ResourcesInjection MoldingLooking at the Cost Comparison Between 3D Printing and Injection—and When They Break Even
Rebecca Piccoli headshot
Published September 23, 2020
Updated December 17, 2024
Comparing the benefits and price breakdown of two popular manufacturing types
An injection molded screw for manufacturing
As we see new and innovative technologies disrupt the manufacturing industry, it’s a good time for us to explore how older methods compare—and when both should be used. Two manufacturing processes that usually get weighed up against one another are injection molding and 3D printing, especially since each brings specific advantages, downsides, and budget considerations to the table.
While additive manufacturing has given many engineers and manufacturers pause, it’s not necessarily a solution for all companies’ needs. Here’s how these two compare financially and how they stack up in terms of what they can offer.
What Is Injection Molding?
Injection molding is one type of manufacturing process that works by funneling molten plastic into molds of certain shapes and designs. They cool and you’re left with different parts — which can be pretty complex. This technique gels well with plastics and it’s cost-effective compared to a lot of other methods.
How It Works
  1. First, the mold is shut and tonnage is applied to both halves or however many sections your mold is split into.
  2. Then, the plastic (or other material mixture) is heated into a molten hot state and injected into the mold.
  3. Once the right amount is in, the machine will apply pressure for a set time limit to the mold to make sure the plastic has reached every nook and cranny.
  4. Then the mold will go through a cooling phase where the plastic shape will harden.
  5. After it’s hardened and cooled down, the molds will be opened and the object will be ejected and continue on to get processed or finished.
In the diagram below, you can see a drawing of what some injection molding machines look like and how each component fits together.
What Is 3D Printing?
This is a large family of technologies that use printers for additive manufacturing—and it’s forever advancing, becoming quicker, easier, and more affordable. It’s possible to make very complex parts and customized components through this layer-by-layer methodology. You can 3D print with almost any material, from plastics and polymers to glass and metal. It’s a popular choice for prototyping as the costs are pretty low once the machinery is taken care of.
How It Works
There isn’t a step-by-step guide that covers all types of 3D printing, as each machine operates differently and has its own way of creating parts. In general, these machines will lay down one layer of material at a time, cure it, and continue layering until the part is fully built.
"3D printing is a good process to prototype in and confirm ‘proof of concept.’ Although the initial tooling costs can be higher, injection molding becomes more cost-effective over large production runs, helping you achieve economies of scale. However, injection molding may be justified at low volumes if specific materials or mechanical properties are needed for testing purposes."
Kyra Stawson,
Senior Solutions Engineer
Comparing Injection Molding and 3D Printing
The table below will give you a look at how injection molding and 3D printing compare in different aspects and the pros and cons of each.
Pros and ConsInjection Molding3D Printing
Pros and Cons
Production quantities
Injection Molding
Fit for mass production and large-scale orders still made at a high quality.
3D Printing
Not quite to the point where it’s ready for mass production.
Pros and Cons
Design requirements
Injection Molding
Stricter guidelines and requirements than 3D printing. Tough to create small quantities with injection molding.
3D Printing
Not as strict guidelines. Easy to iterate and test different designs. Doesn’t require large quantities for production.
Pros and Cons
The process
Injection Molding
Makes strong parts, but is an expensive process, and any mistakes are costly and take a long time to fix.
3D Printing
Longer production times but more affordable and capable of creating complex parts.
Pros and Cons
Waste
Injection Molding
Minimal
3D Printing
Minimal
Pros and Cons
Aesthetics
Injection Molding
Clean, sleek parts
3D Printing
Often rough surfaces that need to be post-processed
Pros and Cons
Applications
Injection Molding
Bumpers, dashboards, cup holders, mirror housings, medical devices, pill bottles, X-ray machinery, turbine blades, chassis components, food storage containers, caps, straws, custom construction parts, hand tools, and fasteners.
3D Printing
Aerospace components, robotic parts, dental implants and appliances, prosthetics, prototypes, art, replacement parts, and automotive parts.
3D Printing vs. Injection Molding Comparisons
Cost Comparison Breakdown
The break-even point hovers between 250 and 2,000 parts when it comes to finding the point at which injection molding and 3D printing are most cost-effective. To give you a better picture, we’ve analyzed a few case studies below. But before jumping into those, you’ll want to heavily consider the following factors when you’re deciding between these two types of manufacturing, as these tend to be the most important:
  • Surface design: The bigger the surface area the more you’ll have to pay and the longer it’ll take to create your part when it comes to 3D printing. This isn’t as much of an issue for injection molding.
