Impact Strength: Definitions, Importance, and How It Is Measured
9 min read
Published March 9, 2023Updated February 11, 2026
Learn more about the importance of impact strenght in manufacturing.
Impact strength test. Image Credit: Shutterstock.com/Thaweesak Thipphamon
Impact strength is the measure of the ability of a material to resist cracking, fracturing, or plastic deformation under sudden and intense impact, or shock loads. It is a critical property that determines the material's ability to withstand sudden forces. Designing components that will be subjected to high impact or shock loads hinges upon an understanding of these measurements, to allow for potential failures. The impact strength of a material is usually quantified using the IZOD test or Charpy tests. These are indicative and standardized tests, used to grade materials. However, they are not representative of real use and provide limited information about cyclic or real-world loading. This article will describe impact strength, how it is calculated, its importance, the factors that affect it, and the different types of impact strength failures.
What Is Impact Strength?
Impact strength is a measure of the ability of a material to resist fracture under shock and impulse loading. It is only applicable to materials that undergo brittle fracture. It is also used in the testing of ductile materials that display temperature-dependent and/or impulse-dependent brittle-ductile transition. Many materials that are ductile under “normal” loading and operational conditions can display brittle behavior when cold and/or impacted suddenly. Evaluating these behaviors is informative in product design and material selection.
What Is the Importance of Impact Strength?
Understanding the impact behaviors of materials is a critical piece of design information that drives both material selection and detailed design. Components that are likely to suffer high impulse (i.e., short period) impacts must be made to resist the catastrophic effects that these can create.
Good design of resilient products requires various behaviors to be understood in addition to basic impact strength. Understanding properties such as fatigue, microfracture, and mixed ductile/brittle behaviors also contribute to reducing/avoiding making products that fail prematurely in service. Service life is particularly important in many areas. It enables preventative maintenance and drives an understanding of inspection processes and schedules to prevent failures.
How Is Impact Strength Calculated or Measured?
Listed below are the two methods for calculating impact strength:
1. Charpy Impact Test
The Charpy test is less commonly used than the IZOD test and results in a measurement of absorbed Charpy V impact energy, in Joules. This is measured by the post-impact travel of the hammer, as the remaining energy is dissipated in the continued swing of the swing hammer.
To learn more, see our full guide on Charpy Impact Test.
Charpy Impact Test Diagram
Charpy impact test diagram
2. IZOD Test
The ASTM impact energy is measured in J/m or ft-lb/in. Impact strength results from dividing the value for impact energy in (J or ft-lb) by the notch thickness (mm or inches) of the specimen, for an average of 5 test cycles. The ISO method is slightly different, deriving impact strength with units kJ/m2 from the impact energy in J by the area under the notch. This test is performed on 10 specimens and the results are averaged.
To learn more, see our IZOD Test guide.
How the IZOD impact test works
IZOd impact test diagram
What Are the Factors That Affect the Impact Strength of Materials?
Listed below are the factors that affect the impact strength of material:
1. Material Thickness
Thicker material will influence strength by providing more structure/bonds that may need to be broken to achieve fracture.
2. Temperature
Many materials show significant changes in properties as temperature changes. Characterizing these alterations is a critical part of the material definition/testing process, and both IZOD and Charpy tests are performed at a range of standard temperatures.
Metals, in particular, have an annealing temperature, at which they can become more self-healing. Aluminum, for example, anneals at 570°F, so all crystal boundaries blend into each other and the material becomes very ductile. Some materials suffer embrittlement at low temperatures. Many materials weaken as they get hotter, with unusual transitions being evident at temperatures such as the onset of glass transition.
3. Notch Radius
Stress concentration is a major factor in material strength. A sharp-tipped notch will promote fracture by focusing the stress at a point, so notch radius is critically important in comparing tests for like materials.
What Are the Different Types of Impact Strength Failures?
