Xometry Palladium-Nickel Plating Service
Get Quotes in Two Hours and Parts Finished in as Fast as 2 Days. ASTM B867 Available.
ITAR Registered
ISO 9001
ISO 13485
AS9100D Certified
Palladium-Nickel Plating Overview
Palladium-nickel is a precious metal alloy frequently used as a gold plating alternative. It can also be used along with gold plating. Xometry offers Type II Pd-NI, which means that the alloy is made up of 80% palladium and 20% nickel. This alloy is a popular one for plating/finishing due to its electrical conductivity, ductility, corrosion resistance and heat resistance. Make your parts better with Xometry's palladium-nickel plating service. Specifications: ASTM B867.
- Thickness recommendation:
- 0.8-3.0 microns: circuit edge card connectors
- 0.8-1.5 microns: Lower energy electrical contacts
- 0.4-0.5- microns: Electrical contacts with little adverse environmental, electrical, or mechanical action.
Competitive Pricing
Access a deep network of world-class palladium-nickel platers, helping you find the suppliers you need at competitive prices.
Fast Quoting
Streamlined Communication
Anodizing
- Type II Anodize
- Type III Hard coat
- Type III w/ PTFE
Metal Plating
- Copper Plating
- Electroless Nickel
- Electrolytic Nickel
- Nickel Plating
- Nickel Sulfamate
- Nickel Watts
- Tin
- Zinc
Adhesives and Coatings
- Black Oxide
- Dry Film Lubricants
- Powder Coat
- Wet Paint
Conversion and Pretreatments
- Chem Film
- Chromate Conversion Coating
- Heat Treat
- Passivation
- Pickle and Oil
Surface Treatments
- Bead Blasting
- Electropolishing
- Etching
Part Marking
- Ink Stamping
- Laser Marking
- Silk Screening
Heat Treatments
- Annealing
- Carburizing
- Cryogenic Treatment
- Flame Hardening
- Hydrogen Embrittlement Relief
- Induction Hardening
- Nitriding
- Stress Relieving
Certifications
- AS 9100D
- ISO 13485
- ISO 9001:2015
- ITAR
- NADCAP
- RoHS
Finishing Services at Xometry
Find Your Finisher
Find verified finishers using our robust search tools with over 50 different criteria including location, finishing capabilities, and certifications.
Create and Submit Your Request
Send a breakdown of your project's requirements to the finisher of your choice complete with details on your finishing needs and any necessary files.
Manage Your Order
Manage your order from start to finish in one place, including fast and easy transactions with your credit card or apply for net-30 terms with no hassle or risk.
