![Xometry Palladium Plating Services](https://images.prismic.io/xometry-marketing/20db0dfc-570c-453e-a906-ef174d7efadb_finishing-services-Desktop-View-v2.jpg?auto=compress%2Cformat&rect=0%2C0%2C1440%2C606&w=1440&h=606&fit=max)
Get Quotes in Two Hours and Parts Finished in as Fast as 2 Days. MIL-P-45209, ASTM B679 Available.
ITAR Registered
ISO 9001
ISO 13485
AS9100D Certified
Palladium Plating Overview
Palladium is a rare metal known for its lustrous, bluish-silver appearance. It has low density and a low melting point and at room temperature does not oxidize. The koop hardness of palladium can be as high as 400. Palladium is useful in applications where the prevention of an oxide formation is necessary. In some cases, it can also act as a stand-in for gold plating, providing great performance at a lower price. Palladium, like gold, has very good solderability characteristics and is good for electroplating large and small parts. Palladium plating can also be considered in a multi-plating process. Specifications: MIL-P-45209, ASTM B679.
- Atomic symbol: Pd
- Atomic mass: 106.42
- Atomic number: 46
- Boiling point: 5,365°F
- Melting point: 2,831°F
![Rhodium Plating Services](https://images.prismic.io/xometry-marketing/d6afe0f8-5ada-4292-8e45-e2925ed1e8e8_xometry-finishing-services.jpg?auto=compress%2Cformat&rect=341%2C0%2C756%2C756&w=492&h=492&fit=max)
Competitive Pricing
Access a deep network of world-class palladium platers, helping you find the suppliers you need at competitive prices.
Fast Quoting
Streamlined Communication
Anodizing
- Type II Anodize
- Type III Hard coat
- Type III w/ PTFE
Metal Plating
- Copper Plating
- Electroless Nickel
- Electrolytic Nickel
- Nickel Plating
- Nickel Sulfamate
- Nickel Watts
- Tin
- Zinc
Precious Metal Plating
Adhesives and Coatings
- Black Oxide
- Dry Film Lubricants
- Powder Coat
- Wet Paint
Conversion and Pretreatments
- Chem Film
- Chromate Conversion Coating
- Heat Treat
- Passivation
- Pickle and Oil
Surface Treatments
- Bead Blasting
- Electropolishing
- Etching
Part Marking
- Ink Stamping
- Laser Marking
- Silk Screening
Heat Treatments
- Annealing
- Carburizing
- Cryogenic Treatment
- Flame Hardening
- Hydrogen Embrittlement Relief
- Induction Hardening
- Nitriding
- Stress Relieving
Certifications
- AS 9100D
- ISO 13485
- ISO 9001:2015
- ITAR
- NADCAP
- RoHS
Finishing Services at Xometry
Find Your Finisher
Find verified finishers using our robust search tools with over 50 different criteria including location, finishing capabilities, and certifications.
Create and Submit Your RFQ
Send a breakdown of your project’s requirements to our network of finishing suppliers.
Manage Your Order
Manage your order from start to finish in one place, including fast and easy transactions with your credit card or apply for net-30 terms with no hassle or risk.
![Xometry Image](https://images.prismic.io/xometry-marketing/fd339357-7c20-4ec9-b801-f9660f54fa29_finishing-services-Mobile-View.jpg?auto=compress%2Cformat&rect=0%2C45%2C375%2C375&w=200&h=200&fit=max)