Listed below are the different types of impact strength failures:
1. Brittle Fracture
A brittle fracture is one in which a sample of material has parted into two or more parts. These parts can be refitted together to form the original shape/outline of the part. A cracker undergoes brittle fracture, when fresh and crisp.
2. Ductile Fracture
A ductile fracture is a rare occurrence. Ductile failure modes occur when a material necks irreversibly (i.e., undergoes plastic deformation) and extensively. In general, a massive ductile failure in a tensile test piece looks like a plasticine that has been pulled to form a neck. This is generally followed by a small brittle fracture that can fit back together neatly—rather than extending to a hair-fine thread.
3. Yielding
Yielding is a feature of elastic materials that reach their elastic limit and then undergo plastic distortion. When experiencing forces below the yield point, the material will return to the original shape/dimensions when the force is released. On the other hand, when the yield point or yield strength is exceeded, the material will undergo some plastic (i.e. permanent deformation). When the force is released, the material will recover its elastic distortion, but not the plastic component.
4. Slight Cracking
The purpose of both Charpy and IZOD tests when correctly performed is the parting or fracture of the material sample, into two or more pieces. If the sample is only slightly damaged or partially broken, a higher energy or deeper notch test may be appropriate. The failure can be achieved from a mixture of modes—shear, ductile, and brittle. Failure types are listed as: complete break, hinged break, incomplete break, and non-break.
How Does Impact Strength Relate to 3D Printing?
Most 3D-printed plastics display considerably lower impact strength than a molded or machined block of the same material. This is a function of the anisotropic properties of the construction methods used for 3D printing and can relate significantly to the build orientation. For example, FDM parts offer generally better inter-layer bonding than they do intra-layer, so the models have a reasonable degree of strength in the X-Y plane of the build but are very much weaker along the Z axis. This variation/directionality is true of other model types, to a varying degree.
What Is the Ideal Impact Strength for a 3D Printed Material?
The ideal impact strength for a 3D-printed material varies depending on the material characteristics. In general, the impact strength of FDM printed parts in, for example, PLA is close to zero across the Z axis and up to 23 kJ/m2 across the X-Y axes in Charpy tests.
What Are the Applications of Impact Strength?
While impact strength testing cannot provide an absolute reference point in the design of components, it is a necessary scaling measurement. Listed below are some applications of impact strength:
  1. The relative strength of materials.
  2. Failure modes under “normal” adverse conditions. These results can inform the design process, by improving stiffness and energy dissipation for components. It helps improve real-world performance by, for example, better tolerating ductile distortion that may predictably occur.
  3. Understanding temperature performance, to allow the selection of materials suited to the expected working conditions for the part.
  4. Understanding other environmental factors such as moisture exposure/absorption and its effect on parts.
What Are Examples of the Impact Strength of Some Materials?
Material impact testing is an area of mixed outcomes. Not all testing is as rigorous as it should be. Material manufacture can introduce variability that is not apparent until failure. In metals, heat treatment, and the resulting crystalline structure alterations, can have far-reaching effects that are hard to understand or quantify. Alloying agents are similarly important, though less hidden. Finally, manufacturing processes can alter performance so markedly that basic material testing can be uninformative. A good example is the difference between a forged and a cast steel part made in the same material. The raw material is identical, but the forged part can be orders of magnitude stiffer, stronger, and more fracture resistant.
What Is the Impact Strength of Plastic?
The impact strengths of some common polymers are shown in Table 1 below:
Table 1: Impact Strengths of Some Common Polymers
Table Credit: https://omnexus.specialchem.com/
What Is the Impact Strength of a Metal?
The range of properties for metals is highly dependent on heat treatment and alloying materials, as well as processing techniques. Table 2 below shows an example of the impact strength of metal:
Table 2: Impact Strength of Metal
A few Charpy test data examples are included to understand the range.
Frequently Asked Questions About Impact Strength
This article presented impact strength, explained what it is, and discussed what it means in manufacturing. To learn more about impact strength, contact a Xometry representative.
