Metal 3D printing has transformed how complex metal tooling and parts are made. Electron beam melting, or EBM, is a sound alternative to CNC machining and metal casting due to its ability to print parts with the durability and strength of metals but at the speeds of 3D printing.
EBM is a powder bed fusion process similar to SLM (selective laser melting) and SLS (selective laser sintering) in that each thin layer of metal powder is deposited onto a heated bed and then melted or sintered into place. However, EBM differs from those processes in that the energy source that fuses the powder is an electron beam instead of a laser beam, and the process takes place under a vacuum instead of at atmospheric pressure. Chromium-cobalt and titanium alloys are two of the most commonly used materials in EBM 3D printing.
The history of electron beam melting dates back to 1993, when its principles were first patented by the company Arcam in collaboration with the Chalmers University of Technology in Gothenburg, Sweden. Their goal was to create 3D objects, layer by layer, by melting electrically conductive metal powders with a beam of electrons. In 1997, Arcam was reorganized into Arcam AB, which continued to develop and commercialize the EBM 3D printing process.
In this article, we dive deeper into electron beam melting and discuss everything from what it is, to its advantages and disadvantages, and its similarities and differences from other 3D printing processes.
What Is Electron Beam Melting (EBM)?
Electron beam melting is a 3D printing process that uses electrically conductive metal powders and beams of electrons to produce parts layer by layer. For the process to work, a vacuum of about 0.0001 mbar must be created in the print chamber. In the absence of a vacuum, high-energy electrons collide more frequently with gas molecules, robbing the beam of the energy it needs to complete the printing process. Once a vacuum is obtained, the build platform is heated to extremely high temperatures (around 600-1000℃), and the metal powder is precisely deposited to form the current cross-sectional layer of the part to be printed. At that point, the electron beam meticulously moves about the build platform and uses even higher temperatures to selectively melt and fuse the new powder layer with the previously printed layers. Once a layer is completed, the build platform drops down by an amount equivalent to one layer. This process repeats until the entire part is printed.
What Is the History of EBM Printing?
Electron beam technology dates back to 1869 when Johann Wilhelm Hittorf and William Crookes experimented with cathode rays (another term for electron beams) in gases to melt metals. Their experiments led to a host of discoveries. However, it wasn’t until 1952 that Dr. h.c. Karl-Heinz Steigerwald developed the first practical electron beam processes for commercial use. At that point, electron beams were mainly used for welding applications. More than 40 years later, in 1993, the principles and theory of EBM were first patented by the Swedish company Arcam. This was made possible through collaboration with the Chalmers University of Technology in Gothenburg, Sweden. In 1997, the company was reorganized into Arcam AB as they continued to develop and commercialize the EBM 3D printing process. Arcam AB was acquired by GE in 2016 and integrated into GE Additive.
What Is Electron Beam Melting Used For?
Electron beam melting 3D printing is used for small-batch manufacturing and proof-of-concept verification of parts with complex geometries. EBM systems and the powders used for printing are expensive, hence the process is seldom used for mass production. EBM produces high-strength metal parts, which are mostly used in the aerospace, motorsports, and medical industries. EBM-printed parts are used in high-performance parts such as turbine blades, engine components, medical implants, and prostheses.
What Is Electron Beam Melting Similar To?
Electron beam melting is similar to other powder bed fusion 3D printing processes, like selective laser melting (SLM) and selective laser sintering (SLS). EBM utilizes a beam of electrons to selectively melt and fuse metal powders to form parts layer by layer. In SLM, a laser selectively melts and fuses metal powders on a heated build platform. SLS is a nearly identical process; however, polymeric powders instead of metal powders are selectively sintered and fused by a laser.
EBM differs from these two processes in the use of an electron beam to create parts rather than a laser, the need for a vacuum in which to print parts, and the need for higher build platform temperatures.
How Does Electron Beam Melting Work?
EBM 3D printing is made possible by a tungsten filament that is heated in a vacuum to create the electron beam. Once the vacuum is obtained, the beam is created, and metal powders are deposited on the build tray, and printing can start. The steps in producing an EBM 3D printed part are described below:
- Metal powder is deposited onto the build platform to form the current cross-sectional layer of the part to be printed.
- 3D printer chamber pressure is reduced to around 0.0001 mbar.
- When the required vacuum level is obtained, the electron beam is turned on and heats the entire build platform to the required temperature (600-1000℃).
- Once the build platform is heated, the electron beam moves precisely to the build platform to melt and fuse the metal powder particles at even higher temperatures.
- When one layer is completed, the build platform drops down a height equivalent to one layer.
- A fresh layer of powder is deposited, and the process repeats until the entire part has been printed.
- Parts are left to cool—often overnight—before they are removed from the printer.
- After the parts are cooled, residual semi-sintered powder and support structures must be removed.
How Accurate Is Electron Beam Melting?
EBM printing is generally less accurate than SLM printing. This is because, in SLM, the metal powders used are typically finer, and build layers are typically thinner than in EBM. The thicker layers in EBM-printed parts can result in rougher surface finishes. Therefore, post-processing may be required for EBM-printed parts to obtain desired tolerances and surface finishes.
