, if not the most popular aluminum grade, 6061 aluminum is used for a huge range of applications, including structural components, aerospace and automotive frames, rivets and fasteners, flooring, boat parts, and many other uses.