  • Volume order: Like with any manufacturing process, the more volume you have, the less you usually have to pay per part. 3D printed parts tend to be more affordable (around 10% to 20% less) than injection molded parts when you have an order of 20,000 or less. The price seems to be on par when you hit 40,000 to 50,000 parts.
  • Tooling costs: When you’re looking at the costs of iterating products, 3D printing comes out on top as far as affordability goes. It’s much more expensive to change the designs (and thus the molds) of injection molded parts.
Now, we’ll take a look at a couple of product production examples we’ve priced out using our Instant Quoting Engine at Xometry. This looks at the cost of creating a drone leg, potentiometer knob, and junction housing and how their prices compare depending on quantity when you 3D print them or create them through injection molding.
Example 1: Drone Leg Pricing
  • The bounding box is 146.69 mm x 139.57 mm x 33.00 mm (5.775 in x 5.495 in x 1.299 in).
  • The drone’s leg geometry means it'll cost around $32 for one part or $24 per part for 250 parts through selective laser sintering (SLS). HP Multi Jet Fusion is a little less expensive per part after 250 units.
  • The price per unit with injection molding hits break-even pretty fast, so scaling is doable and cost-effective. Think $3 per part at quantities over 8,000 — far cheaper than 3D printing.
  • After 250 units, it’s better to look at injection molding for speed and cost-effectiveness.
See the graph below to see how different 3D printing methods and injection molding prices compare:
Data results for the per-unit price of the Drone Leg
The Drone Leg
Data results for the per-unit price of the drone leg over doubling quantities from 1 to 8,192 pieces.
Example 2: Potentiometer Knob Pricing
  • We’re looking at a potentiometer knob with a bounding box of 16.81 mm x 15.20 mm x 15.20 mm (0.662 in x 0.598 in x 0.598 in)—it’s around the size of a thimble for reference.
  • Because it’s so tiny, the cost of 3D printing remains competitive with injection molding until you hit 2,000 units.
  • At around 30 units, you’ll want to consider HP MJF printing over SLS. This would equal out to about $3.45 per unit and is great if you’re looking to stick with lower quantities.
  • When you need more than 2,000 units, injection molding will save you thousands of dollars, as it costs around $0.80 per unit (without tooling).
Take a look at the graph below, which compares methodologies for making a potentiometer:
Data results for the per-unit price of the Potentiometer Knob
Potentiometer Knob
Data results for the per-unit price of the potentiometer knob over doubling quantities from 1 to 8,192 pieces.
Example 3: Junction Housing Pricing
  • This example looks at junction housing with a bounding box of 215.84 mm x 172.44 mm x 68.18 mm (8.498 in x 6.789 in x 2.684 in).
  • Because junction housing has a pretty large surface area, you’ll get higher costs from the get-go, even with 3D printing. You can expect a little over $200 per part made from nylon with SLS. Then at 30 units, you’ll get a better cost with CNC machining.
  • Urethane casting and HP MJF offer better prices between 30 and 250 units, but injection molding ends up being the cheapest if you have a large quantity.
  • It can cost around $10,000 in tooling but after 250 units, it’s still cheaper to use injection molding.
Take a look at the graph below for the price breakdown between methods and costs:
Data results for the per-unit price of the junction housing
Junction Housing
Data results for the per-unit price of the junction housing over doubling quantities from 1 to 8,192 pieces.
FAQs About 3D Printing and Injection Molding
Below are some common questions that crop up when you’re looking at these two specific manufacturing methods.
How do the costs of injection molding and 3D printing compare?
It will all depend on the quantity of units you’re after and tooling costs, but in many cases, 3D printing is usually cheaper for lower numbers, whereas injection molding cuts the price down significantly at higher quantities. However, if you have a part with a large surface area, 3D printing may not be cost-effective at all, even with fewer units.
Is injection molding additive manufacturing?
Nope—additive manufacturing involves creating a part layer by layer, whereas injection molding involves pushing molten plastic into molds. 3D printing is an example of additive manufacturing.