What Materials Are Used in Electron Beam Melting?
Only a limited range of metals can be used in EBM. Titanium and chromium-cobalt alloys are two commonly used materials. Certain steel powders and Inconel 718 can also be used. Because electron beam melting 3D printing requires electrically conductive materials to build parts, polymeric and ceramic materials cannot be used.
What Are the Temperatures Necessary for EBM?
The fusion part of the EBM 3D printing process can require temperatures in excess of 2000℃ to fuse the high melting-point materials typically used in EBM printing projects, such as titanium. Tungsten alloys can require fusion at over 3000℃.
Even the preheat phase of EBM printing demands heating the build platform to 600-1000℃. Preheating the build platform to a high temperature minimizes residual stresses in the printed part, resulting in better mechanical properties. However, a higher build platform temperature requires an adequate amount of support to prevent overhangs from warping.
Supports help conduct heat away from the part and into the build platform—effectively reducing thermal stresses throughout the part.
What Are the Advantages of EBM?
The advantages of EBM 3D printing are:
- EBM prints high-density parts with good mechanical properties.
- EBM can print brittle parts that otherwise couldn’t be produced using SLM printing due to the increased print temperatures in EBM.
- Unused powder can be recycled and used in later print jobs, effectively minimizing waste and reducing costs.
- The electron beams used in EBM are more powerful than the laser beams used in SLM because the use of a vacuum assures that no foreign molecules can interfere with printing. This higher energy level leads to faster print speeds for EBM compared to SLM.
- EBM can produce high-quality parts comparable to traditional manufacturing methods like casting or CNC machining.
What Are the Disadvantages of EBM?
The disadvantages of EBM 3D printing are:
- EBM can be an exceptionally expensive process due to the electron beam technology and metal powders used.
- Only a limited group of metals can be printed using the EBM process.
- EBM-printed parts tend to have lower dimensional accuracy compared to SLM-printed parts due to the difference in powder particle size and printed layer height.
Why Is the EBM Process Performed in a Vacuum?
The EBM process is performed in a vacuum to reduce residual stresses in printed parts and to prevent oxidation on printed parts due to increased temperatures. If a vacuum is not present, electrons within the beam can collide with molecules present in the air.
This will cause electrons to collide more frequently with gas molecules, robbing the beam of the energy it needs to complete the printing process.
In normal practice, heating metals at high temperatures like the ones found in EBM printing can lead to increased oxidation, which makes the final product brittle. However, in EBM, printing inside a vacuum chamber virtually eliminates oxidation and the lack of ductility and toughness it can cause.
What Is the Difference Between EBM and SLM 3D Printing?
SLM (selective laser melting) is an LPBF (laser powder bed fusion) process. The name “SLS” was originally trademarked by SLM Solutions (now Nikon SLM Solutions Group AG), but it is often used as a generic term for metal LPBF systems.
The differences between EBM and SLM 3D printing are:
- EBM uses electrons to melt powders, while SLM uses photons from a laser to melt metal powders.
- EBM requires a vacuum to print parts, while SLM prints parts with an inert gas at near-atmospheric pressure.
- EBM primarily processes titanium, cobalt-chrome, and some nickel-based superalloys, while SLM supports a broader range of metals, including stainless steel, aluminum, and copper.
- EBM generally prints parts with lower dimensional accuracy and rougher surface than SLM due to its larger powder particle size and the required print layer heights.
- EBM is more expensive than SLM due to the EBM technology and metal powders that are used.
What Is the Difference Between EBM and DMLS 3D Printing?
DMLS (Direct Metal Laser Sintering) is almost identical to SLM 3D printing. The name DMLS is trademarked by EOS GmbH. Despite the use of the word “sintering,” the process actually melts particles together rather than sinters them.
Aside from a few differences in printing parameters between SLS and DMLS, they are fundamentally the same technologies.
The differences between EBM and DMLS are, therefore, quite similar to those between EBM and DMLS.
- EBM employs a high-energy electron beam to melt metal powders, while DMLS utilizes a high-powered laser to achieve the same process.
- EBM operates in a vacuum environment, whereas DMLS functions in an inert gas atmosphere (such as argon or nitrogen) at near-atmospheric pressure.
- EBM is primarily used for materials like titanium, cobalt-chrome, and certain nickel-based superalloys, while DMLS accommodates a wider variety of metals, including stainless steels, aluminum, tool steels, and titanium.
- EBM tends to offer lower dimensional precision than DMLS because of larger powder particles and thicker print layers, resulting in rougher surface finishes.
- EBM machines are generally more costly, though the actual expense varies based on the intended application, material choices, and production needs.
This article summarized Electron Beam Melting (EBM) 3D printing technology, including how it works, its advantages, materials, and how it compares to other 3d printing processes. To learn more about electron beam melting 3D printing and how you can apply it to your projects, contact a Xometry representative.
- Inconel® is a registered trademark of Huntington Alloys division of Special Metals Corp., Huntington, WV.
